Results 1 to 3 of 3
    Active Member One Ring audiboi.86's Avatar
    Feb 17 2019
    NoVA
    B8 A4 MMI Update
    Hello:
    Can someone kindly help me with finding a reliable source to obtain the latest MMI updates for my B8 A4? Also, does anyone know if the latest update will change the Sirius XM display to look like the latest version?
    Thank you.
    Veteran Member Three Rings B6_Dolphin's Avatar
    Apr 10 2005
    PNW
    Here's a link to buy the 2020 Navigation Map & Firmware updates for the B8 A4:
    https://www.ebay.com/itm/Audi-A4-A5-...item2ae56ed485
    You will receive three (3) authentic Audi P/N S/W SD Cards - a 2020 Nav Update, a Firmware Update, and an Activation Card (install last!).
    Once installed, you'll also need to fix a few errors:
    https://upgrademyaudi.net/tutorials/...how-to-remove/
    And this:
    And you'll need to buy the script tool, too:
    https://upgrademyaudi.net/product/03...emoval-script/
    After the Activation Card is loaded and run, you'll need to perform a reboot of the MMI.
    Expect the updates to take 2-3 hrs total.
    2023 RS5 Coupe - Ascari Blue/Black; Mods: IE A2A IC, 034 Strut Brace, ECS Poly Trans Mount, APR CF Intake, EuroCode FRT & RR STB + Endlinks, PB Pedal Tuner; AskCarbon Steering Wheel
    2021 SQ5 S/B Prestige - Daytona Gray/Black
    Veteran Member Three Rings DrGER's Avatar
    Aug 31 2014
    '17 Audi A4Q 6MT CYMC/RJN, '11 VW GOV TDI 6MT CJAA/LHD
    NW OH USA
    Quote Originally Posted by audiboi.86 View Post
    Hello:
    Thank you.
    What model year? Which MMI (3G High or Plus)? Need to update maps, too? What is current MMI firmware version?
    For MMI 3G+, current (latest) firmware for NAR is: HN+_US_AU3G_K0942_6
    New 2020 map update (released recently) for NAR is: 8R0060884GJ NAR 6.20.1
    Take a look here, too, just in case: https://www.audiworld.com/forums/q5-.../#post25431527
    2017 B9 A4Q P+ 2.0T 6MT Daytona Gray. Previous: 2014 B8.5 A4Q P+ 2.0T 6MT Monsoon Gray; 2009 B8 A4Q P+ 2.0T 6MT Brilliant Red; 2005 B6 A4Q 1.8T 6MT Cambridge Green; 1995 B4 A90Q V6 5MT Pearl White; 1990 B3 A80Q I5 5MT Crystal Silver; 1984 C3 5000S I5 5MT Montego Black; 1978 C2 5000 I5 4AT Helios Blue; 1977 C1 100LS I4 4AT Signal Green; 1974 B1 Fox I4 4AT Sahara Sand.
