Results 1 to 40 of 61
    Veteran Member Three Rings volvofan's Avatar
    Sep 10 2016
    MA
    List of all OEM Audi Battery Part Numbers and their Amp-Hour & Amperage ratings
    ******DISCLAIMER******
    After more than a few conversations with Antigravity’s tech support staff and their president, we mutually decided that it would be a good idea to put this in the lead-off post here, to address liability concerns.
    If you put an Antigravity (AG) battery in your vehicle and it doesn’t work, even after re-coding your BMCM for the proper size, Antigravity’s “party line” is that you should return the battery to them. Modifying your car’s control systems is NOT an approved or endorsed method of making their battery compatible with your vehicle. If you do it wrong and 1) mess up your car or its systems and/or 2) mess up the battery by operating it outside of its designed and warranteed limits, then neither they - nor I - may be held liable in any way for damage, injury, R.U.D.E. (Rapid Unscheduled Disassembly Events), or other undesirable consequences. If I were you, I would expect the same of ANY LiFePo4 battery manufacturer, so do not treat this disclaimer as though it is exclusive to AG.
    BOTTOM LINE: Proceed at your own risk knowing you ALONE accept full responsibility for the outcome of any alterations or modifications to your vehicle’s stock configuration.
    Wasn't sure which forum to stick this in, so I figured I'd just park the info in the forum I frequent the most due to the vehicle I currently drive, and people will find it if they SEARCH :)
    I installed an Antigravity 60 Amp-hour Lithium battery replacement to shave some weight and free up some space in my not-a-spare-tire well for mounting a subwoofer amp. Yeah, I know, I could have mounted the amp in between the B&O and the satellite radio, but having it so close to the battery made a LOT of things easier. In any case, I had some troubles in that the car was initially providing TOO MUCH juice to the battery. The battery monitoring and control module (aka BMCM, or J367) was showing voltage climbing up to almost 15 volts within the first couple minutes of driving, then things started shutting down to protect themselves (and I think that a couple times the battery's built-in protection may have kicked in, too). In the process of trying to solve this problem, I found that I could change the way the car tried to charge the battery by playing with the Battery Energy Management (BEM) code I inputted into VCDS... if you switch in an Antigravity or other lightweight LiFePo4 replacement, you should probably start by recoding your car with a battery part number that's as close as possible in amp-hours to the new battery. Especially if you're experiencing overvoltage/undercharging problems, re-coding should be your FIRST stop. If you get lucky, you won't have to do anything else! If you don't get lucky... well, just keep reading. It's a long post.
    BACKGROUND - SYSTEM ARCHITECTURE
    On the A5/S5/RS5 (and perhaps some other models as well), the BMCM sits on the negative battery terminal and watches battery temperature, battery voltage, and current running through the negative terminal. It feeds this information back to module J533 (CAN Gateway) via a LIN bus (Local Interconnect Network). Think of LIN like old-school serial communications... sending ones and zeros back and forth over a single 12V line, pulsing it like a telegraph. The J533 processes this info as well as other data from the Engine Control Unit (like RPM, engine load, whether accelerating or decelerating) and other CAN bus users like the central convenience module (to find out if things like the Rear Defroster or seat heaters are on). It mashes all that information together to make a decision on how much juice to tell the alternator to put out. Using another LIN bus line, it talks to the alternator's LIN-enabled voltage regulator to tell it what voltage it wants, and the voltage regulator adjusts the alternator accordingly to put out the requested power. All of that communication and calculation takes TIME... and sometimes the car's other components are acting/reacting more rapidly (especially when driving in a "spirited" fashion) than it seems the whole loop can keep up. The huge, heavy, non-LiFePo4 chemistry batteries that our cars originally come with act like a gigantic electrical "shock absorber"... sucking up spikes and surges and changes without complaint before the rest of the car's components notice anything is amiss. I believe (though I have a masters degree in engineering, it's NOT in electrical) that the LiFePo4's rapid charge/discharge characteristics end up passing those spikes and surges along to the car's electrical components rather than absorbing them, and/or shutting down because its own internal overvoltage/overcurrent protections are being triggered. Smart car + smart battery = too many chefs in the kitchen, I guess?
    POTENTIAL SOLUTION 1) RE-CODING THE BMCM
    The BEM code that gets put into the BMCM is in three parts, separated by a space between parts 1 & 2 as well as between parts 2 & 3. It must be this *exact* length of 26 characters (11-character part number, 1-character space, 3-character vendor code, 1-character space, 10-character serial number) or VCDS will not accept it. A full code looks like this:
    000915105DD VA0 251016AGRA
    Okay, what does all that mean? Let's break it down.
    1A) BATTERY PART NUMBER.
    All part numbers are 000915105** where the ** is filled in by the two letters below.
    2 LTRS AMP HRS DIN AMPS TYPE (I think?)
    DB 44 220 Conv
    BB or DC 51 280 Conv
    CB 58 340 AGM
    EB 59 320 EFB
    AC or DD 60 280 Conv
    AD or DE 61 330 Conv
    CC 68 380 AGM
    DF 70 340 Conv
    FC 70 420 EFB+
    AE AF or DG 72 380 Conv
    CD 75 420 AGM
    ED 79 420 EFB
    AG or DH 80 380 Conv
    AJ or DJ 85 450 Conv
    CE 92 520 AGM
    EE 93 520 EFB
    AH or DK 95 450 Conv
    CF 105 580 AGM
    AK or DL 110 520 Conv
    DM 115 600 Conv
    MANY other batteries have different series part numbers instead of "000" series... as in, +++915105*. In this case, there is only a single letter after the nine-character sequence. The list below is by no means exhaustive. If you want to use these instead when coding into VCDS, put a BLANK after the letter so you'll have the right number of characters. I've only listed the ones that I could find actual pictures of specs of them in "OEM" trim, although if you search for other letters, you'll find several hits where aftermarket manufacturers have listed their batteries as compatible with those numbers in cross reference. I am currently running a "DE" part number for my 60 AH Antigravity battery... but more on that effectiveness below.
    I think the two-letter suffix in the "000" series was intended to supersede all these other series with the single letter suffix, as it seems to be the most comprehensive list. From here forward, I'll be applying limited effort to updating the list below, only if it seems to offer some novel option not already reflected by a "000" series part number in the list above... those few are indicated by a "^".
