Originally Posted by
NPuter
That's the beauty of the CETE - you're not locking in a fixed drop and are increasing the flexibility of air suspension.
E.g., you can make comfort mode higher than stock (for extreme situations), auto stock height, and dynamic lower than stock. And then you can quickly cycle through them with the drive select button.
Interesting. That makes sense. I guess I'm pretty happy with the current ride height for the car as a daily. While I'm satisfied, I can see why someone who wants to slam the car, but not be committed to being low all the time, that this unit would work well for them as they can't customize and change as they see fit.
Djpeaksd
Yeah, I am in CA so only have 91. However I do have a gas station right down the street with E85 so with JB4 I was able to put 4 or 5 gallons of E85 in the tank on my RS5 and quickly and easily log the car through the JB4 app and send it over to George at Burger and run the appropriate map. Kind of nice to see real time info on your car when running a tune as well.
I can see that being beneficial for your preferences. Sounds like you enjoy tinkering, as a lot of people do. I'm guessing they haven't gone this far with the RS6 package as I would assume most owners just simply just want a little more power and aren't experimenting with different fuels etc as you would with more traditional VAG tuner cars like the S3, Golf R, S5, etc... My personal preference is a set it and forget it at 93 octane, 700hp is plenty :) But I get why someone like you could make use of more features. I think "APR" will have a flash eventually that will allow you to switch between various states of tune. The problem with the flash, as you know as indicated by your previous purchase of a second ECU for your other car, is that it's detectable, even when the flashed back to stock. I would wager that most of us are not comfortable riding in the grey area of the warranty with such an expensive drivetrain.
[email protected]
The CETE air suspension modules have been insanely popular with the RS6 crowd so far, can't keep them in stock. I imagine there are some folks here who have their cars and are already running the CETE setup.
The CETE setup will lower/raise the car from what the car sets as a height in each main drive select mode. So if the RS6 isn't sitting lower in dynamic when parked the car would be whatever you lower in the app for dynamic. When you got moving if the car lowered itself this will still happen with the CETE setup.
Example:
Dynamic - CETE set to 12mm lower - you are 12mm lower than the standard dynamic at park. You start moving and the car lowers 6mm more you are at 18mm of lowering from dynamic while parked.
You can set a speed threshold in the app which will essentially turn the CETE setup off above a certain speed as well.
If anyone has any questions on the CETE air suspension setup or exhaust valve controllers don't ever hesitate to contact me as the North American support/distributor:
[email protected]
Cheers,
Just curious, if you are set to 12mm lower than stock, while parked... Why would you want to drop another 6mm (for a total of 18mm) when you start moving. Forgive my ignorance, but wouldn't your lowest setting typically be parked if you wanted that "stanced" look when parked, without the absurd camber?
At one point do start rubbing on the RS6?
Will the CETE let you go low enough to have a rubbing problem?
If you set the CETE to a certain level, does it completely override the stock system, disabling it? Or is there a possibility the car will continue to lower on it's own, going lower than you prefer, if it does its own adjustment based on driving conditions and speed?
How do most people set up the RS6 wtih the CETE?
Sounds like an interesting product.
