Results 1 to 30 of 30
    Apr 17 2008
    Boston, MA
    3.0T stage 2 - spark plug recommendation?
    I'm about to go APR stage 2 (SC pulley only) with my 2012 A7 and I would like to change the spark plugs at the same time. I contacted APR tech support and they recommended NGK 2668 BKR8EIX with .028" gap. I was curious to see if that's what everyone is running or if there is a better option that I should consider?
    Jun 12 2019
    MK5 Rabbit 2.5 5spd
    Natick, MA
    Interested in this as well, recently went apr single pulley, only 33k miles on the car so not due for plugs yet and have not had any issues, but curious to see what the consensus is
    2016 A6 P+ 3.0T / Aviator Blue Metallic / APR Stage II Single Pulley 93 Octane / BG_SQ5 tcu / MercRacing hx v3 / Hartmann Rotor Reps 20x9 ET40 w/ 265/35-20 PS4S / 0-60 3.56 sec
    Veteran Member Four Rings bajan01's Avatar
    Jan 11 2018
    2018 VW Atlas, 2016 VW Golf
    Florida
    Quote Originally Posted by Devil_Inside View Post
    Those should be fine. Stage 2+ guys might run 9EIX gapped to 0.024” or lower. When I switched to a higher ethanol blend I went back to 8EIX from 9EIX on my dual pulley SQ5 gapped to 0.024”. I am currently running NGK coppers in my single pulley S4 and plan to do the same on my SQ5, but those will be swapped out every oil change. 8EIX should be fine for you, datalog and see if everything looks good with them.
    Veteran Member Four Rings f4m0u5's Avatar
    Aug 04 2014
    Gloucester MA USA
    Im running .026 gap on stock ngk plugs on a stage 2 single pulley setup as requested by epl
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    I'm running STG2 DP+TB E40, plugs are NGK BKR9EIX @ .026 per John at IE :) I was running the same plug and GAP on 93
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
    Sep 10 2019
    Fl
    APR Stage 2 DP running NGK 2669 gapped to 0.26
    Veteran Member Four Rings 07S6's Avatar
    Sep 17 2010
    I've been asking around the forums and APR dealers the very same question for my APR single pulley A7, and there doesn't seem to be any consensus between the stock NGK (Platinum) or the BKR8EIX (Iridium) for single pulley. I've been single pulley on stock plugs for the past 2-3 years and have not noticed any issue.
    I'm due for my second plug replacement at 110K miles, and may give the Iridiums a try in the next couple of weeks just for the heck of it.. If i'm not mistaken, the Iridium plugs may need more frequent replacement than the stock.
    2012 A7 Prestige, Innovation Pkg, Sport Pkg, B&O / APR Stage2, AWE Touring, Injen intake
    2012 A6 Prestige - Phantom Black/Nougat/Innovation Pkg. (sold)
    2007 S6 5.2L V10 (sold)
    Senior Member Three Rings dc2002's Avatar
    Jan 29 2007
    Roswell GA
    Quote Originally Posted by f4m0u5 View Post
    Same here
    2012 A6 3.0T Prestige
    EPL Stage 2
    Sep 17 2010
    Just ordered NGK 2668 BKR8EIX. I guess I'll gap them to .028" and hope for the best! If the car complains one bit, i'll go right back to stock plugs..
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by 07S6 View Post
    id put them at .026 still
    Junior Member Two Rings
    Jan 17 2018
    2020 VW Atlas SE W/tech 2.0t with a JB1
    san antonio
    Quote Originally Posted by bajan01 View Post
    I prefer to run copper plugs as well going back to my LT1 and LS1/2 days, what copper plugs are you running?
    Jan 11 2018
    Florida
    Quote Originally Posted by back13a6 View Post
    NGK R5671A-8 (4554) in the S4 gapped to 0.023” and BKR8EIX in the SQ5 until I can swap the 4554s into that too.
    Jan 17 2018
    san antonio
    Thanks for the quick reply. No issues running the copper plugs? I know they are a better conductor, but wear faster.
    Jan 11 2018
    Florida
    Other than replacing every oil change...no issues. Once I put a set in the SQ5 and get some race gas in there I’ll grab some logs and see how they work at that extreme.
    May 26 2020
    Lakewood Ranch, Florida
    Following. Currently APR stage 1. Will be Stage2 SP by year end.
    Mar 11 2007
    Colorado Springs
    I am stage II dual pulley with stock plugs and see no reason to change. The car is rock solid and runs like a top!
    2022 Q8 S line Prestige Stock
    2012 A7Plus APR Stage II+ UC
    2012 A8L 4.2
    Still own them all...
    Established Member Two Rings chydog's Avatar
    Jan 29 2017
    1996%20Impala%20SS
    Barrie, Ontario, Canada
    Quote Originally Posted by A6sport View Post
    i definitely noticed better throttle response with the apr spec;d NGK BKR9eIX plugs, especially at initial throttle tip-in, my crec motor had just under 40K on it when tuned in september this year so perhaps new plugs were in order but the power definitely comes on earlier for me, I'm stage 2 91 octane S/C single pulley only, for an hours work and $50 i would try it if i were you
    2016 A6 S-Line Oolong Grey, Carbon Fiber wrapped roof/Mirrors - EBC Brakes slotted + yellowstuff pads, Renntech Monolite wheels 19x9 et39, debadged Stonecarbon RS6 grille and APR stage 2
    1996 Impala SS BBB - 383 forged stroker LT1, GM 846 cam, Advanced induction 200 cc heads + valvetrain, 3.73 rear, denny's driveshaft
    Veteran Member Four Rings JWebb_C7_Comp's Avatar
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    What does a slightly smaller gap due for performance? Is it less likely to allow misfire as plugs start to wear?
