Results 1 to 6 of 6
    Junior Member Two Rings dbetter's Avatar
    Jul 16 2019
    2002 A4 Big Turbski, 2005 Audi S4, MK4 VR6 Wagon (sold), MK4 TDI (sold)
    Grand Rapids Michigan
    Question Steering angle calibration not working
    After a few months of having no speedo because my ABS module failed, I finally got around to replacing it, matching the part #0 265 950 012. Now after recoding the module and taking it for a test drive, I still cannot get the steering angle calibration to work. I've done the following procedure with no luck:
    [Meas. Blocks - 08]
    Group 005 Field 1 (Steering Angle Sensor -G85-)
    Specification: 0.0 °
    Tolerance (when straight): ±5.0 °
    [Done, Go Back]
    [Login - 11]
    Enter 40168
    [Do It!]
    [Basic Settings - 04]
    Group 001
    [Go!]
    [Done, Go Back]
    [Fault Codes - 02]
    All fault codes should have disappeared.
    [Done, Go Back]
    I've driven the car around as I read that could solve it, nothing yet. Also, my steering angle is stuck at -2.5°, which ross tech says: "Some of the Bosch 5.7 modules will not show live Steering Angle Sensor (G85) readings after the Login and Coding are performed. If this is the case -2.5 ° may be stuck in Measuring Block 005 and will not change when the wheel is turned. Make the wheels as straight as possible and continue with the Steering Angle Sensor (G85) Calibration."
    Any help is appreciated, I know my steering angle sensor is good, as it was working fine before the module replacement.
    -Built B6 A4 Quattro 1.8T, GT35R, 6 Speed Swapped 02X-GVE
    Jan 24 2010
    Paramus,NJ USA
    How do you know that the sensor or calibration is not working?? IIRC there are more steps to this. The car needs to be driven in a straight line at a certain speed iirc.
    Ziddy Autowerks
    Jun 12 2014
    2002 Audi A4Q (B6) 3.0 6MT; 1999 Mustang Cobra; 2003 G35 Coupe 5AT
    Tampa FL
    I seem to recall some part of the procedure where you turn the steering wheel right then left...
    I think the shitty Bosche units are only in the 2002-2003.5
    Try this:
    https://forums.ross-tech.com/index.php?threads/12602/
    https://www.audizine.com/forum/showt...nsor-procedure
    2002 Audi a4 B6 Q 3.0 6MT
    Jul 16 2019
    Update: FIXED!
    Every time i tried recoding the module, it would never save my coding, and the module kept saying "No response from controller" when closing the controller after recoding. I decided to try and change my WSC (workshop code), from 03325, to 12345, and for some reason, it started reading steering angle again. Took it for another drive, traction light went off, then the ABS light when off, and all seems to be working fine now. Not sure how the WSC would cause something like this to happen, but I'm not mad about it lol.
    Jul 03 2010
    1988 Merkur XR4Ti, 1986 911 Coupe, 1991 Alfa Romeo 164
    New York
    Quote Originally Posted by dbetter View Post
    I agree, that's kinda weird. But I admit I don't fully understand how that stuff works.
    Only thing I can add is that when I've re-programmed a couple ABS modules, the whole thing with turning the steering wheel with the engine off to re-calibrate the steering angle didn't really seem to do anything. I think I re-programmed one or two without even bothering to do that step and it didn't seem to matter. <shrugs>
    Brad 2002 Quattro 1.8T w/ 2.8 B5 5-speed
    Jan 24 2010
    Paramus,NJ USA
    I have seen WSC affect different functions in certian control modules. Most of the time modules just needs to see a different WSC.
    Ziddy Autowerks
