The simplest solution is usually correct. As several had said, the slide pins are probably not retracting enough or one is stuck. If the ebrake was engaged, or even slightly, it would be smoking the pads. No brake shop will go thru the effort any of us would for our cars. One has to remove the pin rubber boots, (they should be really be vacuum sealed on there) and should "pop" off. Pull the pins...sand them down to a shine, and get a wire bristle brush and scrub inside the pin holder "hole" or drill wire brush in there of course with a cheapo Freight Harbor pencil size wire brush. Then lube them up with high temp grease, any will do. Like the above comments, anyone can change the brakes with minimal wrench skills, but the extra effort is what counts. No shop will do that as they are "book time". In and Out.....with your 10yr old car and harsh Canada winters, (salted roads??). either way...A rusted pin doesn't release any slight pressure from not releasing will cause that heat. Maybe the now winter cold will keep them cooler (lol), but I'd hate to do that work in the freezing cold...