    SERIES / LTR AMP HRS DIN AMPS TYPE
    8k0 / C 70 340 Conv
    8k0 / D 80 380 Conv
    8k0 / F 110 520 Conv
    4f0 / B 80 380 Conv
    4f0 / C 95 450 Conv
    4f0 / D 110 520 Conv
    4f0 / E 92 520 AGM
    7P0 / none 68 380 AGM
    7P0 / A 75 420 AGM
    7P0 / D 105 580 AGM
    1S0 / A 59 320 EFB
    5TA / B 70 420 EFB+
    6R0 / B ^ 69 360 EFB
    3D0 / G ^ 85 480 AGM
    3D0 / H 75 420 AGM
    Part number tips: Obviously, you're going to want to select a part number that has as close to your new LiFePo4 battery's amp-hours as possible. It would also make sense that you'd also want to select an AGM (Absorbed Glass Mat) or EFB (Enhanced Flooded Battery) type, as those more closely mirror the charge/discharge rates and voltages of a LiFePo4 battery. In practice, however, I found this resulted in some VERY undesirable behavior. Upon revving the engine, I was immediately seeing some significant voltage spikes... almost like the car was counting on the battery to buffer them, but the AG battery didn't want to play nice with that. You may have different results, but I recommend simply sticking with the "Conv" part numbers... that seemed to keep charging rates and amperages low. Regardless, ALL part numbers are still listed here for the sake of being comprehensive.
    1B) BATTERY VENDORS. As far as I could tell, the only effect this had on the car's behavior was to set a flag in one of the VCDS measuring blocks indicating the battery was "OK" or "NOT OK". What does it do with this information? I have no clue. I did discover that it hardly EVER said a Varta (VA0) battery was "NOT OK" so I pretty much left those middle three characters as "VA0" for the duration of my testing:
    5DO = JFF/Boading
    TU3 = Exide
    MLA = Moll
    JCB = JCI/JCB
    VA0 (or VAO) = Varta
    UM5 = Akuma
    BA2 = Banner
    1C) BATTERY SERIAL NUMBER
    Standard format is DDMMYY of battery manufacture, followed by a four-digit arbitrary alphanumeric code assigned by the manufacturer. You could actually use any ten letters/numbers in here you want... I've had it accept "ABCDEFGHIJ" or "1234567890" with no trouble. The important thing to know is that the BMCM **STORES** the battery codes and histories associated with them according to their SERIAL NUMBERS, not their PART NUMBERS. It keeps up to three of them in its memory, then starts overwriting. How much history it keeps and what types/parameters is stores and adapts for each, I do not know. BUT, if you want a fresh start with a "new" battery, make sure you don't just change the part number... give it a new serial number, too. In the example BEM code above, I pretended that I installed the battery on October 25th, 2016, and I made up serial number "AGRA" for it. Why not? give your battery a "vanity plate". For what you paid for the f**king thing, it deserves one.
    This video from Ross-tech is also super helpful in sorting out the coding process:
    https://www.youtube.com/watch?v=IJAScg6JrYI
    HOPEFULLY, THIS SOLVES ANY OVERVOLTAGE/UNDERVOLTAGE PROBLEMS YOU'RE HAVING, AND YOU CAN STOP READING NOW!
    The above solution (properly re-coding your BMCM for the new-sized battery) is the ONLY ONE suggested by Antigravity. If it doesn’t work, they want you to send the battery back to them. If you don’t, and you instead elect to proceed with one of the solutions described below, you do so at your own risk and assume full responsibility for any adverse outcomes.
    What? Still here? ::Sigh:: modding is never as simple as it seems, right? Have no fear... we're not out of options yet.
    Despite trying a bucket of different codes, I was still seeing the same behavior, over and over again (all found by monitoring the measuring values of CAN Gateway 19). Upon startup, the alternator would start outputting 14.7V. Even at idle without driving anywhere. As the battery voltage crept up to match, the CAN gateway would start dialing up the specified alternator voltage about .1v at a time. When the battery voltage showed 14.5, it would start asking for 14.8 out of the alternator... when battery charged to 14.6, it'd bump the alternator up to 14.9, and so on... by the time the alternator was putting out 15V, the battery decided to say "screw this, I'm outta here." It would get to about 14.75 volts, then would internally disconnect. Shortly thereafter, alternator voltage would drop to 14.3 and I'd lose seat heaters and rear defroster. Sometimes the battery would decide to give it another go and reconnect (in which case the same behavior would repeat) or sometimes it would just stay disconnected until I shut the car off. Driving would result in even more unpredictable behavior. Sometimes it would do the same thing as it did at idle, but other times the alternator would somehow put out a spike in voltage and some of the car's modules (important stuff like the transmission control unit or the MMI) would freak out and reset, throwing up warning lights and beeps and other scary stuff left and right. NOT COOL. If this has happened to you... fear not. Take your pick from the menu of options below, and you'll be all squared away. Depending on your particular model or configuration, you may have to try more than one of these to find the best solution for you:
    POTENTIAL SOLUTION 2) DISCONNECT BMCM. Unplug the two-wire connector at the negative battery terminal. This places the car into a "fallback" mode. Alternator puts out no more than 14.3V, whereas I was seeing up to 15V at idle with it connected. I’ve only taken a couple of drives with the car’s BMCM disconnected, so I can’t say it’s been a comprehensive test, BUT, it does seem to work well. The battery voltage recovers quickly after startup and remains steady at about 14v according to the bluetooth battery tracker in all sorts of driving conditions ranging from “lazy” to “very spirited”, both with and without high-draw devices like rear defroster and seat heaters on. PROS: Laughably easy to do. Fully reversible. Free. No dashboard warnings though it will set a code in VCDS. CONS: You are defeating some of the functionality of the vehicle; this may have other side-effects of which I am not yet aware. Also, only a few Audi models use this separate, directly-on-battery-terminal-mounted BMCM... others have more integrated electrical control units that have WAY more than just two wires plugged into them; disconnecting those systems entirely is not a viable option.
