Originally Posted by
djn876
Could be plugs but that sounds a lot like leaking intercooler too. My plugs were always clean when mine was leaking. Was surprised at how much gunk had built up without any other indications on the plugs and things and coolant loss was very small and hard to detect.
When you say misfire do you mean you are logging misfire counts, or are you referring to knock detection?
Sent from my SM-G988U using
Audizine Forum mobile app
Just installed the NGK BKR8EIX plugs, gapped to .026". Zero misfires. Logging misfire counts. Pulls hard. 7k upshift 3>4 is flawless. I'll try a Dragy run tomorrow. I understand that it may take time for a leak to affect the new plugs.
All old plugs were normal looking except for what seemed accelerated wear on the ground strap. No fouling, expected black soot, though. All were dry, no evidence of IC leak. Gap had not opened appreciably, though. Still at .026"-.028", closer to .028" on most.
For those interested, the BKR8EIX plugs are technically for another application and come gapped at .032". I closed them to .026". Note: gapping Iridium fine wire plugs must be done very carefully to avoid scraping or damaging that fine center electrode tip. I learned this lesson the hard way years ago on another platform that came with NGK Iridium plugs OEM.
