Results 1 to 10 of 10
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Evap readiness failed/incomplete
    I posted this yesterday in the c7 forum but no responses yet. I know this one is quite a bit more active for the 3.0T so figured I’d try here too.
    So I had my car tuned just about a month ago, and have driven about 900 miles since then, mostly slow commuting with maybe 75 highway miles mixed in. Out of curiosity I checked readiness with vcds about a week after tuning and everything was ready except evap, I did some quick reading and found that evap can take some time to show readiness so I didn't give it too much thought. I checked again yesterday, and sure enough, evap is still showing "failed or incomplete." Most of my drives are short, I've probably only done 3-4 trips since the tune that truly got the car to full operating temp (i.e. oil temp above 180ish) but I do commute about 5 slow miles, 5 days a week so it has had many on/off cycles. The last few weeks have been fairly chilly, somewhere in the research I did I thought I read that there have to be a certain number of on/off cycles over something like 39 degrees F which if true, that could be part of the issue. Full vcds auto scan shows zero codes.
    Tune is APR stage 2, my understanding of their tunes is that they do not alter the emissions system, and frankly if they did I'd expect to fail readiness on catalyst or o2 sensors. Is it common after a reflash to take this long to show evap readiness when everything else showed ready within a week or less? should I be concerned? I am not up for inspection until next July so I have time to figure this out.
    From VCDS:
    Readiness Status: 0000 0100
    Exhaust Gas Recirculation: Passed
    Oxygen Sensor Heating: Passed
    Oxygen Sensor(s): Passed
    Air Conditioning: Passed
    Secondary Air Injection: Passed
    Evaporative Emissions: Failed or Incomplete
    Catalyst Heating: Passed
    Catalytic Converter(s): Passed
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Veteran Member Three Rings awwturbo's Avatar
    Mar 22 2012
    2009 BMW 328i Xdrive sedan, 2010 Aprilia RSV4 R
    Northeast USA
    I find it takes a while to set especially in the colder weather (winter time). You will need to have at least 1/2 a tank and it needs to go through a proper "drive" cycle. Can't remember the proper process for drive cycle but you can google it.
    [2012 Audi S4 Prestige | S-tronic | Moonlight Blue | Black Nappa Leather | Sport Diff | Titanium Package]
    Mar 05 2016
    Here is the full driving cycle
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by TC_S4 View Post
    Wow that’s specific. It’s been a month and about 1,000 miles as of today, checked after running some errands again today and evap still failed/incomplete. I’ll just keep driving it and hope to have that cycle done by next July when I need a sticker lol
    Mar 05 2016
    Quote Originally Posted by 2k16A6 View Post
    Knowledge is power😁. You can drive all day long, if you don’t hit that sweet cycle, it will never be ready. From where I live, it doesn’t required emission readiness. I just do it for the fun of it, once you complet the cycle and you see emission ready, it’s satisfying 😌
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Yeah I knew there were certain conditions that had to be met, but I’ve generally read that 1/2 to a full tank of gas worth of normal driving should clear everything up. Didn’t realize there was such a specific order of operations. Actually given how specific the conditions are it’s amazing that your average driver ever hits it without trying to.
    Appreciate the info!
    Veteran Member Four Rings B72.0T's Avatar
    Dec 18 2009
    2015 Q7 TDI S-Line Prestige, B8 S4 6MT
    Pennsylvania
    Try clearing your codes even if you don't have active CEL. Then get on the highway and drive 120 miles straight.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by B72.0T View Post
    No codes (full vcds scan), no lights, only way I can see anything is checking readiness, all is green except evap.
    May 20 2013
    california
    In CA you are allowed to have the evap readiness monitor showing not ready/failed and still pass. May be the same where your located.
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Quote Originally Posted by 65efi View Post
    I searched around a bit for what is allowable in MA, could not find anything definitive but I did find some document that suggested evap is the only one that is allowed to show not ready, so maybe I’d be fine. Not due for a sticker for like 8 months so I’d imagine I’ll be good by then, I was really just wondering if this could be an actual issue with the car. Since there are no codes or anything else, I suppose I’ll just check periodically and try to do the drive cycle next time there’s a warm day when I can get to an open bit of road so I’m not forced to stop at a red light and restart the sequence.
