Results 1 to 6 of 6
    Active Member One Ring dan0709's Avatar
    Dec 14 2020
    1990 Mitsubishi Lancer
    Germany
    3.0 TDI V6 Selfmade Intake?
    Hello guys,
    I wonder if there is a bolt-on solution for a 3.0 TDI V6 (2012, engine code CDUC) intake on the market?
    I'm from Germany and the only solution I know is the "Turboloch" intake out of silicon. But it's out of stock.
    Someone here has a selfmade one for example like this? Or do you know another brand that offers a bold-on solution?
    greetings from Germany
    2012 Audi A4 B8.5 Avant 3.0 TDI Quattro S-Line
    RS style Grill - ingonoaktuning front lip - Stage 1 - Audi 7-Doppelspeichen S-Line wheels 19x8.5 et43 with 12mm spacers - 255/35-19
    Instagram danweezer
    May 20 2010
    Have you checked Darkside Developments in the UK?
    2016 A6 TDI Prestige - Tornado Gray. Malone Stage 2, DPF Delete, EGR blockoff, S6 F&R brakes, 034 RSB, RSNav S4, P3 v3 TDI gauge
    2003 RS 6 - Misano Red. AMD ECU/TCU tune, KW V3s, Hotchkis sway bars, Phaeton brake ducts, red carbon fiber trim
    2005 allroad 6MT swap - Alpaca Beige
    2003 allroad 6MT - Highland Green Metallic / Fern Green & Desert Green interior (1 of 15 max) - WIP
    2003 allroad 6MT - SOLD like a dumbass
    2007 A4 2.0T quattro - Gone but not forgotten
    Dec 14 2020
    Germany
    Thanks this looks interesting, the only issue is that this will only fit with the 88mm BI-TDI MAF.
    Does anyone know if the 88mm BI-TDI MAF housing (059906461Q) will fit plug & play on the stock air filter box?
    It is possible to attach my MAF Sensor on the BI-TDI housing?
    Maybe the BI-TDI Sensor is longer than mine?
    Instagram danweezer
    Dec 14 2020
    Germany
    After a little google research I found out that the MAF Sensors are equal. They have the same part number 420 133 471, this means its only the housing what is bigger. The airbox side is identical.
    MAF Measurements:
    Original 3.0 BI-TDI: Airbox-side: 92mm
    Original 2.7 / 3.0 TDI: Airbox-side: 92mm
    Original 2.7 / 3.0 TDI: TIP-Side: 78 mm
    Original 3.0 BI-TDI: TIP-Side: 88mm
    Once installed the MAF Sensor will need calibrating by your tuner.
    Now I had to look after a tuner here in my area who can do this.
    Instagram danweezer
    Jan 08 2016
    Los Angeles, California
    Just came across this post; did you ever get this all sorted out?
    '14 Q5 TDI Premium Plus S-Line w/ Black Optics: APR ECU Tune, DTUK TCU Tune, Magnaflow 3" Catback, SQ5 BITDI Intercooler, Hi-Flow CP4 Metering Valve, AFE Dry Flow Air Filter, Full ECS Drivetrain Inserts, AG M610 Wheels, 034 RSB with Moog Endlinks.
    Dec 14 2020
    Germany
    Quote Originally Posted by Pittdawg View Post
    Nope.
    Instagram danweezer