    POTENTIAL SOLUTION 3) DROP OUTPUT VOLTAGE OF ALTERNATOR. Install a high-amperage diode inline with what goes from the alternator to either the jumper block in the cowling under the hood, or from the jumper block to the main fuse block on the positive battery terminal. Not sure which would be better, as I haven't tested this yet. The part is on the way, though, and I intend to. Most diodes will shave off about .7V, which would be perfect in this case. PROS: A "hardware" solution for limiting alternator voltage isn't subject to software reaction time. Retain full functionality of BMCM. CONS: Costs about $25 plus installation time, may have other side effects, inefficient (wastes excess voltage as heat), and reduces alternator output voltage ALL the time (even at lower RPMs when you may not WANT voltage to be lower). BMCM may be too "smart" for this workaround and might increase alternator field current to compensate? EDIT - I think my solution #5 is going to work as desired, so I probably will NOT end up testing this route. If someone would like to try, I have a BFD (Big F**king Diode) you can buy off of me for half price).
    POTENTIAL SOLUTION 4) SPOOF BMCM WITH BATTERY AND DIODE(S). Put a 1.5V (AA, C, D, doesn't matter) battery in series with the voltage-sensing lead from the positive terminal to the BMCM. Add a diode (or diodes) to drop voltage "boost" to the level that gives you the best performance. This tells the BMCM that the battery's voltage is higher than it actually is, as I theorized above. I tested this (using a potentiometer instead of a diode), and it DOES work. Adding about 0.6-1v seems to get the BMCM to tell the J533 module to tell the alternator to chillax and dial back its output voltage. It was a crude test, and I didn't do any driving to see if this solves the problem under all conditions, but it's promising. PROS: Relatively inexpensive, simple, retains functionality of J367 module to adjust alternator load to varying conditions without overcharging AG battery. CONS: May take some trial-and-error to tweak/tune, and the 1.5V battery will need to be changed out periodically. Also, this method lies to your car ALL the time, not just when it’s on. This could have adverse effects on starting or on what the car reads as battery health indicators.
    POTENTIAL SOLUTION 5) SPOOF BMCM WITH ISOLATED DC-DC CONVERTER & DIODES. Same effect as described above... lie to the BMCM. Basically replace the 1.5V battery with an isolated DC-DC converter so it never has to be changed or charged. Found one that steps down to 3.3V, then we'll have to get down to the desired "boost" voltage by adding a few diodes to drop the voltage to whatever works best (again, shooting for somewhere between 0.6 and 1v). UPDATE - the components have arrived and I built the prototype (see pics below). Haven't installed in the car yet, but it works as advertised during bench testing... providing an adjustable "boost" amount to the battery voltage the BMCM sees. SECOND UPDATE - I adjusted the design, because sticking the diodes into the IC socket was giving me an unreliable connection. I ended up going with a six-position rotary switch with five Schottky diodes bridging the six terminals, and two more regular rectifier diodes in series after that. I did this because of both the sketchy connections already described, and it was becoming a pain in the ass to open up the case every time I wanted to try a new combination of diodes. The two rectifier diodes get the voltage stepped down pretty close, then the Schottkys give me fine-tuning capability in about 0.175v increments. I can take battery voltage sitting at 13.2v and adjust what the BMCM sees all the way from 12.9v up to nearly 14.3v. It was dark, cold, and snowing, so I didn't feel like doing any testing after I got everything installed, but it IS working in the car. THIRD UPDATE: Drove today with the voltage boost set at about 0.7v. Worked like a champ. The car kept alternator voltages between 13.8 and 15v, with battery voltages (as measured by the bluetooth battery tracker) staying between 13.65 and 14.3. No electrical hiccups or undesirable side effects, no disabled seat heaters or defroster, and no codes registered in VCDS. Only a short testing window, but so far indicative of success! FOURTH UPDATE: It's now been more than a week, and I've probably driven a hundred miles over the course of 6 or 7 drives. Absolutely no issues whatsoever. Battery starting and charging performance remains exceptional, no codes or errors in VCDS, and no voltage spikes or errant electrical problems. The PROS: retains functionality of J367 module to adjust load to varying conditions without overcharging, no current draw when off, no 1.5V battery to change. CONS: Most complex solution, requires some rudimentary soldering and fabrication skills, costs about $30 in components (DC-DC converter, diodes, relay, enclosure, wiring, board, etc.).
    Original design with IC socket to hold diodes
    Revised design with rotary switch (final configuration of diodes ended up being slightly different than what is shown)
    Revised schematic - added 8-position switch and more Schottky diodes for more fine-tuned control of voltage boost.
    Thanks to @Apefactory and the folks at AntiGravity batteries for a lot of assistance and troubleshooting, as always!
    -Jon
    EDIT - I'm adding a fourth column to the charts... as we hammer out whether these part numbers are conventional (flooded aka "wet cell"), AGM, or EFB, I will list the type. I'll do a google image search for each part number as it seems that Audi/VW labels the top of the batteries with "AGM" or "EFB" if they are one of those, and apparently leaves it blank if it's a conventional wet cell battery.
    SECOND EDIT - this is now done. For the "000" series part numbers, it would appear that if the first letter is "A", "B", or "D" it's a conventional battery; "C" means it's an AGM; "E" means it's an EFB; and "F" means it's an EFB+. What's the "+" for? I have no earthly idea.
    THIRD EDIT - This now contains all the info found in post #12... at least for the "000" series.
    FOURTH EDIT - Reorganized post and added more info about what the car does with the part numbers and serial numbers in the BEM code. Also, posted initial description of potential workarounds in case coding alone doesn't solve overcharging problems.
    FIFTH EDIT - ***IN PROGRESS*** I'll edit this specific post further as I conduct more testing and evaluation on the workarounds. I've only just started static testing, and dynamic testing could take several weeks to try all configurations and monitor carefully for adverse/side effects across a wide range of driving conditions.
    SIXTH EDIT - Added disclaimer at the top after speaking with AG staff about liability concerns.
    Last edited by volvofan; 01-12-2021 at 08:29 AM. Reason: Added/consolidated more information and photos
    2013 RS5 Coupe 57k; slower than an Apache... not by much.
    GO - ECS intake; LWCP / LWFW / FP; Kline headers & exh; HFCs
    STOP - Forgestar F14s; Michelin Pilot Sport AS4; Voshmods rear BBK; CCBs x4
    TURN - ALL the braces; EuroCode sways; PowerFlex inserts; KW HAS; SPC UCAs
    PROTECT - RMR xmsn cooler / bar; ECS shields; JXB bearing; AG battery
    A/V - RSNav S4 10.25"; JL 8W1V3 sub; Alpine MRV-M500 amp; lighted sills/rings
    OTHER - Weathertech; Ziza LEDs; RMR hoses; ALL the carbon fiber
    Veteran Member Three Rings makisupa's Avatar
    Jan 30 2006
    Boston, MA
    Good info, I’m thinking about making the jump to an antigravity battery in the very near future as well. I was going to ask Michel some similar questions! Thanks!
