Results 1 to 12 of 12
    Established Member Two Rings Jeffinstereo's Avatar
    Jun 15 2020
    Philadelphia
    Spark Plugs post tune
    What plugs is everybody who has gone Stage 1 running? I'm running an IE Stage 1 on 93 octane and still have my stock plugs. Coming up on 50K miles so I was going to change when I do my brakes in January. Already purchased NGK plugs (linked below) but wondering if these are gapped properly for stage 1. Saw a pinned bulletin on the IE FB consumer page mentioning a different gap for 3.0 TFSI Supercharged on Stage 1 tunes. I also can't tell from their product pages what these are gapped at.
    No real issues with ignition running OEM I've found, just want to make sure I'm running the correct stuff going forward.
    '15 SQ5
    IE Stage 1 Tune and intake
    034 drivetrain, tranny mounts, rear sway bar
    AWE Downpipes
    KW Street comfort Coilovers
    Homemade blackout package
    Jun 15 2020
    Philadelphia
    I've reached out to IE support. They sent me this plug and recommend a .028 gapping for stage 1 tunes.
    https://www.ngk.com/ngk-2668-bkr8eix...-ix-spark-plug
    What's hilarious is that their datasheet for this plug is listed as a .032 gap. However, an Amazon review of this plug has a user actually measuring it as .028, so they literally have their own specs wrong on their website. After bringing that up with IE their response is essentially "use that plug, there's a typo online."
    Audi SQ5 is not listed as compatible but that's understandable as the car is no longer running within stock parameters. Hopefully this thread helps somebody else in the future.
    '15 SQ5
    AWE Downpipes
    Jul 31 2016
    PA
    Quote Originally Posted by Jeffinstereo View Post
    I have a set of those, and they were definitely around .032 when I got them and needed to be gapped down. I'm sure there is some variability in there but likely more measurement error. You need to use the wire measuring tool or some feelers gauges. The little round ones with a slope on them are just not accurate.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Veteran Member Four Rings ILVTRANCE's Avatar
    Dec 19 2012
    New York
    2014 SQ5 P+ | 034 Stage 2 ECU + TCU | 034 190mm crank pully | 034 Street Density motor mounts | 034Motorsport S34 Carbon Fiber Intake | Merc Racing HX V3 | Bilstein B8's w/ H&R Springs | 034 Trans insert | RSNAV 10.25
    NEW EDM MIX APRIL 2021 https://soundcloud.com/matt-scheinwa...in-my-basement
    Jun 15 2020
    Philadelphia
    Lol good to know I'm over thinking it.
    '15 SQ5
    AWE Downpipes
    Jul 31 2016
    SC PA
    I just did mine about a hundred miles ago, this is from Chris at EPL: We recommend the NGK PFR8S8EG plugs gapped down to .026" and replaced every 25k miles or less.
    Those plugs are allegedly gapped to .032 from the factory, mine varied from .032 to .036.
    SOLD - '14 SQ5 - EPL Stage 2 + TCU | AWE Black Diamond Touring Exhaust | 034 Throttle Body Inlet hose fed by an APR Open Intake
    Veteran Member Four Rings MSq5's Avatar
    Feb 14 2017
    Toyota Highlander, Nissan Armada, Kubota M4030, Scag Tiger Cat 2
    Gulfport, MS
    Quote Originally Posted by Shaggymatt View Post
    Chris is right. Stock NGK platinum gapped to .026". Higher boost does shorten plug life, so 25k miles or less is the change interval.
    I'm trying NGK's iridium plug equivalent to see if it lasts a bit longer.
    BKR8EIX # 2668
    Iridium is both harder than platinum and has a much higher melting point. This is a fine wire tip, so you must be careful not to scrape it when regapping. Also, this plug, while a direct cross-reference number for PFR8S8EG, is technically an original equipment motorcycle plug! So, don't be surprised if it comes up that way in the charts.
    It is performing great. Zero misfires at about 20 psi boost, stage 2 dual pulley 93 octane. Time will tell as to whether it will extend plug life. I was getting only 15K on the platinum.
    2017 Q5 3.0T S-Line | Brilliant Black | 034 Stage 2+dual pulley 93 octane tune | JHM 187mm crank pulley w/ EPL 57.6mm s/c pulley - 3.247 total ratio | Red Star shielded test pipes | Magnaflow high flow downstream ceramic core bottle cats | Vibrant Ultra Quiet Resos in place of OEM baby resos | aFe Pro 5R (part#10-10121) filter in "modified" stock air box | 034 silicone throttle body hose | HP Tuners custom TCU tuned ZF8 | Merc Racing HX | Michelin Pilot Sport A/S 3+ 255/45/20.
    Veteran Member Three Rings JayCar's Avatar
    Dec 13 2015
    2023 Tesla Model Y Performance, 2022 MINI Cooper S Countryman, Specialized Tarmac SL4 Sport :-)
    Houston, TX
    Quote Originally Posted by MSq5 View Post
    BKR8EIX # 2668
    Checking to see how these plugs worked out for you? I just bought the 2669 (BKR9EIX). I haven't installed them yet, but wanted to give them a shot.
    2014 SQ5/Monsoon Gray
    Go: APR Stage 2+ w/ SC pulley, Airbox mod w/ aFe hi-flow filter
    Ride: H&R Street Performance Coils, RS6 reps in Gunmetal 21x9.5 w/ Michelin PSS 285/35/21
    Look: P3 vent gauge, HID fogs, E-code heads and tails, Many VCDS mods
    Rebuild Thread
    Feb 14 2017
    Gulfport, MS
    Quote Originally Posted by JayCar View Post
    Still doing fine. No misfires. Have about 20,000 miles on them. I did pull them recently when doing routine maintenance. Looked normal and needed no regapping. I usually check plugs during an oil change just to inspect for coolant from supercharger cores (none) and to check gap. I see no reason, zero reason to go step colder though. Try the 9s, but don't be surprised if they foul in daily driving.
    Dec 13 2015
    Houston, TX
    Yeah honestly I ordered them by mistake. I might return them and the 8s, but figured since I had them I’d give them a shot.
    I have my previous set of plugs still (OE NGK) with about 8K on them I can always use if these poop out.
    Rebuild Thread
    Feb 14 2017
    Gulfport, MS
    Give them a try, I guess. Some tuners recommend heat range 9 for dual pulley so give them a try. If you are pulling timing it might help. Gap tight, at least .026" if not a bit tighter and try. If they foul in city driving, pop the 8 range back in.
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Did you gap to 0.026 or 0.028"?
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
