Results 1 to 40 of 40
    Jul 18 2020
    Mechanics Tool Set Recommendations
    Hey everyone,
    I’m looking to pick up a starter tool set to be able to work on my car (B8 avant) down at college. If anyone has recommendations for specific tools and tool/socket/bit sets, it would be greatly appreciated if you could drop a comment.
    Veteran Member Four Rings Spawne32's Avatar
    Nov 20 2016
    Aside from a regular mechanics tool set you can get basically from anywhere (check slickdeals as alot of them are on sale this time of year) some specialty tools you will need will be triple squares, and torx sockets. Power tools also help.
    Nov 20 2016
    https://www.lowes.com/pd/Kobalt-232-...est/5000183119
    This kit is a little heavy on the 12 points but its got alot of stuff you need.
    Jul 18 2020
    Quote Originally Posted by Spawne32 View Post
    For the triple square and torx socket I’m assuming you’re referring to the bit sets? I found some 10-piecers that seem to do the job
    Nov 20 2016
    Quote Originally Posted by Christianmacart View Post
    Something such as this
    https://www.amazon.com/LISLE-27200-T.../dp/B0002NYBZU
    and these
    https://www.amazon.com/Titan-16138-S...e%2C173&sr=1-5
    It is helpful to get low profile first because of how many odd ball bolts wind up in tight spaces.
    Jul 18 2020
    and these
    Got it, thanks for the recommendation!
    Active Member Four Rings Nano909's Avatar
    Jul 25 2016
    California
    Ross Tech VCDS. You'll save LOTS of money with it.
    B8 A4 S-Line | quattro | Ibis White
    Boss500 Kit | Custom WPT Big Turbo Tune
    Rev9 IC | Fuel-It E Sensor
    Macan 345mm Front Calipers | S5 Rear Calipers | EBC Reds
    S4 Rear Valance | S4 Exhaust | RS4 Grille
    My Porsche Macan BBK upgrade thread: https://www.audizine.com/forum/showt...-on-B8-B8-5-A4
    Jul 25 2016
    California
    I didn't have special tools at first and did mostly everything with a regular set of wrenches, ratchets and sockets. Eventually I learned I needed torx tools so I bought a set of torx keys (like the Allen keys) at Autozone that hasn't failed me. You don't necessarily need specialty tools but they do make the job easier. You do need a Ross Tech cable though to be able to diagnose and work on your car without hitting up the dealer.
    Veteran Member Three Rings Iceman502's Avatar
    Nov 12 2017
    Pioneer 202 Islander, 2014 Q5 P+, 2013 S5 P+
    Raleigh, NC
    If you don't have one in your spare tire kit, a wheel hanger is always nice to have (or pair), just makes it a lot easier if you're doing your own tire rotations, suspension, or brake work.
    https://www.amazon.com/gp/product/B0...&psc=1&fpw=alm
    It's good to have a torque wrench too. Wheels get torqued to 88 ft-lbs so something with a ~25-100 range can do pretty much anything on the car. For smaller hardware you might want one with a 1/4" drive/lower range if you're particular about that stuff.
    2012 Audi A4 P+, S-Line, ZF - IE K04 - Totaled
    2013 Audi S5 P+, DSG w/Sport Diff - EPL 3.125PR E40
    2014 Audi Q5 P+, Reman CPMB - Daily
    Nov 20 2016
    Quote Originally Posted by Nano909 View Post
    Actually, a OBDeleven device is way better for someone on a college campus. I keep one in my car wherever I go just in case.
    Jul 25 2016
    California
    How so? I know college kids have laptops so I don't think that would be the issue. $199 is a great price for one of the best diagnostics tools for our cars.
    Jul 18 2020
    I’m sure I could figure out either system, cost is honestly the most important thing currently as I don’t have much disposable income.
    Jul 25 2016
    California
    OBD11 is cheaper and does some of what the Ross Tech cable does. I guess it's a bit more cost effective.