    4.2L CFSA swapped 2013 allroad
    plus a bunch of other crap slapped on there
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    Jon took the time to deep dive into this when I didn't have the time plus I wasn't having over voltage issues like he was. I don' know if it's because of the heat or what down here but I had one incident and at the time, I had an electrical issue as well. I'd chalked it up to that and have run the car pretty hard more than a few times since installing the battery.
    I'll try this today and monitor my voltage as well.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
    Sep 10 2016
    MA
    When I spoke with Antigravity tech support they reported that the few VAG owners who'd had problems during retrofit had the OPPOSITE problem, where the battery wasn't charging ENOUGH. They were having to run their passenger seat heaters full-time in order to tell the car that there was more load so that it would push more juice. I forwarded them this list so hopefully they'll have it on hand and folks can fiddle around with it as they see fit to get optimal performance.
    I will say this... I was hesitant to spend the money on the battery tracker, and only got one because I found a good deal on a used AG battery (had been used for a demo/photoshoot for only a couple of weeks) that came with the tracker. It has been absolutely INVALUABLE for troubleshooting.
    -Jon
    Jun 24 2017
    San Antonio, TX
    Ok...sitting here messing with this. I initially kept my code and just changed DB at the end and that actually worked from a standpoint of it taking the code.
    I have the 40Ah model. While I was messing around with this, I had the ignition on but not the engine for a bit so I drained my battery down to 77%. When I started the car up, everything looks fine initially and then after a few minutes of idling, the voltage kept ramping up to the point where my radar detector read 14.9V and the Antigravity bluetooth battery monitor program read about 14.73 or thereabouts. It stayed there but I decided to turn the car off and reexamine.
    ****Important. I KEPT the three letter middle code for my old battery which was not a Varta. Theorizing that the two letter suffix for amp hours you listed above is battery maker specific. My code had been MLA. So my full BEM was 8K0915105F MLA 130215F9GH.
    The GH at the end is not in your list which I'm assuming now works ONLY with the VA0 (Varta) coding. So Jon's list of suffix letters above may be Varta specific. I'll dig around and see if that is indeed the case.
    I'm now sitting here, car idling, with VA0 in the middle position with DA at the end. Radar detector is showing 14.3V with 14.05V at the battery and holding steady. Actually just dropped down to 13.5V at the radar detector and 13.34V on the battery monitor but my battery capacity reached 80%. I'll have to watch charging with this code too. Now at 81% so not charging super rapidly like these batteries can. Voltage steady at 13.29V on battery meter. I may try some of the other suffixes for higher amps. If I remember correctly, 14.2V seems pretty normal for a voltage reading on the radar detector but I am not 100% certain.
    The test will come once the car is warm and I can go do some hard shift/acceleration runs. I know two other RS5 owners who have that problem when they floor it and downshift in D mode.
    Going to cross post this on the other forum if you haven't already done so John.
    Jun 24 2017
    San Antonio, TX
    Didn't see your reply before I replied...tried the heat seater, no change in requested output but battery now charged up to 83%.
    Sep 10 2016
    MA
    Quote Originally Posted by Ape Factory View Post
    Michel-
    The first ten or eleven characters in the full BEM is the part number. The middle three are the manufacturer code. The last ten are the six digits for the date and the four digits for the serial number.
    Your code, broken down:
    8K0915105F* (F and then a blank space) is where the two-letter identifier I'm talking about should be inserted/changed to tell the car to send different juice to the battery. Looking up that older part number, it looks like that is a 110 amp-hour battery. Woah!
    MLA = The battery vendor is MOLL. I'll edit the original post and put the vendor codes for everyone listed by Ross-tech.
    130215F9GH = DDMMYY of manufacture... 13 February 2015. F9GH = serial number. You could literally put anything you wanted in here. For example, if you wanted your battery to be supercharged, never-let-you-down awesomeness, you would obviously put "ARMY". If you want it to suck and go dead when you need it most, you could put "NAVY" (by the way, the Army-Navy football game is coming up this Saturday).
    My full code for a 59 amp-hour battery, manufactured by VARTA on the 8th of November 2020 with serial number "AGRA" is:
    000915105EB VA0 081120AGRA
    The part numbers are Audi part numbers, so I do not believe they pertain to a specific manufacturer... though I suppose varying the manufacturer (and nothing else) might impact how the battery is charged? Theoretically, it shouldn't have any more impact on the car's behavior than changing the serial number would. I recommend we futz with one "variable" at a time... start with the last two characters of the part number (in this case, the first F in your full BEM)
    -Jon
    P.S. - not sure if this will work or not, as I haven't tried it myself, but the Ross-Tech forums also reports that "Measuring blocks 017, 018, 019, and 020 should show Battery information". Perhaps that information will include things like amp-hours and battery composition (i.e. conventional vs. AGM)? If so, changing the two-letter code (and maybe the manufacturer) then checking those measuring blocks might validate that we're having the desired effect on the battery management system?
    Jun 24 2017
    San Antonio, TX
    You know you're overworked when you have to go back and watch your own installation video. Anyway, duly noted above. Saw your reply when I was driving around and didn't notice any change. I did get a voltage spike but it didn't shut the car down. Wasn't high enough.
    That BEM is from my original battery. Most of the RS5's came with a 110AH battery. I've since coded in a 95Ah BEM from an OEM replacement battery.
    Tried to change the code out in the field but my VCDS stopped playing nice as I refused to update it to the latest software this morning. It takes forever and a day. Once it's finished, I'll throw another code in there.
    On the manufacturer codes, VCDS throws those up on the screen when you use the drop-down menu and select battery update. I'll post up a screen shot shortly.
    Sep 10 2016
    MA
    I edited the first post in this thread quite a bit... already added manufacturer codes up there.
    I think I’m going to head out to my faithful steed and see if changing the codes alters whatever shows up in those measuring blocks, or if they just give you voltage, current, disconnect status, etc. in realtime.
    -Jon
    Jun 24 2017
    San Antonio, TX
    Ok new code in, it would not take DB no matter what I tried. Went to DC the next one up. Headed out for a drive, logging adv. measuring values for CANbus, voltage and a few others.
