Results 1 to 11 of 11
    Veteran Member Three Rings slammed_nogaro's Avatar
    May 10 2007
    CHICAGO
    2014 Audi S6 upgraded Headlights help.
    HI Guys. My friend just got a 14 S6 So the previous owner did a full oem RS6 exterior conversion. When he did that he also did 16+ facelift headlights and taillights. The taillights work great as they are a kit from Europrice. I am reaching out to see if anyone would know How the wiring would be for the facelift front lights. The lights are EURO without the orange and LED not Matrix. Passenger side headlight does not turn on when you turn the lights on, Only the DRL and Turn signal works. The Bright also don't work on either headlights. The drivers side light does turn on. I did get correct coding and it did not change anything. Its tough because the previous owner already tired to wire this up so it doesn't not have the factory plugs and wires in the factory places. I also have fan faults. I did open the lights to see if they have fans and they DO NOT. We have pre and post facelift wiring diagrams, but its still not helping much. Thank in Advance. I did send CMG_R a PM to see if he can help out.
    May 10 2007
    CHICAGO
    Apr 04 2017
    10 S4, 01 S4, 14 328d
    Chicago IL
    Was this car also red sometime in the last 2 years? As a last resort you could try zworks. They recently did some work for me. He's not timely in the least, but if anybody around here is willing to figure out your lights without asking you to buy all new it's probably him.
    May 10 2007
    CHICAGO
    Nope never been red. This is the Original color and he kept it the same. Ok thanks for the option, I will look into him.
    Veteran Member Three Rings eurospek's Avatar
    Mar 15 2008
    Chicago
    Was this a Midwest car? Done by A&L?
    Jan 31 2009
    2016 RS7-P
    It looks like Fast4Door's conversion but his was a 2013 and I don't remember him doing the facelift headlight change. High beams probably won't work because of the auto high beam function in the facelift LEDs needing different electronics.
    Not that I would do it myself but the chinese conversion lights for pre-facelift cars would probably be easier to deal with. https://www.ebay.com/itm/Full-LED-He....c100009.m1982
    May 10 2007
    CHICAGO
    Yes it’s a local car that was done by A&L years back. It’s not Fast4Door’s car. It does look the same though. The high beams makes sense. I wasn’t sure it if wasn’t working because the headlights have no fans in them. Thanks for the info.
    May 10 2007
    CHICAGO
    Bump! Just in case anyone else had any ideas. Thanks!
    Established Member Two Rings vrod's Avatar
    Oct 02 2018
    Germany
    What did it have before? Full led’s or hid’s?
    Dis you try to swap control modules between the headlights? That would tell you if a module is done.
    Wiring diagrams can be found with elsawin.
    Established Member Two Rings Sima-Koya's Avatar
    Jun 15 2020
    Serbia,Belgrade
    Most likely he needs parametrization on headlight modules to work correctly.
    Contact:
    Whatsapp : wa.me/381653086899
    Telegram : https://t.me/simaservis1108
    Phone Number : +381653086899
    MHI2 / MIB2 / MMI 4G
    Maps update / firmware update / Android Auto / Carplay
    May 10 2007
    CHICAGO
    Car had Full LED Headlights oem But its a 2014 car. I guess the harness has 16 pin which went into the old headlights but these new euro headlights have 14 pins.
