Results 1 to 7 of 7
    Sep 28 2009
    suburb
    Do I need endlinks?
    034 has a sway bar sale.
    Endlinks are a big portion of sway bar cost.
    Do they really add that much difference? I just want it a little tighter during turns. Car is already lowered on KW HAS kit -- will sway make ride worse?
    Audi S7 stage 3 w/srm turbos
    Audi B8 S5 stage 3 w/apr supercharger
    Audi SQ7
    Audi Q5 3.0 EPL stage 2 single pulley (gone)
    Audi Allroad 2.7 stage 3 (gone)
    Audi B5 S4 stage 3 (regrettably gone)
    Audi B8 S5 (gone)
    Veteran Member Three Rings Mrads's Avatar
    Dec 20 2012
    '13 Daytona RS5, '14 Subaru Outback (wife's DD)
    New Westminster, BC, Canada
    Sways won't make the ride quality worse. They will improve cornering and depending on how they are setup, they can improve turn-in and reduce understeer. Solid/adjustable end links transmit more noise and vibration into the car so you might categorize that as a worse ride.
    Adjustable end links aren't really necessary for street use. I run solid, non-adjustable end links on my RS5.
    Sent from my Pixel 4 XL using Tapatalk
    Established Member Two Rings Lamayeee's Avatar
    Apr 17 2020
    San Francisco, CA / Eugene, OR
    I heard that 034 end links will creak so if you don’t like random noises you might want to go with a different brand
    2014 Suzuka Grey Metallic RS5
    Black Optics Pack / B&O / Driver's Assist
    KW DDC
    1/1 Valvetronic Designs Exhaust
    K&N Drop-in Filters
    034 Transmission Insert
    Variant Argon 20x10 ET20
    Jan 24 2008
    Pennsylvania
    Since the 034 end links have spherical bearings instead of rubber, they will improve the performance of the suspension (reduced deflection, etc) and give the suspension a more precise feel. The casual driver might not notice much of a difference between stock and spherical end links though.
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Sep 28 2009
    suburb
    Cool thanks for the info. I think I will just go sway bar then.
    Audi SQ7
    Audi B8 S5 (gone)
    Feb 07 2018
    PDX ish
    The 034 endlinks are all metal vs the rubber body of the OEM b8's. Seems like its more then just the bearings. Having held the two side by side there is a major difference in feel and rigidity. Not a suspension expert so just an observation. Mine make no noise, and I don't have the rubber outer boots.
    2011 S line Prestige A4 Avant - 3.0t swapped
    EPL + 034 Stage 2+ DP ECU tunes| EPL TCU | CTS 187/57 | Roc-Euro Intake | PLM V2 Heat Exchanger | HR coilovers | Front BBK SPM Alcon 375mm | Rear BBK Voshmod 356mm| Milltek full resonated exhaust | test Pipes | 034 Endlinks | RS5 FBSW | 3g+| Deval CF Diffuser| BFI Knob | P3 Gauge| S4 Panda seats| Beaufort Aluminum Trim | RS5 Piano black MMI | S5 gauge trim
    Veteran Member Four Rings Ape Factory's Avatar
    Jun 24 2017
    RS5/Infiniti QX70S stormtrooper/Jeep Wrangler Rubicon 10th Anniversary
    San Antonio, TX
    The only reason to run end links is if your lowered. The 034's and others from Eurocode and ECS are all "adjustable". They're adjustable so you're not adding any pre-load to your sway bars. If you lower your car, the OEM links will pre-load the sway bar and it'll diminish the car's handling potential.
    Sways can make the ride quality worse as what you're doing is effectively increasing the spring rate. You're tying up an independent suspension if that makes sense.
    On the creaking, I have 034 rears and the initial set I had were horrible and made nails on chalkboard horrible noises. 034 determined there was a machining error and replaced mine. Going on two years with no abnormal noises. With that said, they are sealed spherical bearings and they will eventually wear causing "clacking" noises as you go over bumps. The bearings are end user replaceable however. Just don't expect them to stay silent forever like the OEM end links.
    I just ordered a set of the fronts through JHM but I suspect they'll perform just like the rears. If you do purchase a set, make sure to install them correctly and have a way to put the car up on a lift via the wheels so you can adjust them to a neutral position. One can, theoretically, adjust them to favor a car turning left or right.
    Instagram: redmist5 Youtube; https://tinyurl.com/redmistvideos
    2013 Audi RS5 Misano Red-Klassen ID M10/JHM Tune/AWE Exhaust/Eventuri Intake/Bilstein PSS10/H&R Sways/STERN/CR-15//ECS SS Brake Lines/Rear Diff Bushing/ECS rear diff inserts, front end links/034 Motorsports subframe inserts & Rear End Links/Tranny insert/E-code head, tail lights/Maxton splitter/Red Trim Start Button/black emblems/VCDS.
