I feel I shouldn't have to ask this. It should be easy to do but didn't work, so thought I'd ask.
A couple weeks ago I got the Service Due! reminder on the center cluster. The MMI screen also showed the countdown to 0 days. I just finished changing the oil, in the MMI went to the service spot, scrolled down and selected reset service interval. I figured that should do it, but it still shows in the cluster on start up/shut off. On my old 2015 A6, you couldn't reset it in the MMI, I had to use the Carista I had at the time to clear it. So I synced my OBDeleven, went to Apps, and spent 10 tokens to reset the oil change reminder. Side note, does it cost 10 tokens every time I need to reset it? Anyway, did that, shut the car off and on, and still getting Service Due!
Only thing I can think of is it wasn't an oil change reminder, but service for something else? Therefore resetting the oil change one in the OBDeleven app did nothing, ever though they gladly took my 10 credits. Was I suppose to select something else? I saw there was another option that looked like it might be right, but I only had 4 tokens left.