    Jun 24 2017
    San Antonio, TX
    With the "DC" code in, no real voltage spikes. Looks like the highest I had was 14.38v and when you look at it on the big graph it's very compressed so it makes it look more like a spike. Go back to the main screen and it's a smooth line and it seems like it switches back and forth between the 13V and 14V range. But no warning lights, no electrical interventions. If someone has an AG and has been having an issue, I'd try this and see if it fixes it. I'm not the best example as I haven't been having major problems on a regular basis.
    Here's today, the last "spike" of 14.38V is with the new code, the previous spikes are with the old BEM code.
    Here's a bonafide spike, 14.93V and probably higher in the electrical system.
    Veteran Member Four Rings hahnmgh63's Avatar
    Jan 10 2008
    Roy, WA
    51Ah – 8K0915105J / 000915105BB / 000915105DC
    60Ah – 4F0915105 / 8K0915105G / 000915105DD
    61Ah – 8K0915105H / 000915105AD / 000915105DE
    70Ah – 4F0915105A / 8K0915105C / 000915105DF
    72Ah – 8K0915105B / 000915105AF / 000915105DG
    80Ah – 4F0915105B / 8K0915105D / 000915105AG / 4FD915105 / 8KD915105 / 000915105DH
    95Ah – 4F0915105C / 8K0915105E / 000915105AH / 000915105DK
    110Ah– 4F0915105D / 8K0915105F / 000915105AK / 8KD915105A / 000915105DL
    68Ah – (AGM) 7L0915105 / 000915105CC
    75Ah – (AGM) 3D0915105H / 000915105CD
    92Ah – (AGM) 4F0915105E / 000915105CE
    105Ah– (AGM) 4L0915105 / 000915105CF
    115Ah– 4H0915105 / 000915105DM
    Part number / Serial number
    These are from the site upgrademyaudi.net
    In my 2013 S5 3.0t I was having overvoltage errors when I was trying a smaller Antigravity ATX30-RS - 880 CA. Up to the S4/S5 my 2012 there was a TSB for overvoltage faults, the fix was a new regulator. Even though mine is a 2013 I replaced the regulator which seemed to fix the problem for a couple of days but the overvoltage returned. I tried coding in a lower Ah battery from the list above and the car took the coding but didn't fix the problem. I ended up sticking my OEM battery back in the car and recoded it and all has been fine since then. Sometimes the cranking amps comparison from company to company and/or N. America to Europe can be Apples to Oranges due to the different ways the list the capacities. The battery I think Michel is using is listed as a 40Ah but 1500 Cranking Amps on the Antigravity site. The battery I used above is listed on their site as 880 Cranking Amps, 32 Amp Hours (PbEq)/ 16Ah (Actual)??
    My RS5 is getting close to getting on the road so I'm planning on stepping up to a larger AG battery like Michels and give it another try. I really can't give up on the weight savings the AG batteries provide. The ATX30 is cranking the 4.2TT in my RS6 fine, and the Convenience module/Voltage regulating in the RS6 being a couple years older isn't as picky as the B8.5 equipement.
    2003 RS6 (6Spd)
    2013 RS5 (Headers, Aluminum DSG Flywheel,JHM Stg2, etc...)
    2013 S5 (034 Stg2 & TCU)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Sep 10 2016
    MA
    Thanks for sharing that info! More data points = closer to a formulaic solution that will work for all Lithium conversions.
    VAG reports a battery’s amperage according to the DIN standard, which is considerably lower than the SAE or Cold Cranking Amps rating. Not sure if there is a linear formula that enables one to convert from one to the other?
    I REALLY want to crack the nut on which batteries are AGM and which are conventional... once that’s sorted, which are more compatible with the charging profile the AG battery is looking for. It looks like the info you provided correlates with my conjecture that the batteries with a higher amperage-to-AH ratio are the AGM ones. All those on the list you provided with a 000915105C* are listed as AGM on your list and have a higher amperage rating than the batteries with comparable amp-hour ratings on my list.
    Now we’re getting somewhere...
    -Jon
    Sep 10 2016
    MA
    Did some tests yesterday modifying the last two letters of the part number and modifying the manufacturer to see what effect it had on the parameters I could measure in the measuring blocks. I did all tests with the vehicle on but engine NOT running. I did not do any test drives to see how charging behavior changed, as I was just trying to ascertain what the car changed in it's system based on the part numbers (and perhaps the manufacturer).
    Pertinent block values I was looking at were Battery type (017-1), Vendor (017-2), Size (017-3), and battery state of charge (019-1). Throughout all tests, battery voltage (018-1) remained constant at about 13.0, actual internal resistance (020-1) remained constant at 2.6 megaOhms, and Battery Capacity (020-3) remained constant at about 54 to 53 Amp Hours.
    So, basically the first two rows of the table below are my inputs, and the remaining four rows are the resultant outputs.
    2-letter code Manufacturer Type Vendor Size SOC
    EB (59 AH) VA0 (Varta) OK 1 16 91% (battery voltage was showing 13.1 and for some reason AH was only showing as 32?)
    ED (79 AH) VA0 (Varta) OK 1 18 100%
    CB (58 AH) VA0 (Varta) OK 1 14 99%
    CB (58 AH) TU3 (Exide) Not OK 3 14 99%
    DE (61 AH) TU3 (Exide) OK 3 3 98%
    Obviously that's not an exhaustive test. But, it starts to hint at what the car calculates vs. what it just relies on whatever it's told. For the next round of tests I may try some of the MUCH larger batteries (like the 95-110 AH ones) and the smallest ones (44 and 51 AH) to see what results that gives.
    I am still interested to see if there's some sort of part number logic behind what's a regular (conventional AKA flooded) battery, with thin plates, an EFB (Enhanced Flooded Battery) with thicker plates, and an AGM (Absorbed Glass Mat) battery with, um... absorbed glass mats. The latter two are specifically designed to be fitted in vehicles that have start-stop capability (not like "push-button" start, like the kind where the engine kicks off at stoplights then quickly restarts when it's time to move again). Those need to have higher rates of discharge/recharge that more closely mirror what a Lithium Ion battery is looking for, so I think the key for successfully retrofitting a Li-Ion battery may be narrowing down to those part numbers for AGM/EFB batteries. Between the two, I wonder if the EFB batteries will hold the key. They have a lower charging voltage than AGM batteries, so perhaps there's less chance for overvoltage if the Audi's BEM is told that an EFB is installed. Refer back to the first post, where I've done several edits and updates to capture this info. There does, indeed, seem to be a correlation between part number suffix and battery type.
