Results 1 to 28 of 28
    Sep 02 2020
    Philly burbs
    Why does my rs3 slam to stop in reverse?
    For the 4th time now, i go to backup and nothing is in the rearview camera or anything and the car basically slams on the brakes and the car goes into neutral and the dash display tells me to put the car into gear!!!!!! What am i missing???
    Senior Member Two Rings arulrs3's Avatar
    May 02 2019
    Burlington, NC, Carolinas
    Quote Originally Posted by Jerryrs3 View Post
    Rear cross traffic assist if you have driver assistance package is what I think of. It happened to me twice but gear did not change. Try turning off the parking assist and see if you can reproduce the issue.
    The rear cross traffic assist is activated when the parking assist is turned on. ... are different levels of warnings: visual, acoustic and a short jolt of the brakes.
    Current DD 2018 Audi RS3 Nardo Grey .. Stage 2 - 93
    VIR fullcourse - 3.27 miles in 2.10.67 minutes.
    10.88 @ 129 MPH - Uni Stage 1+ @ Rockhingham Dragway, NC (70-80 F and DA 1000 ft)
    11.264 @ 121 MPH - Uni Stage 1+ @ Rockingham Dragway,NC (80-90 F and DA +3100 ft)
    11.882 @ 114.80 MPH - Stock ECU/TCU ON 93 @ Rockingham Dragway,NC (50-60 F and DA is less than 1000 ft)
    Past
    2016 VW Toureg TDI / 2014 BMW 328Xd/ 2011 BMW 328i/ 2009 VW Jetta 2.5/ 1997 Nissan Altima
    Junior Member Two Rings
    Jul 02 2020
    Columbus OH
    Mine does that when I try to back in to a parking space too quick, scared the shit out of me everytime, but it doesn't pop into neutral though
    Sent from my VOG-L29 using Tapatalk
    Sep 02 2020
    Philly burbs
    I dont believe i have the rear criss cross traffic package but i will turn off the camera...and try that ...i was going slow....nothing crossed my path any time...etc...thanks for the feedback
    Sep 02 2020
    Philly burbs
    Quote Originally Posted by iambjx View Post
    Yes, scares the crap out of me every time! And then i gotta put it into reverse again.....not fun
    Veteran Member Four Rings S3DUDE's Avatar
    Aug 29 2017
    24' RS3, 23' RS3, 24' Colorado ZR2, 24' GR-86, 09' supercharged track SI
    Tucson, AZ
    I have that happened to me but it was always when I was backing up and I didn't see a car coming and the car suddenly stopped for me but never got the car in neutral.
    8V RS3 [email protected] mph (ran a few 11.7s stock and ran 118+mph several times)
    8Y RS3 k&N filter ran [email protected] (ran 11.6 5 times and trapped 120+ several times)
    at 3100ft elevation
    Sep 02 2020
    Philly burbs
    Quote Originally Posted by arulrs3 View Post
    Just looked and i do have the rear cross traffic assist....ugghh...thanks for the heads up
    Mar 06 2020
    TX
    Im fairly confident you can disable the braking function but still have all the other warnings.
    Nov 12 2019
    Quote Originally Posted by AudiRS# View Post
    I tried having the dealer disable nthis feature and they said they couldn't.
    Mine would trigger for no good reason.
    Sent from my IN2025 using Audizine Forum mobile app
    Registered User Three Rings MerakiAutoworks's Avatar
    May 09 2016
    Orange County, CA
    I would love to disable that breaking feature. When I'm reversing into a tight spot it slams the brakes and scares the crap out of me.
    -Josh
    Senior Member Three Rings Dominick's S4's Avatar
    Oct 04 2013
    2016 Audi Q5s 2016 BMW 340I M 2014 Jeep Grand Cherokee Limited 2007 Jeep Grand Cherokee
    Johns Creek, GA
    By any chance.. Do you rest your hand on the stick shifter? Maybe when rear cross traffic assist engaged and it slammed on the brakes in reverse the hand resting on the stick shift inadvertently pulled the stick shift back into neutral? I've had it pop into neutral on me when launching and resting my hand on the shifter..
