Results 1 to 9 of 9
    Junior Member Two Rings
    Jul 21 2013
    lithuania
    S6 c5 camshafts.
    hello. i have S8 D2 40v AQH and now my engine broken so i changed it to s6 c5 40v engine AQJ . etka shows that intake and exhaust camshafts should be the same on s8 d2 and s6 c5. and indeed my s6 engine have same code intake camshafts like s8, but exhaust camshafts codes are different. s8 D2 exhaust camshafts are 077109022DE - DP.. and in my s6 c5 engine AQJ exhaust camshafts are 077109022DF-DG ,i found in Handler that DF AND DG nockenwell erszetsen to DP-DE what mean that ersetzen or ersezt its mean they changed camshafts codes only but they are exatly same, or they changed camshafts and made more agressive them for s8 ?? thank you
    Jul 18 2012
    2013 Town & Country
    St. Louis
    Someone has a good thread on here about the differences between the 4.2 A6, S6, A8, and S8 motor. You are correct, the exhaust cam is different along with the intake if I remember correctly, aiding in tge S8 making an extra 20hp.
    Sent from my SM-N986U using Audizine Forum mobile app
    "If it has tits or tires it will give you trouble."
    2003 S6 01E swapped
    Old:
    02 A4 Avant, 3.0 and 01E (owned twice)
    02 allroad, 2.7TT and 01E
    Jul 21 2013
    lithuania
    but etka shows me the s6 exhaust cams should be same part number as s8 .. and what mean word ersezt from german language, its mean they just changed code but left same camshafts or camshafts different are made for 20hp more ?? :)
    Jul 18 2012
    2013 Town & Country
    St. Louis
    https://www.audizine.com/forum/showt...L-V8-A6-S6-RS6
    I have read the intakes are the same and I've read they're different between to S6 and S8.
    2003 S6 01E swapped
    Old:
    Sep 16 2010
    Central Wash
    Going off foggy and unreliable memory I think the only differences we know about between the S8 and S6 engines are slight tuning, intake cam and intake manifold. And then a few bolt on parts.
    Changing the exhaust cam wouldn't get you anything, and no way is there 20hp hiding in exhaust cam lift/ duration. The rest of the engine and drivetrain are similar enough that you can't account for 20hp anywhere; so if that HP figure is accurate then it's in fueling/intake setup.
    Anyone know if the hp24 trans in the S8 is the same as in the S6? Is there a gearing difference that takes better advantage of the N/A torque / curve?
    Senior Member Three Rings C5S6's Avatar
    Oct 04 2008
    '02 S6 Avant, '03 A6 Sedan
    CO mountains
    Quote Originally Posted by rollerton View Post
    I believe the S8 trans is the same, they both have a 4:11 FD...A8 and C5 V8 do not, but do have a 5HP24A
    -TJ
    2002 S6 MT6
    2003 A6 2.7t MT6
    Jul 21 2013
    lithuania
    intake cams are same, same part numbers, i checked that in reality, because i have both sets of camshafts, but now cant decide remove from s6 engine exhaust camshafts and change to s8 exhaust cams or not, part numbers are different but i dont know i the lift and duration is the same or not, or only part code different but same lift and duration have. To change cams i need to release ignition, again 1 full day of work. from morning till the night . intake manifolds are same no difference becuse i have both manifold from s6 and s8. engines are totally same , just airfilter boxes are different and intake pipes lenght are different, s8 longer pipe, and s6 shorter. fuel injectors same part number. i dont know osm is the same on s6 and s8 :) and about trans i know nothing , mine s8 from factory came with DGV manual 6 speed. and yes manual gearbox bolt on straight to s6 c5 engine and s8 d2 engine, because all bolt holes are in same location.
    Jan 05 2010
    burnaby british columbia
    Doing similar thing as OP
    BBD s6 into S8 that has AYS
    Here part #s from my motors.
    077 109 021 FS bank 1 intake
    077 109 022 EE bank 1 exhaust
    077 109 021 FR bank 2 intake
    077 109 022 EF bank 2 exhaust
    S6 BBD
    077 109 021 FQ bank 1 intake
    077 109 022 DP bank 1 exhaust
    077 109 022 DE bank 2 exhaust
    Sent from my SM-A715F using Audizine Forum mobile app
    Dec 10 2013
    Borden, Ontario, Canada
    In the hierarchy of 4.2 belt engines, I've always known the performance list to be this:
    If working from a stock 300hp A6 AWN or similar to S6 levels:
    S6 intake manifold (2 stage)
    S6 intake cams
    S6 throttle body
    S6 injectors
    S6 exhaust manifold
    Tuning
    From S6 to S8:
    S8 Exhaust cams
    Tuning
    The difference from the S6 and S8 are only the Exhaust cam and tune. Everything else between the engines are the same.
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
