Yes, the ECU can be scaled differently to make 22.5 PSI seem like it’s actually less but there aren’t many OTS tunes that offer it.
Before I set my MBC to cap boost to 22 psi I used to overboost from 2600 all the way to like 3500 and the boost curve was just a flat line because the map sensor couldn’t see the actual boost.
Attachment 213983
I drew in an idea of what actual boost was actually doing.
If I could run 22-23 PSI instead of 20 to where I make peak HP at 5800 RPM and still have fuel for it, my car would make a pretty good amount more power. Once I get my fuel pump in I’m going to try and do some dyno runs with just the MBC, no N75 (just plugged in) and see if I can get 22 PSI at 5800.
It would be nice if we could just throw in a 3 bar map sensor and have someone write a K04 tune for 22-23 PSI. Alas, our ECU makes it difficult.
Sent from my iPhone using
Audizine