    Aug 04 2014
    Gloucester MA USA
    Quote Originally Posted by JWebb_C7_Comp View Post
    it prevents spark blow out, theres alot of pressure in the Cylinder and the boost is rushing into the motor by the spark plugs. it will help with throttle response and stop any hiccups
    Jan 11 2018
    Civic, A6, Q7
    Chi-Burbs
    Learn something new every day; thanks.
    Sep 17 2010
    Looks like the BKR8EIX are on back order, so I switched my order and just got the much pricier stock NGK PFR8S8EG that Audi switched to in the last couple of years.
    The gaps are measuring .030-.031
    I’m gonna reduce it to around .028 before installing. Engine mounts are waiting for installation at same time..
    Sep 17 2010
    Got the new NGK PFR8S8EG plugs swapped in yesterday. Looks like they matched the OEM version of the same plug that was in the car for the past 45K miles and 2.5 yrs as stage 2 single pulley. The car felt really great on the way home and pulls strong and of course, with the new motor mounts, I can barely tell it’s running on idle with zero vibration whatsoever.
    I tightened the gap to roughly .029 before installing. The old ones that came out were around .031 with no perceptible issues. A dealer tech friend installed them during my oil change and the only strange thing I noticed was the sticky oily residue on the threads of 2 or 3 of the plugs (on the plug to the right).
    Should I be concerned? Car doesn’t burn through oil or anything.
    Established Member Two Rings dspl1236's Avatar
    Dec 15 2007
    '90 90q 2.6, '90 GTI 3.6, '12 A6 3.2T
    Akron, Ohio
    NGK R5671A-8 (4554)@.025 snappy throttle even in the cold. Just going todo these every oil change
    Came from stock plugs, stock gap, UM tune, upper pully, will be adding the lower soon. Was stumbly at idle. Smooooth now.
    '13 A6 3.0T + '90 Jetta 2.0T 20v + '92 Corrado SLC + '90 90q 2.6 20v + '90 GTI Plum 3.6 VR6 + '89 200 10vt + '12 A6 3.2T + '01 A8
    Gone: '91 200TQA, '90 V8Qm, '97 A4 1.8T, 2x '98 A4 1.8T, '90 80Q, '90 CQ, '91 CQ, '91 CQ 1.8T, '91 200TQ, '95 90cs, '01 Jetta 1.8t, '08 Passat 2.0T, '13 GLI, '76 Audi Fox, '04 1.8T USP
    Apr 17 2008
    Boston, MA
    I ended up installing the recommended NGK 2668 BKR8EIX with .028" gap and the car ran great for the short amount of time I drove it prior to trading it in. Thank you all for the recommendations and input on this subject.
    Dec 25 2019
    Howell, MI
    You gonna have to swap those BKR plugs out more often. Everyone seems to run them but forgets the PFR8S8EG plugs are oem are laser platinum and last longer than those BKR plugs.
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Corydms7 View Post
    The BKR's are Iridium
    "Iridium is said to be six times harder and eight times stronger than platinum with a 700° higher melting point. Iridium spark plugs have extremely fine electrodes while retaining excellent wear characteristics. Thanks to its strength, iridium spark plugs can last up to 25% longer than comparable platinum spark plugs."
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Veteran Member Four Rings Alabama's Avatar
    Apr 19 2020
    C7 S6
    Birmingham Alabama
    Quote Originally Posted by gk1 View Post
    You and your facts! Do you know if there are any conditions where iridium might not perform as well as platinum (e.g., non-standard fuel, etc.)?
    2014 CPO S6, SunTek PPF (applied by CGS Vinyl), BlackVue dashcam (installed by Radio Active), Hawk Brake Pads/Zimmermann Rotors/Goodridge SS Brake Lines, H&R sway bars, Alu Kreuz, 034 Drivetrain Mount Inserts, SRM Driveshaft Carrier (mechanical/maintenance by Franklin Automotive)
    Dec 25 2019
    Howell, MI
    But they are LASER platinums. Laser platinums do last a tad longer than iridium’s.
    Aug 06 2014
    NJ->CO
    Perhaps, but even NGK compares their latest (greatest) Ruthenium plugs to their Iridium instead of Platinum so assumption is Ruthenium>Iridium>Platinum
    https://ngksparkplugs.com/wp-content...Y-1024x591.jpg
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Veteran Member Four Rings Audibellybutton's Avatar
    Jun 28 2019
    California
    brisks definitely. but they have a shorter life span than iridium/platinum
    C7 Audi A7 Prestige 3.0t (RIP) - Dual Pulley E40 , Turtle TCU , Ported Blower, Meth, Porsche 997 TB, Merc Racing Heat Exchanger, CWA-100, RKX Silicone Intake hose, RS7 Airbox, RS7 LPFP, JHM 207 pulley,SRM Driveshaft Upgrade, H&R Springs, 034 Drivetrain inserts, Vossen VFS2, RS7 Steering Wheel, Autotech HPFP
    C7 Audi S6 Prestige 4.0t (Current) - ZF8 Swap, E85 tune W/ FE STG2 Turbos, WMI, Merc Racing HX, EMP Coolant Pump,GFB DV+,LPFP upgrade, ECS Inlets, TS Gates, Exhaust
    IG:@stolens6