    Jul 16 2018
    Atlanta
    My growing complaint with OBD11 is the structuring of the DTC and vehicle information. OBD11 users post something and think it's an informative DTC, yet it's missing 60% of the information that would have been there in a copy/paste from a VCDS log.
    Take this thread. "what's the DTC"? From OBD11, we get "Fault b200049 Static". While a VCDS autoscan log would have:
    Address 44: Steering Assist (J500) Labels: 8K0-909-144.clb
    Part No SW: 8K0 909 144 G HW: 8K0 909 144 B
    Component: RCEPS H40 0508
    Revision: 00001000 Serial number: 0015589422
    Coding: 100000000001
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_RCEPSAU48X 008015
    ROD: EV_RCEPSAU48X.rod
    VCID: 35614D929407E5969D-8060
    1 Fault Found:
    0770 - Internal Control Module Memory Check Sum Error
    B2000 49 [137] - Internal electronic failure
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 8911 km
    Date: 2015.06.13
    Time: 02:44:23
    I get the module address, module part number, module coding if any, DTC date, etc.
    Or they post screen caps of basic text. I don't have OBD11; I do wonder if there's a better way to log the vehicle scan and users are just not leveraging that aspect because the tool does not take them there by default?
    All the info is probably there in OBD11, but you're going to have to find it and compile it to match what VCDS produces on its own.
    As to tools, kind of depends on the component at hand. As soon as you need to replace a door handle sensor if you have advanced key, you're going to want long shaft Torx bits. If you're doing any interior work, you'll want trim tools; I've made a lot of use of https://www.amazon.com/gp/product/B07DD6ZPYV swivel sockets, obviously metric, have come in handy from time to time (removing cat from turbo, etc). Torque wrenches, from the small 1/4" to the big (relatively) 1/2". I've built my collection as a I go, as I tackle each new task. Same as I did with my Probe back in college. Otherwise, you could prepay on a lot of tools one could use, but which you won't in a college parking lot.
    Sep 03 2014
    2014 Audi Q7 Premium Plus, 2014 Audi A4 2.0T Quattro S-Line
    Ellicott City, MD
    For a college kid on a tight budget, Harbor Freight is your best friend. You don't need VCDS or OBD Eleven for basic maintenance tasks. You only need them to diagnose serious problems which would probably be outside of your budget to repair anyway. They're great tools to own, but they're not something you would get as part of a starter tool kit. Just get some basic sockets and wrenches. I prefer the impact sockets from Harbor Freight because they grip the bolt and nuts better (6-point vs. 12-point) and are nearly indestructible. Get one of those cheap 4-way screwdrivers. Two things that every metric socket and wrench set leave out are 16mm and 18mm sizes and cars always seem to have fasteners in those sizes. I believe a 5/8" socket or wrench is essentially the same as 16mm so you can easily substitute the 5/8" tool. A couple of socket wrench extensions can come in really handy for those hard to reach spots. Torx and hex bits for a 3/8" socket wrench are also nice to have on hand. A pair of vice grips, adjustable wrench, and needle nose pliers are good to have as well. Beyond what I've already mentioned, you start getting into more specialized tools that may only be required for specific tasks. A 3/8" socket wrench will handle most tasks. A 1/2" drive socket wrench is almost a must for any suspension work. A 1/4" drive socket wrench is nice to have on hand, but you probably won't need it that often. You can get a decent torque wrench in both 1/2" and 3/8" drives at Harbor Freight and they go on sale all the time.
    Just get the basics and add what you need as your budget allows. As was suggested earlier, you can pick up complete mechanic's tool sets pretty cheap this time of year that should contain most of what you need. One tool that I really love that Harbor Freight has is a telescoping magnet for retrieving dropped parts in tight places. I think they were only about $1-2 when I got mine, but they have one now with a 15-lb capacity for about $5.
