Results 1 to 8 of 8
    Mar 12 2017
    N.C. USA
    Need info re OBD11 upgrades for 2018 Q5 prem+
    Next week going to have tech do upgrades w/OBD11. Really appreciate a listing from anyone who has a list(s) of recommended mods/upgrades etc.for my 2018 Q5. Pls post, pm or email me. [email protected]
    Want to get it done right the first time. Have done a forums search but sure my findings are not complete. THX
    2020 Q5 prem plus Matador red/Beige
    Senior Member Two Rings trevor51590's Avatar
    Dec 18 2007
    '21 S4, '21 Q5
    Take a look at this thread in the B9 A4 forum, most of those will work in the Q5
    https://www.audizine.com/forum/showt...DS-mods-for-B9
    '25 RS6 Performance | Daytona Gray/Congac/Black Dinamica | Executive | Black Optics | RS Sport Exhaust | RS Driver's Assist | B&O
    '21 Q5 Premium Plus | Navarre Blue | Nav
    '21 S4 Premium Plus | Daytona Gray | S Sport | 034 Stage 1
    --Gone but not forgotten--
    '23 RS5 Sportback | '18 A4 Premium Plus | '18 Q5 Prestige | '13 S4 Premium Plus | '11 S4 Premium Plus | '06 A4 2.0TQM | '99.5 A4 1.8TQM
    Jan 01 2018
    Idaho Panhandle
    Following are the changes I've made using OBDEleven. Remember: get a full read out of your original values and save (email) a copy to yourself.
    Auto Start-Stop feature - disable
    Air Conditioning (08) > Adaptation > A/C comfort parameter for start-stop function > (default) 5 > change to new value (0 = disable start/stop)
    Disable Seatbelt Warning
    Dash Board (17) > Adaptation >Deactivate seat belt warning > (default) No > change to Yes
    Display Gear in Virtual Cockpit
    Transmission (02) > Adaptation > Single gear display > (default) D off/S off > change to D on/S on
    Turn Signal Freeway Flashing
    Central Module Comfort System (46) > Adaptation > Turn signal control > Freeway flashing, flashing cycles > (default) 3 > change to desired number (I chose 5)
    Turn Off Soundaktor
    Actuator For Structure Borne Sound (A9) > Adaptation > Volume of structure-borne noise actuator > default 100 (%) > Enter a value (0 = mute)
    Increase time required to open trunk lid with remote key
    Central Module Comfort System (46) > Adaptation > Time for opening rear lid with remote control > default 800 (ms) > change to desired value (e.g. 2000 = 2 seconds)
    Increase amount of time before "Lane keeping warning: keep hands on steering"
    Note: Modifies the threshold of when the lane assist shuts off due to no steering input by the driver
    A5/Front Sensor Driver Asst
    Adaptation Channel: Directional stabilization assist driver inact deactiv threshold
    Old: Medium
    New: Late
    Allow Navigation Panning while Driving
    Note: Reboot MMI Nav afterwards (Nav/Map + Radio + Push Center Knob)
    Information Control Unit (5F) > Adaptation > Locked menu contents > FB_NAV_3 > non_blocked
    Choose the default Adaptive Cruise distance at vehicle startup.
    Note: Puts a new option in the MMI that let's you choose
    Module 13/Adaptive Cruise
    Adaptation
    Distance Basic Setting Option
    Old Value: Off
    New Value: On
    Easy Entry
    Note: Moves seat back when car shut off and door opened. Move seat to stored position when Start button pushed.
    I used the OBDEleven app for 10 credits. Following are the changes made at a bit level which I believe you can make using long coding.
    09 Central Electrics
    Long coding:
    OLD
    07500363E0691CCD050D51199CBE98B9110B3D080000000000000000200016010A63012B825709
    NEW
    07500363E0691CCD050D51199CBE9CB9110B3D080000000000000000200016010A63012B825709
    36 Seat Adjustment Driver Side
    Long coding:
    OLD
    005C1B000000B0010000010101010000000000000000000000000000000000
    NEW
    005C1B400000B4010000010101010000000000000000000000000000000000
    Adjust MPG Calculator
    Dash Board (17)
    Adaptation
    Display correction of consumption and operating range
    Changed from 100% to 107%
    Change AC Option from AC Max to AC Eco
    Adaptation: ACmax/ECO
    Old Value: ACmax
    New Value: ECO
    Adjust Volume Defaults
    Control Unit 5F
    Adaptation
    Audio Management Input Gain Generation 2
    Satellite Radio - old: 17 new: -128
    Radio (AM): -5
    Radio (FM): -5
    Satellite radio: -2
    Media_BTDevice: -2
    All others, like Nav inputs, leave at -128.
    2018 SQ5 Prestige, S-Sport, Dynamic Steering, APR 91 Stage 1 Tune
    Jul 16 2020
    Bay Area CA
    Quote Originally Posted by spindlewood View Post
    Easy Entry
    Long coding:
    OLD
    NEW
    Long coding:
    OLD
    NEW
    I tried the app on obd11 for this but it's not doing anything. I see the bit to modify for module 19 but module 36 isn't labeled. Do you know which bits need to be checked for byte 3 and 6 in module 36?
    Jan 01 2018
    Idaho Panhandle
    First, go into the MMI and search for the seat adjustment. I'm pretty sure this mod adds a setting which wasn't visible before. You might have to uncheck and recheck the setting for it to take effect. I remember I had to do this once.
    Also, did you take a backup before running the app? If so (and even if not), do a backup now and generate a current file and send it to yourself. Compare the two files and see if the changes shown in the post for 09 and 36 were made by the app. Presuming not, this is the logic I'd follow, using my experience as a programmer. But I haven't tried to do this mod using long coding myself and so you do this at your own risk. Remember to make a scan and send it as a backup. That said...
    It appears that each two places (of numbers or letters) in the long coding string represent a hexadecimal digit.
    Each hexadecimal digit represents four bits, or half a byte.
    So it takes two hexadecimal digits (4 places in the long string) for each byte.
    If we take 36 Seat Adjustment string and split it byte by byte we get:
    005C 1B00 0000 B001 0000010101010000000000000000000000000000000000
    It would appear that it is bytes 2 and 4 that need to be modified.
    If you go this route, make sure you run a scan and email yourself the file and then after the change do the same thing. Then verify that the changes show up in the bytes you expected. If not, you can easily go back and reverse your changes.
    If you do attempt this, please report back with your results. A pic of the screen where you've made the change would be a bonus.
    Good Luck!
    Jul 16 2020
    Bay Area CA
    Good Luck!
    When I reconnected to the car the app did in fact modify those two chains. I'll try and dig through the MMI for the seat settings.
    Edit: Off and on in the MMI was the trick. Disappointed that it only goes back and not down, I was hoping it would be a hack for my squeaky seat. It was already re-greased once...
    Sent from my SM-G950U using Audizine Forum mobile app
    Dec 16 2019
    1986 944 turbo
    Oak Hills, CA
    Quote Originally Posted by grosen84 View Post
    It would really help if you would put the model and year of your car. Someone with the same car may be able to help you out. As for the squeak, there's a TSB on newer cars regarding bad welds inside the seats. May be causing your squeak. Sorry I don't have a copy of the TSB.
    2020 SQ5 Prestige, Matador Red.
    Jul 16 2020
    Bay Area CA
    Quote Originally Posted by BarneyM View Post
    It's a B9 SQ5, but not a driveline issue, so it should generally apply in this forum. I'll check out the TSB about the welds, the only one I found was to grease the tracks.
