Hi all,
I know everyone is probably tired of seeing oil pressure threads for 2.0 TFSI, but my 2007 quattro is acting weird.
The oil was freshly changed, and the other day when the engine was hot, I got the red oil pressure message. I immediatly shut the engine off and parked the car, oil level was fine so I restarted, and the light was off for the rest of the trip.
A few days later, I got the message again and did not bother too much, as it did the exact same thing. Same thing happened today, right before the end of a ride.
There is no pattern as to when the message appears, except for the fact that the engine was hot each time (but it does not happen every time the engine is hot tho).
I know for a fact that some oil is dripping from the oil filter, I’ll try to see if the seal was incorrectly installed.
I was thinking that the issue is probably not an oil pump or a clogged pick up tube, as when I stop the engine for a minute before I restart, the warning is gone. Is it realistic to say that oil from the oil filter is causing the message by dripping on the oil pressure sender connector?
Any insight is welcome!