    Feb 15 2016
    Cambridge,Ontario
    you wanna fix a vag product ?? get a set of torx and triple square ( XZN) bits for a 3/8 drive ratchet.... on top of your regular tools.
    i also have a set of allen keys that are torx that are nice that i use often.
    but my real advice ?? if your a college kid on a tight budget ? dont own a B8.
    2014 A4 2.0TQ Technik Manual
    2006 A4 2.0TQ Manual
    1978 Porsche 911SC Targa
    1976 Yamaha XS 360
    Jul 18 2020
    Very good point. Thankfully it’s all paid off (parents are passing it down to me) and I’m nearly graduated but it’s definitely not the cheapest option. 62863841214__159B4D50-99E4-4CFB-B90F-D370268B276A.jpg
    Jul 25 2016
    California
    Quote Originally Posted by captain_video View Post
    I highly disagree. You can't remove the service light without it. Indy shops and dealers charge $50-$90 just to diagnose and remove a light. It is quite literally something you need with these cars.
    Sep 03 2014
    Ellicott City, MD
    LOL, I have VCDS and I still get the service reminder. I'm just too lazy to drag out my laptop to turn it off. While I agree that you do need it for certain things on occasion, you can still get by without it if you don't mind a few minor annoyances like the service reminder popping up each time you start the car. It disappears after a few seconds so it's no big deal. The OP is looking for a starter set of mechanic's tools with the emphasis on "starter set". While many may deem it a necessity for working on Audis and VWs, there are a lot of basic maintenance tasks that can be performed without it. It's definitely something any mechanic should have in their toolbox to work on these cars, but it's not something you'd necessarily have to invest in right away, especially if you're on a tight budget. You can buy a lot of tools for $199. It all depends on what kind of maintenance the OP plans to do and what he is capable of doing. It's also a matter of priorities. Do you want to buy a set of hand tools to actually do some work on the car or blow it all on a diagnostic tool that tells you what's wrong and leaves you with no way to fix the problem? I know what it's like to live on a college kid's budget so you have to get your ducks in a row and decide what you need vs. what you can actually use.
    Veteran Member Four Rings Novarider's Avatar
    Jul 02 2017
    Knoxville TN
    How will he figure out what's wrong without diagnostic software? You can't fix what you don't know is broken.
    2011 A4 Avant Prestige S-Line
    Jul 02 2017
    Knoxville TN
    Here is another starter tool set. I'd get Husky over Kobalt simply because Lowes is killing off the Kobalt line and replacing it with Craftsman. Not happy at all about that at all, I have many Kobalt tools.
    https://www.homedepot.com/p/Husky-Me...0MTS/309161789
    Feb 15 2016
    Cambridge,Ontario
    im a craftsman guy because of the lifetime warranty . , but to be honest i have had some of them over 40 years and never needed the warranty once, ever..
    oh wait once, i had a ratchetting 10mm that would bind ....
    1976 Yamaha XS 360
    Apr 20 2019
    Coloarado
    Look for the Christmas sales at Home Depot. My Husky stuff is good enough and has lasted me years. Cheap vs expensive tools are only going to matter when that bolt is stuck as hell or in a tight space. Luckily this is an Audi so there is none of that
    But seriously craftsman or husky will do you fine. On sale they are usually better priced than HF stuff.
    Senior Member Two Rings schwiz23's Avatar
    Feb 22 2020
    Burnsville, MN
    If you're on a budget, look on craigslist or fb marketplace for a used set of metric tools. SAE is less important. After that, find your specialty torx and triple squares. Both can be had on Amazon for ~$30 together.
    10 years ago I went to a buddies estate sale he put together for his dad that passed away. Scored a huge set of craftsman tools, box, and a starter set of power tools for $150. Wheel and deal where you can if you're on a budget.