    -Jon
    Jun 24 2017
    San Antonio, TX
    I'm pretty sure we have regenerative braking on our cars. It's done via the alternator and puts an increased load on the engine when decelerating and it's used to charge the battery. I've noticed that voltage is increasing under deceleration. I need to do some voltage logging with the VCDS where I can log it along with rpm to confirm.
    Sep 10 2016
    MA
    I still haven’t found a good BEM code that keeps my car from overvoltage. Even just sitting at idle, I’m seeing similar behavior for most of the codes I’ve tried... slow increase in voltage until about 14.8, then some sort of safety disconnect occurs and it drops to 14.0 and I lose seat heaters, defrost, etc. often times, if I’m driving, that protection doesn’t kick in soon enough and other control modules freak out and shut down, causing much consternation and many faults (sport differential, transmission, MMI resets, etc).
    I think I’m just going to end up trying EVERY code on this list to see what happens. Hopefully I find one that works. I may also need to do some research in the self-study manuals to find out more about the battery management system’s function and perhaps I can logically reason why it’s doing what it’s doing.
    -Jon
    Sep 10 2016
    MA
    Two things I've learned from digging into the manuals:
    1) The Battery management module stores up to three different batteries. It stores them by serial number (not part number) so when I was changing the part numbers only in my experiments above, it might not have been having the desired effect.
    2) These cars are smart. Way too damn smart for their own good. Not only is the battery management module (the one bolted to the negative terminal) connected to the LIN bus and talking to the central computer, but the ALTERNATOR is doing the same damn thing. So much for intercepting the field winding voltage and dialing it down a bit!
    If I can't figure out a way to fix this with software coding, I'm going to have to try and spoof the battery management module. There is really only one place that can be done... it has a short wire that runs back to the positive terminal side that's about a foot long, thin gauge, so it's basically just a "signal only" and isn't really current-carrying. I would need a DC converter to boost the signal voltage going to the BMCM by about a volt.... this would basically tell the computer that the battery voltage was higher than it ACTUALLY is, and get it to tell the alternator to take a chill pill before all the systems can start freaking out. For example, when the alternator is putting out 14.3v, I would want the battery management module to see it as about 14.7v so it would stop sending more juice.
    The saga continues....
    -Jon
    Sep 10 2016
    MA
    Okay, getting closer to a solution. First of all, I'm going to take the info from my post immediately above and edit into the first post of the thread, so that folks don't have to dig when referencing this.
    Second, I am testing a couple different methods to spoof the Battery Monitoring & Control Module (BMCM, aka J367). I've had some success in "static" (aka car idling in my driveway) testing, but haven't done any "dynamic" testing yet. Will report back. Once again, I'll update the first post with these results in more detail, but I see the following methods as viable options for addressing this issue:
    1) CODING. This should be your first stop. Try re-coding the BMS with a battery part number that's closer to the amp-hours of your AG battery (or other LiFePo4 replacement). Make sure you use a new serial number (second part of the BEM). I do NOT recommend trying the EFB or AGM part numbers... even though those types of batteries supposedly are closer to the charging profile of what the LiFePo4 batteries want, I found that I got MUCH worse overvoltage spikes when running that part number. Stick to the conventional ones. PROS: Free (if you have the necessary hardware) and minimally-invasive. CONS: You need to have the necessary hardware (VCDS, OBDeleven, etc), doesn't seem to work for everyone.
    2) DISCONNECT BMCM. Unplug the two-wire connector at the negative battery terminal. This places the car into a "fallback" mode. Alternator puts out no more than 14.3V, whereas I was seeing up to 15V at idle with it connected. I haven't done any driving tests to see if this has any other adverse effects. PROS: Free. Easy. CONS: You are defeating some of the functionality of the vehicle; this may have other side-effects of which I am not yet aware.
    3) DROP OUTPUT VOLTAGE OF ALTERNATOR. Install a high-amperage diode inline with what goes from the alternator to either the jumper block in the cowling under the hood, or to the main fuse block on the positive battery terminal. Not sure which would be better, as I haven't tested this yet. The part is on the way, though, and I intend to. PROS: A "hardware" solution for limiting alternator voltage doesn't rely on software reaction time. CONS: Costs about $25 plus installation time, may have other side effects, inefficient (wasting excess voltage as heat), and reduces alternator output voltage ALL the time (even at lower RPMs when you may not want voltage to be lower).
    4) SPOOF BMCM WITH BATTERY AND DIODE(S). Put a 1.5V (AA, C, D, doesn't matter) battery in series with the voltage-sensing lead from the positive terminal to the BMCM. Add a diode (or diodes) to drop voltage "boost" to the level that gives you the best performance. This tells the BMCM that the battery's voltage is higher than it actually is, as I theorized above. I tested this, and it DOES work. Adding about 0.6-1v seems to get the BMCM to tell the J533 module to tell the alternator to chillax and dial back its output voltage. It was a crude test, and I didn't do any driving to see if this solves the problem under all conditions, but it's promising. PROS: Relatively inexpensive, simple, retains functionality of J367 module to adjust alternator load to varying conditions without overcharging AG battery. CONS: May take some trial-and-error to tweak/tune, and the 1.5V battery will need to be changed out periodically.
    5) SPOOF BMCM WITH ISOLATED DC-DC CONVERTER & DIODES. Same effect as described above... lie to the BMCM. Basically replace the 1.5V battery with an isolated DC-DC converter so it never has to be changed or charged. Found one that steps down to 3.3V, then we'll have to get down to the desired "boost" voltage by adding a few diodes to drop the voltage to whatever works best (again, shooting for somewhere between 0.6 and 1v). Haven't tested this yet, but the components will be here early next week. PROS: retains functionality of J367 module to adjust load to varying conditions without overcharging, no current draw when off, no 1.5V battery to change. CONS: Most complex solution, requires some rudimentary soldering and fabrication skills, costs about $30 in components (DC-DC converter, diodes, relay, enclosure, wiring, board, etc.)
    -Jon
    Last edited by volvofan; 12-24-2020 at 01:56 PM. Reason: Came up with better solution for option 5 that uses fewer components.
