    Established Member Two Rings nks979's Avatar
    Mar 10 2017
    Arizona
    265/40/20, Will it fit?
    Currently running 275/35/20 with no issues, however I moved to somewhere with a much heavier winter so I need to pick up some tires that will handle year round a bit better. Trying to go with Pilot sport all season 4s, but they only come in 265/40 or 275/40, tire place is adamant these won’t fit for an A7 - any input from 7 owners on whether this will work?
    2013 DGP Audi A7 - Prestige/Sport
    Sep 16 2020
    West Michigan
    According to an online tire calculator, a 265/40/20 is approximately 3/4" taller than a 275/35/20.
    2012 A6 Prestige - APR single pulley via Fluidampr 189, Injen intake+RS7 airbox, IE HPFP, EPL TCU, JHM HX, 034 motor mounts, Eurocode drivetrain inserts, gutted cats - 034 tunes purchased, not installed.
    Junior Member Two Rings
    Jul 30 2019
    Newton M.A
    I say run 255/35/20 since it's a6/s6 size and also what I ran on my S7 being cheap since 265 35 20 was 100 more per tire for conti dws06
    Sent from my GM1917 using Tapatalk
    Mar 11 2018
    Severna Park, MD
    Why not go with the A/S 3+ if winter is a concern? I had 275/35/20 on my A7 and they were fantastic. Though I felt better running 245/45/18 in the winter.
    Sent from my HD1905 using Tapatalk
    Apr 25 2020
    Holland
    Quote Originally Posted by ruifeng.li.94 View Post
    On some roads my car tends too follow the slight curves on te road which then needs some small corrections. Would it help if I go for 255 35 20? I'm also currently on 265 35 20
