Results 1 to 11 of 11
    Dec 10 2020
    California
    2014 Audi A4 2.0 exhaust setup
    Recently got a 3inch Vibrant resonator done but want it to be louder. Any suggestions to make it louder?
    May 12 2017
    Remove the resonator.
    AKA: hcuorG
    Junior Member Two Rings
    Oct 01 2020
    ottawa, ontario
    delete both resonators. and if its still not loud enough add a test pipe. thatll prep u as well for most stage 2 tunes
    Sent from my SM-N950W using Audizine Forum mobile app
    Veteran Member Three Rings Stazi's Avatar
    Aug 27 2019
    2012 Audi A4 S-Line, 2019 Jeep Grand Cherokee Altitude 4x4, 2017 Moomba Craz
    Michigan
    Leave the resonator in and instead delete the rear muffler unless you wanna have drone and ricer-like buzzing like a mofo!
    2012 Audi A4 2.0T S-Line
    K04 // IE Stage 3 K04 tune // USP HFC // Becker Cat-back // ECS Intake Pipe (w/modded airbox + K&N) // ECS Luft-technik FMIC Intercooler and pipe kit // GFB VTA // RS mesh grille // CF M4 style spoiler // ST rear sway bar.
    Active Member One Ring reeseth21's Avatar
    Jul 12 2020
    Wisconsin
    I have a mk 7.5 GTI that’s stage 2, very similar motor, and I run a catted high flow Downpipe (CTS) and a 3 inch exhaust with only a resonator (Borla type s). Honestly for the noise output it creates the drone is not bad at all, it is noticeable but not bad. The car is very loud, ecspecially on cold starts. However, these motors are known for having that deep buzzing sound around 2k-3k rpm and it is really hard to not drone during that range. Anyways that’s my setup.
    Feb 15 2016
    Cambridge,Ontario
    delete it all, then you could be extra obnoxious.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jun 04 2016
    A
    Quote Originally Posted by Stazi View Post
    have you tried that?
    That's interesting though.
    I've deleted both resonators previously and loved the sound. But there was an obnoxious tin can Honda drone that appeared 1/3 of the RPM and disappears.
    (best bang for buck exhaust mod IMO)
    Ive now gone quad AWE and its too quiet and unhappy with it.
    Dec 10 2020
    California
    Thinking about adding a downpipe or test but I’m from California
    May 12 2017
    I'm not sure why you added a resonator if you wanted it louder. Remove the resonator and just add straight pipe. Or buy this: https://www.ctsturbo.com/product/cts...4-a5-downpipe/
    AKA: hcuorG
    Senior Member Two Rings BradyBoi55's Avatar
    Apr 19 2020
    1994 Ford F-150, 1931 Ford Model A, 2007 BMW 650i
    Manchester/NH
    Instead of spending all the money to delete use a exhaust cutout. You can open and close the valve from the cabin and it works great!
    Apr 19 2020
    Manchester/NH