    Sep 10 2016
    MA
    Latest updates-
    Simply disconnecting the BMCM has been effective. Voltage (according to the battery tracker) recharges to 14v shortly after startup, and no features are disabled (i.e. seat heaters, high beams, rear defrosters, etc.). I've seen no voltage spikes or adverse effects on any other vehicle systems, though I know this is throwing a "soft code" that'll show up on a VCDS auto-scan. Also, since this is only a viable solution for the Audi cars that use this particular method of energy management (many other models have a more complex external regulator or an integrated electrical systems control module... neither of which should simply be unplugged!), I will continue to puruse the "spoofing" route.
    Here are a couple photos (and the schematic) of the prototype I've created to inject a little extra voltage into the BMCM's sensing lead without throwing off any other vehicle systems. It's simpler than it looks... cut the wire going from the battery to the BMCM, and that's two of your connections. One more goes to the battery terminal itself to provide ground, another gets "switched" power when the ignition is on via a tap off of the wiring harness to the AWD module that also happens to sit in the trunk (some models have a whole "ignition hot" fuse block in the trunk but not our 5 series, I believe... or at least not my RS5. I have a fifth wire that's also turning on my subwoofer amplifier, but that's optional.
    HOW IT WORKS: When the ignition is off, the module is "passive". Voltage flows from the battery positive terminal (through a low-amp fuse and a small Schottky diode to keep the module isolated in case I messed something up) and on to the BMCM as it usually does, reflecting accurate battery voltage within a tenth of a volt (small drop due to the diode). When the ignition is on, the +12V tapped from the AWD module's harness engages a solid-state relay (I picked a SSR to ensure only minimal drain on the stock system so it won't even know it's there). That relay then provides a 12v signal to an ISOLATED (it MUST be isolated) DC-DC converter that steps the voltage down to 3.3v. It also sends a 12v signal to turn on my amp ;). Then, I run that 3.3v IN SERIES WITH the battery wire going to the BMCM so that the voltage generated gets ADDED to the battery's voltage. Using a few diodes in line with that wire (each diode has a voltage drop associated with it, but has low impedance so once again the car shouldn't know any better), I can drop the added voltage to whatever level we desire. Probably going to be shooting to add around 0.7 volts, as I've seen this alternator put out up to 15v. Ultimately, I'll be looking for whatever amount of diodes causes the car to charge the battery to about 14.1 or 14.2 V WITHOUT any associated voltage spikes.
    In the photo below, I have three "regular" diodes and one Schottky diode in series. My bench power supply puts out about 13.9V and I'm seeing about 16.1V on my multimeter... a boost of around 2.2v. Before I install it in the car, I'll probably end up adding four more "regular" diodes (the IC socket has its pins soldered together in pairs, allowing me to use it like a breadboard to quickly test different combinations without soldering).
    Update - the IC socket sucks for holding diodes. I honed in on the approximate number of regular and Schottky variants I needed, and ended up soldering them all into a multi-position rotary switch, so I can adjust the outputted "boost" voltage on the fly. Here is a schematic that is more reflective of my final prototype, with some further improvements to ensure voltage remains isolated and the car is protected against backfed current while increasing the "fine-tunability" of the boost voltage. Also, some more photos of the finished product.
    Jun 24 2017
    San Antonio, TX
    Did a long drive yesterday to go pick up cross bars for a few transmission kits I'm working on and it gave me time to test. This time I pulled the two wire plug off the negative battery terminal that feeds the BCM voltage readings. I was going to log but I let the battery run out on my computer and my VCDS wasn't seeing the VCDS plug (thanks Bill Gates!). Got tired of trying to fix it so I went out monitoring it with just the bluetooth monitor.
    Looking at my radar detector's voltage output, the highest I saw was 14.4v. Car seemed to charge the battery just fine and I was pushing the car when appropriate, braking hard, running it up to redline, etc...I didn't have one glitch. Looking at the graph from the Bluetooth monitor, voltage read lower, I think my peak was in the 14.2 range. I'll post the graph up later.
    It appears simply unplugging the BCM works just fine. As Jon said, no lights on the dash. I made multiple stops later in the day and experienced no downsides and the battery was showing it was fully charged.
    I DO like Jon's solution better and I may build one myself for testing. At the very minimum, if you do have issues, unplugging the BCM at the negative terminal will work with the aforementioned disclaimer Jon mentions in his first post. Most cars do not have any issues at all which is what's so surprising.
    Another thought I had was maybe the actual bluetooth battery monitor itself was causing issues. I've not tried to run without it attached just yet. It does span between the positive and negative on the battery but I'd think it would be properly insulated. Just trying to eliminate variables!
    Sep 10 2016
    MA
    Here’s a simplified schematic for a version that does not have provisions to remotely turn on an amplifier. I’m counting on pretty low current draw for the signal going to the BMCM and using the switched 12V going to the ABS module to drive the DC-DC converter directly rather than using the solid-state relay. Also eliminated all non-Schottky diodes for the sake of simplicity.
    I have NOT built and tested this circuit but it “should” work without issue.
    -Jon
    Jun 24 2017
    San Antonio, TX
    Seriously awesome work Jon. I'll attempt to build one of these and test it out myself. Thanks for your time, help and expertise on this. Looks awesome!
    Senior Member Three Rings SteveRS4's Avatar
    Jul 07 2019
    uk
    Can someone tell me please what BEM Code i would enter in vcds for a AGM 95A 850 cold cranking battery ??
    I know the make is VAO but not sure what 2 letters i need to convert it to an AGM battery ?
    Thanks in advance guys
    Sent from my SM-G920F using Tapatalk
    Sep 10 2016
    MA
    I’d try “CE”, as that appears to be rated at 92 Amp-hours. Should get you close enough.
    Full code would be:
    000915105CE VA0 123456ABCD
    Hope that helps!
    -Jon
    Sep 10 2016
    MA
    Thanks, Michel! Definitely try the latest schematic if you don’t need the amp turn-on lead. Much simpler.
    I’ve been doing more driving than usual over the past few days, and my little black box seems to be doing the trick. Battery voltage varies slowly between 13.6v and 14.5v. Recharge rate after starting is deliberate and stable, regardless of driving conditions or high current consumers in use. Not a single error code or glitch.
    -Jon
    Jul 07 2019
    uk
    Quote Originally Posted by volvofan View Post
    Full code would be:
    Hope that helps!
