Hello,
I am running into a strange problem with my power steering. (B6 S4)
About 9 months ago my power steering failed. It was the small sleeve shaft that goes from the pump to the timing gear. The splines inside were stripped, I assume due to my pump seizing. I replaced only the sleeve and everything was okay.
A few weeks ago my power steering went out again. After taking it all apart, it was the same issue. Splines stripped out in the shaft sleeve. This time I replaced both the pump (with a Bosch reman one I got from a local audi mechanic) and the pump shaft sleeve.
I got it all in fine, but now I am running into issues bleeding.
When I bleed it with the car off, it seems to act how it should. Bubbles get pushed out, fluid level goes down, it gets easier to turn. However, when I turn on the car, it will not bleed. The first time I try to bleed it with the car on, when the bubbles subside, somehow the level of fluid is always higher than it was with me bleeding it when the car is off. I've tried for hours to bleed the system.
It seems as if the system is pulling in air, but only when the car is on. Is that a possibility? Or, could the pump I bought be bad?
When the car is running it seems there is a lot of vibration on the hard feed line where it leads into the top of the pump through the banjo bolt. It almost seems like the pump is starving for fluid in this spot, or somehow there is aeration here. But no fluid leaks out of the where the banjo bolt meets the pump.
Any help, suggestions would be much appreciated. I'm about out of ideas.
I don't think it's the rack as it worked fine before and theres no leaks near the tie rods. I don't think it's a leak in the lines as I can't find a leak and there was no leak before. I don't think it's the screen in the reservoir as it bleeds properly with the car off, when you'd think it would be harder for the system to push fluid through the screen. But I could be wrong on any of those.
