Results 1 to 12 of 12
    Aug 18 2020
    Sonoma, CA
    Liqui Moly engine flush?
    Considering using this in my kids A4 2.0. It has about 196k on the clock. Is this a bad idea. Just don’t know enough about the last 194k miles to have good feel of maintenance done other than it was mostly dealer serviced. Would like to remove any sludge as safely as possible but don’t want to risk clogging the oil pick up screen. I will do another oil change soon when he is home for the holidays and will be using Liqui Moly 5w-40. Will be the second time changing oil on this car and only about 3k miles on it.
    Veteran Member Four Rings KMPRSSD's Avatar
    Dec 19 2010
    E10 2002tii, 2010 VW Touareg Lux Limited
    Connecticut
    I used this on my Touareg that I bought with 50k on it. Didn’t have a real solid history on it. I ended up flushing and draining it. I then dropped the pan and cleaned the pickup. Not sure how hard that would be on a 2.0t
    Powered by iPhone using Tapatalk
    ll B8.5 S4 l 6MT l IE STG ll SP l Daytona Grey w/ Magma l Sport Diff l Black Optics l B&O l AWE Touring w/ non res DP l 19" AG M590 l Luft-Technik Intake l P3 Gauges l EuroCode SS l RS4 Grille l Carbon Valance l DeAuto Fogs l RSnav ll
    Dec 25 2017
    Sweden
    I have used it on my A4 with no adverse effects.
    I have used similar formulas on my previous cars, with no adverse effects. Also used lamp oil. It’s all been fine.
    I do an extra filter and oil change using a cheaper oil and filter so I drain it twice essentially to get it all out before filling a premium oil.
    Feb 15 2016
    Cambridge,Ontario
    I think it wont have anyb adverse affects. But I also think it's a waste of time and money. But if it will make you feel better, go for it.
    Regular oil changes is all it needs. Modern oils and fuel have detergent in them.
    Dropping the pan on this model is a non starter.
    Sent from my SM-G973W using Audizine Forum mobile app
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Senior Member Three Rings rlopez's Avatar
    Nov 09 2006
    Porche, AudiA42.0T (6M), Sport Suspension
    Denver Colorado
    Did this on my A4 a few months ago with 150K miles on the clock
    RLo
    Formula 1 window tint Premier Series, RS4 Reps, PSS9s, Velocity Snub Mount
    Aug 18 2020
    Sonoma, CA
    Quote Originally Posted by rlopez View Post
    So how'd it work out?
    Nov 18 2020
    fl
    Quote Originally Posted by AudiB720TS View Post
    what is that considered straining the cars oil with using wasting oil and filters. i can see the oil actually no i cant see the oil and i def cant see the disposable one time use filter. its like a mask ppl wear for the day/hour and throw them away
    Nov 21 2014
    Montreal
    Quote Originally Posted by audilover3 View Post
    It's like you stealing a turbo and not paying for it.
    Dec 25 2017
    Sweden
    I’m too stupid to understand what you are trying to tell me.
    Feb 15 2016
    Cambridge,Ontario
    don't worry, hes too stupid to tell you what he is trying to tell you
    1976 Yamaha XS 360
    Nov 09 2006
    Denver Colorado
    didn't notice a difference in performance. If it cleaned the inside so be it.
    RLo
    Aug 04 2020
    Denver Colorado
    I used it when I bought an '04 A6 2.7t a few months ago. The crankcase breather system was shot and there was a lot of dried up oil in the hoses. I thought it would be a good idea to try something to clean up sludge.
    Followed the instructions carefully and had no problems after. Can't really tell how much good it did but nothing bad happened.
