Originally Posted by
sthulin
I just wanted to say you've done some great work here and really presented a few options for the community. Can you talk about the install process a little bit? Inside the enclosure, is it clips that need to be cut off to get bare wires? It also looks like you had to put a ring of foam around the edge to seal things off?
Sorry I missed your question earlier. For the most part the upgrade is pretty straightforward. The factory woofer screws into the enclosure with four torx screws and then it just falls out. Depending on which woofer you need to install, you may need to dremel out some of the structural webbing inside the enclosure under the magnet. The Ampire Bold pretty much drops in, but it's not a great match for this box and the upgrade will be minimal. The Skar requires some pretty significant box modifications including enlarging the opening slightly, removing all the structural ribs behind it, and even then you'll have a gap on the top side you'll need to fill with thick foam tape. Mortys66 told me you can heat up the plastic on the back with a heat gun a little and deform the box outward with the woofer magnet to get more clearance. Wiring is simple, just connect the new woofer the same as the old woofer. If you are B&O you'll want a woofer with two 4ohm coils, and if you are on the standard system you'll want the same thing, or a single voice coil 2 ohm woofer.
Always put some poly fill inside the box. That helps a lot.
The port modifications I'm doing now are a TON of work and I don't recommend anyone undertake them lightly. I'm just doing that to see how good I can make it. So far I'm still on my original assertion that an under seat powered sub is going to be a better solution for just about everyone that wants to keep the stock look.
