Originally Posted by
elijahallen
Here is a video of my car hitting the limiter in a roll race video. Unfortunately it happens when I am ahead for a bit but if you turn volume up you can hear me hit limiter then lift and floor it and hit limiter again and then manual shift. This was in dynamic mode in auto not in manual mode. Its quite annoying to say the least but Uni is supposedly coming up with revised tunes to fix the problem. My wheel/tire setup is 19x9.5 with 265-30-19 PS4's
Watched your video when searching YouTube before
your stock block? Mine would do the same if I left it to shift on its own (kind of disliking manual shifting at that high of speeds at this point), would love to just leave it in auto/sport and let it do its thing. If i were to guess it has something to do with increasing RPM of motor and the TCU not working correctly at that high of rpm shifting. From what little we can get answers on this its been said tires, if that is the cause what should we change them to? Is that the issue or is its something else. Assuming
Adam (vancity) might be able to help get a better answer to this subject than me guessing. Would love to know the solution to have it auto shift on its own, sure would be more consistent especially for a drag racer.
