Results 1 to 4 of 4
    Senior Member Three Rings cssullivan's Avatar
    Jan 02 2019
    MA
    Help! 02895 and 02897 Fault Code (FIXED)
    I was fixing the headlight adjustment code I was previously getting, now I seem to have disabled my DRL's.
    I am now getting this error: 02895 - Supply Voltage for left LED-module for Daytime Running Light and Parking Light and 02897 - Supply Voltage for right LED-module for Daytime Running Light and Parking Light
    Has anyone been able to fix this before?
    Oct 19 2008
    Ontario%20Canada
    Quote Originally Posted by cssullivan View Post
    I was fixing the headlight adjustment code I was previously getting...
    Let's start with how you went about doing this...
    2011 S4 - Ibis White - 3 pedals - daily driver
    2.95 PR, EPL software, Merc Racing HX, Eurocode inserts, Koni Yellows, H&R OE Sports, beefy RSB, homebrew CR15, stainless brake & clutch lines, custom FBSW by FlyDesigns, P3 Multi Gauge
    Jan 02 2019
    MA
    Quote Originally Posted by wes8398 View Post
    I was using the Snap On Solus. I went to Central Electrics, Basic Settings, Channel 011 and learned the headlight position to fix the previous code. But somewhere before or in the midst of that I disrupted the DRLs
    The DRL's now only work when the headlights are off.
    Jan 02 2019
    MA
    So I didn't sleep last night trying to figure this out but I was able to clear the code. Central Electrics, Security Access, Adaption, Channel 03, change the stored value to 25.
    From what I've read the default value of 9 isn't enough voltage for the DRL to work, so it throws the code.