    2019 RS3 - Black - Unitronic Stage 1+ ECU 93 and E85 tune and Unitronic Stage 2 TCU Tune, APR Intercooler, APR Turbo Inlet and Open Air Intake, IROZ DSG Catch Can and Engine Catch Can, ECE Poly DogBone Mount, P3 Gauge - E85 Content Monitor, Neuspeed RSe10 18x9 wheels Satin Black, MP4S 255/35/18. Best of: 1/8 mile 7.006 @ 102.28mph, 1/4 mile 10.828@ 129.78mph, 60-130 - 7.86, 1/2 mile 17.29 @155.59mph
    Veteran Member Three Rings carlosvjr92's Avatar
    Nov 25 2015
    Miami, FL
    Its the back up traffic assist. Its happened to me where its picked up something on the side thinking it was moving and slammed on the brakes. It usually works, but every now and then it has flukes. So far mine seems to work okay
    2018 RS3 (Cumulus Blue) - APR Stage 2 || APR Intake || APR Downpipe
    Mar 07 2017
    San Francisco
    "Better safe than sorry" -the computer
    18 Silver RS3. Notable past cars: v10 r8, noble m400, lotus elise
    May 10 2017
    Lewisberry PA
    I believe I have had this happen and I do not have the DAP package.
    2017 Ara Blue RS3
    Nov 06 2017
    Vancouver
    Quote Originally Posted by nesbit View Post
    You don't need it
    The cross traffic alert (whatever it's called) is standard and uses the same sensors as the blind spot monitoring. The DAP is a totally different sensor in the grille
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    Ive never had the cross traffic protection put me in neutral.
    My posts are regularly edited or deleted, since 2004 because I tell consumers the truth about modifications or components from within the industry.
    Wastegate Rattle Fix info
    2017 rs3 nardo stage 2+
    2009 r8 phantom black & boosted
    2007 rs4 sprint blue snow car
    2000 s4 single turbo scary fast
    2001 s4 stage 3 street beater
    Nov 06 2017
    Vancouver
    Quote Originally Posted by SlowSedans View Post
    Me neither. But it does activate for no reason sometimes and is annoying as hell
    Feb 17 2018
    California
    Quote Originally Posted by Potatohead_RS3 View Post
    Auto slam of brakes for no obvious reason in reverse. Yes me too... very annoying and jarring.
    Counting on it still to work when I DO need it though.
    System has never placed the car into NEUTRAL
    Sep 02 2020
    Philly burbs
    Quote Originally Posted by Dominick's S4 View Post
    Thats a possibility i thought about...it does scare the crap out of me...
    Sep 02 2020
    Philly burbs
    Quote Originally Posted by Skunkwerx View Post
    Thank you for the feedback...its nice knowing im not alone....im getting ready to mod it and dont need " gremlins" with the car going in....
    Mar 06 2020
    TX
    I have my “pre sense” warning set to “late”. On the mmi it also shows little radar circles to the rear. I basically never get reversing intervention. Do you guys getting intervention have your pre sense to be more sensitive than late.
    Sep 02 2020
    Philly burbs
    No...i need to look into that...thanks
    Jun 07 2019
    2017 S6
    NC
    Do you have your seat belt on when this happens?
    Veteran Member Three Rings adamRS's Avatar
    Jul 09 2009
    Ashburn, VA
    this has happened to me exactly once, when I backed out of my garage faster than I should have. does this always happen in the same place, or anything similar about the occurrences?
    2018 RS 3 - Daytona Gray | IG: @adam__rs
    Nov 06 2017
    Vancouver
    Quote Originally Posted by adamRS View Post
    It will stop if it "thinks" you are about to back into someone's path. The point of the system is to detect cars coming down the lane when you are backing out of a parking spot. So, any time it detects something it believes is a moving car it will warn you, and if you don't stop or it feels the need to stop, it will. I've had it activate once or twice for seemingly no reason at all and another time because I had an empty garbage can off the side of the driveway . So who knows.
    Veteran Member Three Rings signde's Avatar
    Apr 07 2019
    nashville, tn
    the first time this happened to me it was so jarring i actually thought i hit something.
    Audi 8V RS3 | Porsche 997.1 Turbo | VW MK4 R32 | Porsche Macan Turbo
    Jul 09 2009
    Ashburn, VA
    Yeah, I am aware of how it works - I was wondering if the OP has noticed any similarities when it triggers in his car. For me, it must have picked up my wife's car that was parked on the other side of the driveway the one time when I backed out of my garage too quickly. Nothing was actually coming in my direction, or in the path of my vehicle.
    Dec 16 2020
    NY, NJ
    This happened to me in my 2019 Rubicon crossing the George Washington Bridge into NYC on the lower level. Not going in reverse, but the same thing happened where the truck slammed on the brakes and the instrument cluster displayed 'BRAKE BRAKE!" The only potential damage was my shorts.
