Results 1 to 13 of 13
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    2021 S4 without Navigation. Can OBD11 unlock it?
    A colleague just picked up the 2021 S4 and it is apparently available without navigation now but can be "bought" through the MMI and downloaded. Is there a way to unlock this through OBD11 possibly?
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Dec 17 2017
    Long Island, NY
    Quote Originally Posted by HyperM3 View Post
    Probably not.. The new "features on demand" are probably provisioned the same way the AudiConnect services are, and it probably checks for a license.
    Established Member Two Rings slws4's Avatar
    Sep 06 2018
    fl
    I am not sure of unlocking the purchasing part. I think the purchasing is part of audi connect, which is a service.
    In my endeavors to unlock the Virtual cockpit items. I have ran across threads of people adding it (navigation). Now I am not sure if they dont have nav to begin with. If the car is a 2021 as stated, it should have android play/car play which can show the nav inside the virtual cockpit via the phone without the need to add navigation from audi connect. Audi connect and nav components may be needed to add navigation (again dont hold me to this as I am not fully sure.),. The below method requires just obd11 and a phone to tether
    Or another way would be to unlock the using wifi hotspot feature via obd11 and then use your phone to tether to your car to review the nav maps. But this requires reflashing the mmi if i am not mistaken.
    Case in point Canadian cars has no audi connect.
    https://www.audiworld.com/forums/a4-...-audi-2912779/
    This was a very interesting read. The first method of unlocking I posted above before this canadian thread, may require some hardware so I am not sure of that.
    May 13 2015
    Georgia
    This will be available later this year for 2020 (a4,a5 family) and all 2021’s Premium Plus with no technology package. It is called Audi on demand where you can purchase the license software thought the MMI in the car.
    Dec 21 2020
    Winston-Salem, NC
    Quote Originally Posted by slws4 View Post
    How do you do this? I have a 2021 and cannot seem to figure out a way. What do you know!? lol
    Sep 06 2018
    fl
    Quote Originally Posted by MattNCs4 View Post
    Here ya go:
    https://www.audiworld.com/forums/aud...-time-2930511/
    Hope that helps. I rarely use nav and have it but meh, cant get lost where i am at and since we in pandemic .. cant really go no where haha
    Dec 21 2020
    Winston-Salem, NC
    Here ya go:
    Ohhhh I thought you meant showing AA on the virtual cockpit.
    Sent from my Pixel 3 using Tapatalk
    Sep 06 2018
    fl
    The title to the thread literally says: Trick to run Waze (Android Auto) and Virtual Cockpit navigation at the same time
    Dec 21 2020
    Winston-Salem, NC
    Yep. It does. Thanks.
    Dec 17 2017
    Long Island, NY
    For what its worth -- my 2021 came with navigation, and will now happily display Audi's map in VC while navigating a route in Waze.. It would previously change it to the compass if Waze had an active route going on my 2018. To re-emphasize -- nothing changed with running CarPlay on the VC screen - it still only sits on the main MMI display. I haven't yet tried initiating a route in both at the same time
    Oct 24 2017
    Houston TX
    Anyone have any update on this.
    I have a 2021 S4 without the Audi MMI Nav package.
    But i would love to somehow get google map / earth or something similar to display in my virtual cockpit
    Veteran Member Three Rings kifac's Avatar
    Mar 24 2014
    Mississauga
    Quote Originally Posted by RickNY View Post
    does waze show up in the VC when the phone is connected and car play is on?
    Dec 17 2017
    Long Island, NY
    Quote Originally Posted by kifac View Post
    No. CarPlay doesn't display anything in the VC screen. The MMI relays song title info from CarPlay to it - but that's about it. I'm not sure what wasn't clear about my last post -- "nothing changed with running CarPlay on the VC screen - it still only sits on the main MMI display"
    Waze (and anything else from CarPlay) will only display on the MMI screen - not the VC.
