Hi mate
I've asked a similar question a couple of days ago in the
thread about upgrading to facelift LEDs.
I'm also on prefacelift EURO LEDs and wanting to do the same.
I'm expecting for EURO originals that its just the indictor wire that needs carrying over from outer to inner light as we don't have indicator on the original LED inner but we have everything else (i think).
Using the coding noted in the above thread I've been having a think about the updates. At this stage it could all be wrong but maybe worth a go if you have the lights in and can report back?
Obviously note your existing coding in case you are different to mine for some reason.
I've put my original EURO coding then what I think I would try based on that thread. You'll need to compare your US coding and update where needed.
For some reason on the thread link above they all miss out Ch 199 - 202 so I'm thinking US cars don't need to adapt those channels (probably because they have the clear signal lenses on the inner lights already, unlike EURO that are all red).
So for EURO original LEDs like mine I think I need to swap the channels around (see below) so the light signals swap on the pins and light up correctly (but I could be totally wrong).
For US you may not need to make that swap and just leave Ch 199 - 202 as they are (again I could be wrong)
Please anyone else who has done this correct it.
181 - Reverse Light Warning - 65535 --> 0
195 - Signal left outer - 7811 (try 14849 - becomes Red Stripe DRL)
196 - Signal right outer - 7843 (try 14881 - becomes Red Stripe DRL)
197 - Brakes left outer - 5124 (try 5125 (not sure why these are 1 byte different to what we already have))
198 - Brakes right outer - 5156 (try 5157 (not sure why these are 1 byte different to what we already have))
199 - Signal left inner - 133 (try 12 (Euro original - Swap with original Brake left inner to become the new brake left inner - If US original, perhaps keep original)
200 - Signal right inner - 165 (try 44 (Euro original - Swaps with original Brake right inner to become the new brake left inner - If US original, perhaps keep original)
201 - Brake left inner - 12 (try 133 (Euro original - Swap with original Signal left inner to become the new signal left inner - If US original, perhaps keep original)
202 - Brake right inner - 44 (try 165 (Euro original - Swap with original Signal right inner to become the new signal left inner - If US original, perhaps keep original)
203 - Fog left - 73 (Keep or try 12)
204 - Fog right - 105 (Keep or try 44)
205 - Reverse left - 13 (Keep)
206 - Reverse right - 45 (Keep)
207 - Left inner tail, ch/lh - 5 (Keep or try 73 - swaps the position with old fog light left)
208 - Right inner tail, ch/lh - 37 (Keep or try 105 - swaps the position with old fog light right)
209 - Left outer, park ch/lh - 0 (Keep or try 12 - swaps the position with old Brake left inner)
210 - Right outer, park ch/lh - 0 (Keep or try 44 - swaps the position with old Brake right inner)
