Results 1 to 8 of 8
    Established Member Two Rings jpjmustang's Avatar
    May 23 2013
    2014 Audi Q7 TDI - 2011 BMW 328I
    Missouri
    2012 A6 3.0T supercharged oil change
    what oil do you use in you 3.0T?
    Which oil filter is good, better, best?
    How often do you change oil?
    [B]JPJMustang[/B]
    2014 Audi Q7 TDI 3.0 Prem +
    2012 Audi A6 3.0T Prem +
    2011 BMW 328i
    2004 BMW X3
    Jul 21 2020
    Orlando
    LiquiMoly Full Synthetic 5-40, OEM Mann filter. Although dealer states every 10k or full year, I do every 5k. You can find kits on EuropaParts.com or build yourself a kit on rock auto.
    Sep 16 2020
    West Michigan
    I use a LiquiMoly with Mann filter kit from. FcP Euro. Every 5k as 97joey does.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Veteran Member Three Rings GilliamOS's Avatar
    May 26 2015
    2013 A6 3.0T Prestige | 2013 Elantra GT
    Mormon Country
    Mobil1 or Castrol euro spec (found cheap at wal fart).
    Whatever OEM brand is cheapest at that moment, Mahle, Mann or Hengst.
    Right now, I'm on an 11k interval with an oil lab providing guidance.
    2013 A6 3.0T - Slightly better than poverty package.
    2009 A4 2.0T Avant - Totaled
    2000 A4 1.8T - Sold
    1999 Millenia S - Sold, though it should've been crushed 'n cubed
    1997 A4 1.8T - Totaled, repaired, sold years later better than before
    1990 Maxima - Totaled from hail dents
    1987 Maxima - Sold
    1986 Golf Diesel - Rusted and fell apart
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Lots of threads on this. Plenty of fanboys. Any full synthetic 502/503 VW certified oil of reasonable viscosity (5w30, 5w40, 0w30, 0w40) will protect the engine.
    If you really want to drill down deeply into this, go here.
    https://540ratblog.wordpress.com/201...-test-ranking/
    Its a dense detailed blog by a professional automotive engineer constantly updating testing of engine oils, now over 200. This is a severe test for sheer failure, the pressure point where the oil film no longer keeps rotating metal surfaces from coming into contact.
    This blog is the equivalent of several hundred pages. The ratings and associated psi point of sheer failure are about deep into the body of text. Scroll down.
    Of all the oils tested, one particular formulation of Mobil 1 was the highest rated VW502/503 certified oil: Mobil 1 FS (European Formula) 0w40.
    Mann filters are excellent and can be bought in bulk on Amazon at very reasonable prices.
    I change between 6,000 and 7,500 miles.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Four Rings Valpo A7's Avatar
    Nov 27 2018
    2018 Jeep Wrangler JLU; 2015 Mas Ghibli SQ4; 2005 Gulfstream Motorhome
    Valparaiso, IN
    VW 502 spec oil.
    Mobil 1 European Blend
    Valvoline European Blend
    Castrol
    Motul
    Pentosin
    Liquimoly
    These are all good choices.
    For filter I get on Amazon and order a Mann filter. Mann makes the OEM filter.
    For me I use a 10,000 mile change interval. Motor has about 205,000 miles on it now. Some will swear that you should do a 5K change despite the fact that Audi says 10,000 mile interval. Synthetic oil will last easily 15,000 miles
    Feb 05 2008
    Daily 07 Jaguar XJR
    Phoenix, Az
    I do 5k intervals
    Mobil 0w40 from Wally World
    Mann/Mahle filters, buy 5 at a time from Rockauto
    Every service gets a can of BG MOA
    Every other service gets a can of BG EPR
    Veteran Member Three Rings WatchMeSpend's Avatar
    Mar 19 2019
    2016 A6 3.0T Technik S-Line
    Toronto/Ontario
    Quote Originally Posted by 430hps4 View Post
    I do 5k intervals
    Good to see another call it Wally World, even though there are many of us. I miss cruising down the 101, Rudy's Country Store and BBQ and the Salt River. Thanks COVID...
