Results 1 to 9 of 9
    Junior Member One Ring garyr's Avatar
    Mar 07 2020
    Trinidad and Tobago
    Audi a3 8v 1.2 tfsi ESP ABS fault
    Good day guys*
    I am having a issue with my A3 8v . yesterday i had an ESP ABS fault appear on my Dash. I cleared the errors* with a scan tool and*shut of the car and started it up again with no errors reappearing. i drove the car for a few km and stopped of to run some errands about half hour later i returned to the car and started it up and the errors came back*i have a thinkdiag scanner with ProDiag software and was able to scann* the can to identify the faults .what i found was as follows.
    C101B4A- incorrect component installed Right front ABS Wheel* - passive
    C101B07- Speed Sensor mechanical Malfunction Right front ABS wheel- active
    C101B29-Speed sensor Implausible signal*Right front ABS wheel - active
    C101B14- Speed sensor open/short circuit to Ground -active
    and a few related databus and parking break errors .
    I proceeded to replace the* front right ABS*wheel speed sensor and cleared the errors.
    I test drive the car for 15 mins graphing the speed of the front left and right sensor to ensure they match. and they did match all was good or so it would have seemed .
    the car was parked up for about 2 hours. When started the car the errors returned. I proceeded to take of the wheel and inspect the sensor and the cable connector for damage every thing seem ok . so i cleared the errors put back on the wheels and test drove the car again. both sensors speed*matched . the car was parked for an hour or so and the problem came back. i scanned the car one more time and got the following errors*
    C101B01 -Speed*sensor Electrical fault Right Front ABS Wheel-Active
    C101B29-Speed sensor*Implausible*signal*Right front ABS wheel - active
    and some related erros with databus and parking brake
    can anyone give me some guidance* as to what i should check again.
    Should i try another sensor replacement ?
    Test the cable(Dont have diagrams to do this any assistance i would be gratefull)*.
    regards
    Sent from my Redmi Note 8 Pro using Audizine Forum mobile app
    Dec 25 2004
    Earth
    Sounds like it maybe wires/cables...possible corrision inside connectors...
    Inspect the wires and cables for cuts/breaks/corrosion
    2015 S3 with 210,000 miles with new 2019 Q5 motor. Still going!
    Veteran Member Four Rings Spinnetti's Avatar
    Dec 10 2004
    R8_LS400
    Dallas, TX
    Could be what I just had happen - mouse chewed the wiring in the harness in the engine bay....
    2008 R8 V8 Manual: Uni 93 ECU tune * Avior Exhaust * Spacers * R8 Puddle lights * Custom mats. All 12 of my other VAG cars are gone :(
    Mar 07 2020
    Trinidad and Tobago
    I am trying to figure where the wire runs it goes behind the fender sheild and into the firewall but I can't see or access the wires . Any help on this . My next step is the get the pinots for the abs module and check the wire from the abs connector to the abs sensor. Hopefully I get pinouts .
    Mar 07 2020
    Trinidad and Tobago
    Quote Originally Posted by MikTip View Post
    I did inspect the cable and connector ends on the sensor side and all seems good will do a continuity test once I figure out the pinouts for the abs connector
    Mar 07 2020
    Trinidad and Tobago
    Quick update
    Today I bought a bosch replacement front wheel abs sensor. And also found the pinouts for the abs module connector.
    So I have in my possession two wht003860 ATE BRAND SENSORS which I bought at the dealer. both work when initialy installed but gave error as shown above within half hour of them being installed . Before replacing the sensor again I scanned the car this afternoon and got the same errors again
    I replaced the sensor with the new bosch speed sensor as seen below in pic and all seems good so far . I drive the car for 15 mins . Parked it for a hour and a half before checking it and no errors . I will do another check In the morning. I have also shakes the wires and even ran water over wheels and windshield . But every thing looks good so far.
    At this point I am hopeing all is well if I do get errors next step is wireing then ABS MODULE
    IMG_20210104_183843.jpgScreenshot_2021-01-04-15-34-22-026_cn.wps.xiaomi.abroad.lite.jpg
    Dec 25 2004
    Earth
    Quote Originally Posted by garyr View Post
    Quick update
    Looks like a bad sensor. Nice fix!
    Mar 07 2020
    Trinidad and Tobago
    Strange that the new sensor I bought from the dealer was bad the sold me ATE wht003860 sensor that was faulty.. today I bought a bosch replacement and it seems to be working so far
    Mar 07 2020
    Trinidad and Tobago
    Update 2
    Started the car this morning no errors . Went for a drive all seems well .
    Apparent I was sold a bad sensor by the dealership. Strange all sensors read on average 1.4 to 1.5 k ohms