    -Jon
    That's great Jon thank you ever so much for that ill try it and see how i get on
    Great work on your device you made very impressive mate and it seems to work well top job
    Jan 10 2008
    Roy, WA
    Jon, when coasting after a good acceleration do you see a spike in the voltage somewhat, like the car is trying to overcharge the battery?
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Sep 10 2016
    MA
    Quote Originally Posted by hahnmgh63 View Post
    Eh...... sometimes. Ish. I can’t replicate it consistently (as in, I’m not remotely close to being able to say something like, “okay, if I rapidly accelerate to 70 mph then take my foot off the gas and coast back down to 30, I’ll see voltage rise by about 0.6V”). Like... not even close to being able to figure out under what conditions it occurs.
    -Jon
    Sep 10 2016
    MA
    Quote Originally Posted by SteveRS4 View Post
    Thanks for the props! Let us know how it works out!
    -Jon
    Junior Member One Ring atxdjlucas's Avatar
    Jan 09 2020
    Salmon Arm/ BC/ Canada
    Hi guys,
    I have been looking for a solution everywhere.
    I have a 2009 A4 B8 Avant, I bought it used last year around this time. Ever since I owned the car it was giving me lower voltages but it has not really been an issue, besides in the winter it seems to have a much harder time to start because of the lower voltage.
    Here is what the car is doing:
    When the car is not running the battery voltage sits in the high 11's like 11.9v when the car is running the highest voltage I have seen was 13.8v but it hardly ever gets there. it usually sits at 12.4 to 12.8v. A week ago I changed the alternator because I didn't know these cars had a smart charging system, I just assumed my alt was getting tired, but no change whats so ever... I then found out that the battery needs to be programmed to the correct size, so I checked that and found, sure enough, it was set to AGM 75Ah but the battery is an AGM with 95Ah so I changed the Partnumber to 92Ah AGM that was the closest one but once again no change in the charging behavior but now my OBDeleven tells me that my SOC is at 55% and it still will not fully charge my battery.
    Yesterday I put a charger(1.5amp) on my battery overnight and it was showing 75% in the morning. When I got to work my OBDeleven was reading 0 to negative -4A on the battery current, so now the car seemed to be running off the battery because its voltage was higher than usual.
    I also checked my battery connections everything is tight and looks clean.
    I have not tried a new battery because it seems to be charging ok on an external charger.
    I have a better external charger/battery conditioner that I will try later/tonight.
    Any suggestions?
    Possibly a bad BMCM?
    Jun 24 2017
    San Antonio, TX
    If it's the same on the 2009 as it is on my 2013, I'd try unplugging the battery control module at the negative terminal on the battery and see if that changes anything. What it theoretically should do is turn it into a "dumb" system and you should see an increase in charging voltage. I usually reside between 13.7-14.0 with occasional periods as high as 14.3v but no higher.
    Jan 09 2020
    I have tried that yesterday while the car was running and nothing changed but maybe I should leave it unplugged for longer?
    Sep 10 2016
    MA
    Quote Originally Posted by atxdjlucas View Post
    Hi guys,
    Any suggestions?
    When re-coding, don't forget to change not only the PART number portion of the BEM code, but also the SERIAL number portion.
    It may take some drive cycles for the car to adapt to the new battery and start charging it properly. For what it's worth, I definitely would have changed out my battery before changing out my alternator if voltage was consistently low, especially if your resting voltage was below 12v.
    Try re-coding with new Serial number and go for a few drives, then see if your alternator output has changed. Also, you could double-check by logging in VCDS to make sure that there isn't an unusual amount of voltage drop between the alternator and the battery... shouldn't be more than .3v or so.
    Hope this helps!
    -Jon
    Jun 24 2017
    San Antonio, TX
    As Jon said, it does take time to adapt if you recode and it's necessary to drive around. Same with unplugging the BCM. Take it out for a drive and you should see the voltage increase. If none of those work, I'd look hard at grounding issues especially since you're in a cold climate with, I'm guessing, corrosive road salts.
    Jan 09 2020
    Thank you!
    and yes I always change my serial number as well.
    The low battery resting voltage is due to the charging system not charging it up to a good voltage in the first place.
    One thing I forgot to mention is that while running I removed the Negative connection on the battery and nothing changed car stayed running as it should and the voltage stayed at 12.5 ish, it did not go up like I was hoping to see if my battery was bad.
    I have checked all my connections and I have no corrosion anywhere.
    One thing I have not done is check the voltage drop with a meter. I will try and check the voltage right at the alternator and the battery.
    Jun 24 2017
    San Antonio, TX
    Sometimes all it takes is one loose terminal or nut to get a precipitous voltage drop. A corroded line, torn sheathing, etc...can all cause that. Given the age of the vehicle, it'll probably take a bit of elbow grease to track down a bad connection.
    Jan 09 2020
    I took a couple of screenshots of what my OBDeleven is reading of the battery while driving
    signal-2021-01-27-123718_001.jpgsignal-2021-01-27-123718_002.jpgsignal-2021-01-27-123718_003.jpgsignal-2021-01-27-123718_004.jpgsignal-2021-01-27-123718_005.jpgsignal-2021-01-27-123718_006.jpg
    Not sure about the 107%. And looks like the car is asking for 15V?
    do you guys know where the engine/alternator grounds to the frame? I guess that connection could be bad.
    Jan 10 2008
    Roy, WA
    Ground should be by the right front suspension/engine cradle/Motormount.
    2003 RS6 (6Spd)
    1974 911 (3.6ltr)
    2006 CTTS
    944T
    Sep 10 2016
    MA
    Bust out the multimeter and trace voltages from the alternator to the battery to see where you’re losing 2V. I think it goes from the alternator to the positive jumper/distribution block under the hood, then back to the battery.
    Jan 09 2020
    Good News, I busted out the multimeter, and I found that I got 14.8v coming out of the alternator but only got 13.3v at the positive distribution box under the hood. Looks like the wire goes from the alternator to the starter and then to the distribution box?
    All connections look like they are brand new, the only one I cant easily see is the one on the starter.
    Anyway, I think I will just add a #2 battery cable from the alternator directly to the positive distribution box under the hood. Next time I got my car on the lift I will check the connections on the starter and clean them.
    I did add a temp wire to confirm this and it did work.
    Thank you guys for your help!
    I now know so much more about the 12v system in this car.