    '15 A4 S-Line Premium 6MT - Hybrid K04 - APR Tune - ECS FMIC & Alum. Charge Pipes - IE HFC/Downpipe - S4 Quad Tip Exhaust Conversion - Android 10.25" Carplay Retrofit - S5 19" Wheels
    Jul 25 2016
    California
    Quote Originally Posted by Novarider View Post
    Feb 15 2016
    Cambridge,Ontario
    this is getting better than an oil thread ...
    for the record i have VCDS ... but i did without it for over 20 years of owning Audis ... I really only got it to make some tweaks ..
    the stark reality is a lot of what breaks on these cars you dont really need VCDS , but its a very nice to have and i enjoy playing with it. there are other tools that will do 80% for just a few bucks. But as i said im glad i have it. i have used it to fix zero problems on my car.
    uses a ton of oil , water pump leaks, valve cover leaks, oil leaks galore, bad stats, leaking coolant flanges, dead starters, bad alternators, blows out cv joints , sagging suspension, cracked mufflers, leaking flex joints. All very common car or Audi issues that don't need VCDS or ANY diagnostic tools to resolve and keep you on the road driving an Audi or any other car ...
    I would say hold off on it till you need it ... you may never need it. or at least can put it off a while ..
    1976 Yamaha XS 360
    Dec 28 2006
    '13 A5, '24 Tiguan SEL R-Line
    Western Maryland
    I also have VCDS. I bought it when I purchased my new 2003 A4 and have used it ever since. but to be perfectly honest, 99% of the time I get my information utilizing the $5 TorquePro app on my cell phone. You can read/reset codes and monitor numerous different preloaded PID's in real time. You can even add additional custom PID's if you like. It's probably the most useful tool you can get for $5.00
    Jul 18 2020
    I think I’ll hold off for now, my primary goal is getting the damn thing to run again. I snagged some 034s motor mounts and an 034 hfc so I’m
    Gonna start with those two (and obviously the new engine).
    I’d love to go the whole K04 route but for now a boy can dream
    Jul 25 2016
    California
    Baby steps man. First thing to do before mods is all your maintenance.
    Veteran Member Four Rings CONative's Avatar
    May 06 2015
    B8 A4 Avant / Subaru Outback Limited / Honda Odyssey
    +1. Some of the best advice on this forum.
    Cheers,
    Ry-man
    Sep 03 2014
    Ellicott City, MD
    I'm pretty sure that most basic maintenance tasks don't require diagnostic software to know what's wrong, such as replacing brake pads and rotors, control arms, oil changes, or just about anything mechanical. Diagnostic software is a must if you have engine problems or anything reporting an issue to a black box. You really don't need VCDS unless you get some kind of warning indicator such as a CEL. The one task that you need it for is to replace the rear brakes if the car has an electronic emergency brake, but there are workarounds for that too. Audi makes these cars far more complex than they need to be when it comes to maintenance so I wholeheartedly agree that VCDS should be a necessity when doing any serious maintenance. You can just get a cheap OBDII reader for most engine problems. If you have issues that are non-engine related then you will need VCDS for those.
    Veteran Member Three Rings SNice's Avatar
    Aug 06 2019
    Philadelphia
    Agreed on baby steps but If you are installing an HFC, you will need something that will allow you to read and clear codes. The HFC will pop your check engine light. The reader/clearer will help you land on a spacer that will prevent the check engine light.
    I have obdeleven. It has worked well for me and I would purchase again as it is not too expensive, portable, and quick. You just need to run it on a phone or tablet with internet/data as it needs to be on the network to run. In the beginning, I used it to monitor temps, etc. and any present faults. Now I use it for logging as I have changed major components and I need to make sure I don’t blow anything up. I have thought about upgrading to vcds, but I’d rather spend the additional fund on other things.
    YouTube and these forums have been my best resource - there’s videos on almost anything you would need to do. Watch the vids to figure out what tools you need to get the job done. The right tools make all the difference. I started with a small basic mechanics toolset. I’ve ordered unique vag tools as needed. Just try to have all the tools you need before starting the job!
    It’s gonna get expensive. Plan and have a budget. Have fun and enjoy the car!
