Results 1 to 8 of 8
    Established Member Two Rings PTeezy's Avatar
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    Rear license plate bracket
    Alright, just received my custom vanity plate. When installing...the plastic for the top two screw hole tab ended up being destroyed. Any remedies to fix the issue?
    Removing the bracket and turning it upside down is what I had in mind...but the bracket is attached by double sided tape and the two 20mm torx screw. I just don’t want to ruin the sensitive ara blue paint.
    Or I could use the two bottom mounting holes...but I do like having a plate frame for my tag. Frame only has top two mounting holes.
    Audi definitely over engineered this bracket.
    -Patrick
    Senior Member Three Rings Cool_Breeze's Avatar
    Feb 22 2020
    San Jose, Ca
    It'll be a trip to the dealer for that. Mine broke instantly when installing my plates - it was weakened when the dealer over torqued it. They handled the removal and resticking under warranty.
    Sent from my Pixel 3 using Tapatalk
    Veteran Member Three Rings BecksA3's Avatar
    Dec 20 2019
    2006 A4 Cabriolet 3.0l Quattro, 2100 Ram 1500
    Williamsport, PA USA
    Quote Originally Posted by PTeezy View Post
    With a little bit of heat and slow steady pressure it should come right off.
    Took mine off my black A3 without a problem just letting the sun warm it up.
    Then you can find a aftermarket one on eBay.
    '16 A3 Quattro S-line, Black on black, on black: Eurodyne Maestro Suite, DIY 3" intake, GFB DV+, ECS RS Ignition upgrade, and an ever growing wish list.
    "When this baby hits 88mph, you're going to see some serious shit!"
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    I just resorted in purchasing a rear plate bracket off of Amazon.
    I will test fit this unit and see where it goes.
    Here’s a link if anyone else has the same issue and is interested in replacing it.
    Trunknets Inc REAR LICENSE PLATE BRACKET FOR AUDI A3 S3 2014 15 2016 2017 2018 2019 + 8 Unique Screws & Wrench NEW https://www.amazon.com/dp/B01D66AHDY..._.QKXFbNXHEWP8
    -Patrick
    Sep 27 2019
    Boulder, CO
    I just stripped the shit out of one of the screw holders too. Ordered the same thing as you and hoping I can simply install it and go about.
    I also ordered the weathertech plate holders and the screws that came in the car as well as the ones from weathertech were not long enough. Hoping this fixes that issue also since the stock ones are kind of sunk in.
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    Quote Originally Posted by starsh0t View Post
    I’m glad I’m not the only one who’s having issue or had an issue.
    $50 for a plate holder bracket is still absurd. Better than over $100 from Audi.
    Let me know how it goes. I’ll get mine installed next week.
    -Patrick
    Sep 27 2019
    Boulder, CO
    Installed and looks good. Was even able to get the weathertech frame on there.
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    I got mined installed over the weekend. Much better craftsmanship than Audi. Amazon saves the day for me! lol
    -Patrick
