Results 1 to 9 of 9
    Senior Member Three Rings akingzkid's Avatar
    Mar 04 2018
    2006 Audi A6 3.2, 2014 Mercedes E350
    Virginia
    Ticking sound from under hood (purge valve??)
    Hello all. I had the car running last night with the hood opened while I sprayed some of that spray into the vent intake area that removes the musty smell from blowing through the vents. I noticed a pretty pronounced ticking sound that I had never heard before. To be fair, in the 1 year I have owned the car, I probably haven't ever had the hood opened with the engine running so maybe it has been doing this all along and I just didn't notice it.
    Also, I can't recall if it was making the sound before I started spraying the solution in the vent intake thingy or if it started as a result of me spraying it in there. I'm trying to determine if maybe I caused it by spraying it in there. I doubt it but thought it could be a slight possibility. The ticking sound does come and go. It will do it for a while and then stop and then start again.
    I have circled in the picture where the sound it coming from and I believe that to be the purge valve. When I put my hand on it, I can feel it ticking. I did some research last night and found that it is normal for the purge valve to make a ticking sound. Is that true and is this normal? Video link below.
    Car is 2013 A6 3.0T.
    Thanks.
    https://youtu.be/nCKUNbDSD6w
    2013 A6 3.0T Prestige (LED pkg, cold weather pkg, cooled seats, innovation pkg (HUD, top view camera), ACC, sport pkg, 20" rims, HPS short ram intake)
    2006 A6 3.2
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Yes the evap valve clicks quite loud, as you mentioned you probably just never had your head that close to it while running.
    FWIW if you have VCDS you can activate it and hear it clicking without the engine running. As long as no faults it is likely all well.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Mar 04 2018
    Virginia
    Quote Originally Posted by gk1 View Post
    Thanks gk1. I don't have a CEL. Yes, I do have VCDS. I will run a scan tomorrow to see if any faults come up. Listen to yours for me and let me know if it sounds the same. LOL. It's just weird how it sometimes stops clicking.
    2006 A6 3.2
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by akingzkid View Post
    LoL. It is a valve after all. Doesn't always need to run. :) Only when it feels like purging.....
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Three Rings prestige.phantom's Avatar
    Jul 16 2018
    Connecticut
    My car sounds the same. I was concerned when I first heard it, but Im not pulling any codes, and the car runs fine, so Im not worried
    2013 Audi A6 3.0T Prestige
    | Phantom Black Pearl | Nougat Brown interior | LED Headlights | Cold Weather PKG | 20" Sport PKG Wheels & 3 Spoke Heated Wheel | Fine Grain Ash Natural Inlays | Michelin Pilot Sport AS3+ Y | OEM "Rings" Puddle Lights |
    | AWE Touring Exhaust | JHM Non-Res DPs | Eibach Pro Kit & Bilstein B4 Sport Shocks | Eurocode Trans Mount | JBX Carrier | S8 Front Brakes w/ EBC Red Pads | 034 ECU 93 STG 1, TCU, Rear Swaybar, and Endlinks |
    IG: @prestige.phantom @ctautoart
    Mar 04 2018
    Virginia
    LOL. Gotcha. Makes sense.
    - - - Updated - - -
    Quote Originally Posted by prestige.phantom View Post
    Thanks for the feedback. I appreciate it.
    2006 A6 3.2
    Veteran Member Three Rings krwalkman's Avatar
    Jan 01 2018
    Thornton, CO
    Late jumping in here, my A6 does the same. Interestingly, I have never heard it from the SQ5.
    Moonlight 2012 A6 Prestige FBO - SOLD
    Monsoon 2014 SQ5 Prestige
    4.0T Swap in Progress by @SPAutowerks
    Mar 04 2018
    Virginia
    Quote Originally Posted by krwalkman View Post
    You are not late. You are on time. Thanks for your feedback.
    2006 A6 3.2
    Mar 04 2018
    Virginia
    I ran a VCDS scan today and did not find anything wrong. I also tried to test the purge valve and got an error message (it would not run the test).
    2006 A6 3.2