    2014 A4 B8.5 - AUDI _ EFR 6758 / WPT Stg. 3 Flex-Fuel TUNE / WM Injection / Custom HFC / JHM D-Pipe / AWE FMIC & EXHAUST / APR INTAKE / KW V3
    2002 SV650 - SUZUKI
    1989 nt650 HAWK GT - HONDA
    1972/4 r5/rd350 Hybrid (WIP) - YAMAHA
    1971 r5 350 (basket case) - YAMAHA
    Jul 10 2015
    Colorado
    Quote Originally Posted by Smac770 View Post
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Mileage: 8911 km
    Date: 2015.06.13
    Time: 02:44:23
    Smac,
    I think that what you are seeing posted from OBD11 is user error. Following is a recent log that I emailed to myself through OBD11. It has a lot more info. Also, what turns me off on VCDS is that they limit the vins. I have a revolving door of Audis at my house. I'd use those up in a few months.
    OBDeleven data log
    Date: 2020-11-06 16:48
    VIN: WAUBFAFL2BN040808
    Car: Audi A4
    Year: 2011
    Body type: Saloon
    Engine: CAEB
    Mileage: 192410 KM
    01 Engine
    System description: 2.0l R4/4V TF
    Software number: 8K2907115AG
    Software version: 0002
    Hardware number: 8K2907115D
    Hardware version: H19
    ODX name: EV_ECM20TFS0118K2907115AG
    ODX version: 001002
    Long coding: 0104010A290F0160
    Trouble codes:
    P029900 - Turbo/Super Charger Underboost
    static
    Date: 2020-11-05 14:37:03
    Mileage: 192319 km
    Priority: 2
    Malfunction frequency counter: 2
    Unlearning counter: 255
    Engine speed: 3158.00 1/min
    Normed load value: 73.7 %
    Vehicle speed: 60 km/h
    Coolant temperature: 94 °C
    Intake air temperature: 32 °C
    Ambient air pressure: 820 mbar
    Voltage terminal 30: 13.334 V
    Dynamic environmental data: 209628
    Jul 16 2018
    Atlanta
    Yeah, if OBD11 users were posting that log rather than a screenshot or a few words from the screen, it would usually be more helpful. As you noted, it's good to have alternatives for different types of users. So long as the alternatives deliver the same level of diag information; you show OBD11 can produce it.
    Jul 18 2020
    Quote Originally Posted by SNice View Post
    Would you recommend I hold off installing the hfc for now? My reasoning behind getting it now was that I’ll already have the engine pulled and the stock cat has 90k miles on it
    Aug 06 2019
    Philadelphia
    Wow!!! Sounds like you are waaaayyy beyond baby steps! HFC is nothing compared to pulling the engine so completely up to you. But - since you have pulled the engine and have unhooked connectors, etc. - I think it is a MUST that you invest in a device that will allow you to read codes and log parameters. Obdeleven at minimum. Vcds if you are feeling fancy.
    2002 SV650 - SUZUKI
    May 12 2017
    Def put the hfc on if you're going to have the engine pulled. That thing is a huge pain in the ass to install.
    AKA: hcuorG
    Jul 18 2020
    I don’t have much hands on experience with cars but am an engineer and car junkie and I’m hiring a mechanic to help me - thankfully the swap seems straightforward. I’ll give OBD11 a look
    Jul 02 2017
    Knoxville TN
    Quote Originally Posted by kwilson View Post
    Smac,
    OBDeleven data log
    Car: Audi A4
    Year: 2011
    Body type: Saloon
    Engine: CAEB
    Mileage: 192410 KM
    01 Engine
    ODX version: 001002
    Trouble codes:
    static
    Mileage: 192319 km
    Priority: 2
    VCDS allows you to scan cars without using a Vin allocation.
    Jul 10 2015
    Colorado
    Yes, it appears that you can scan any car, but I have auto ADD and am constantly shuffling my fleet. I would soon lose any ability to do more than scan my cars.
