Originally Posted by
slws4
Noted; 2018-2022 is four years; however each car does have a manu date so I was going by that. But I don’t fit the 50k criteria as I’m slightly over.
My major concern is not paying a 4-5k bill. When you say Warrantable under the standard warranty; can you clarify on that a bit more?
Sure, I should have expanded on the "standard warranty" bit. If you look at any RO from a dealer, there's a footnote that mentions a warranty for the provided service with certain terms and conditions. This is not the manufacturer warranty that comes with the car, but rather comes from the dealership or independent repair center.
Let's take for instance, a tech forgets to put your oil drain plug back in after an oil change, and on your way home, all the oil drains out and seizes your motor. The manufacturer warranty is not going to cover this (not a manufacturer defect, recall, etc.). This was at fault from the dealership technician. Another angle you can look at is, if
you changed your own oil and forgot to put the oil drain plug back in and seized your motor . . . the manufacturer warranty is not going to cover for that either.
So essentially, you can go in to the dealer and get the work performed out of your own pocket and they will warranty their work for a certain period until it starts leaking again and use the dealership service warranty. Or, you can leverage your relationship with your service advisor to see if they can push this across as a powertrain warranty claim if it's still active or as "in good faith" since you're slightly over. Now, obviously the specifics of what Audi will/will not cover is going to entirely dependent upon your dealer group, specifically your service advisor and how much they will go to bat for you. Some appreciate the honesty upfront about the car being tuned and can work with their service technician to avoid certain procedures requiring it to call back to home. Others, not so much.
It helps if there is a local Audi group in your area that members can direct you to certain advisors who are on the enthusiast side, and go through the technical jargon with you so they can communicate to Audi about performing it in good faith regardless of the tune or mileage (similar to what TJay74 replied).
