I just finished an upgrade on my own subwoofer this summer.
The route I chose to go was to dismantle a JL Audio CP108LG-W3v3 powered 8” subwoofer box. I chose this mostly because of having one sitting in my garage. But after completing it, I really love to sound so I would recommend it if you feel the price is okay. Check out eBay for a good deal. It’s 4 ohm but it isn’t a problem because I also utilized the built-in amplifier.
To keep the install cheap, I took apart and cut up my factory subwoofer. I used the plastic frame as an OEM fitting ring. I hate cutting factory wiring, so to get the signal from the factory radio, I cut the connector off the factory sub to use as an adapter to tap into the output of the Bose amp. By cutting the ends off one side of an RCA cable, I was able to solder it to the now loose connector from the old sub and then run to the JL amp.
For placement of the amp, I decided to store it where the Sirius radio unit is stored in the trunk. It meant cutting up the frame a good bit but the placement is great for heat dissipation since there’s a large cavity behind it and the carpeting panel is vented. Check out the pictures and feel free to PM me if you want more details.
Sent from my iPhone using
Audizine
