Results 1 to 21 of 21
    Deactivated Two Rings
    Nov 11 2020
    Lake Tahoe, CA
    For those that have Milltek exhaust, have a few questions
    In looking through the options for exhaust, I’m fairly certain about Milltek being the choice but I’m curious about resonated versus non resonated. Sound clips are awesome but it’s hard to get a real life feel of just how loud it is. For those that have non resonated, are you still on good terms with the neighbors, or would you have gone resonated if you could do it again?
    Nov 03 2016
    CA
    I have the non resonated exhaust.
    It’s honestly still very tame. The sound insulation on the B9 is very good, but the exhaust has okay volume outside.
    If you want to be loud, you will definitely need a catless downpipe or a high flow cat.
    My blowoff valve is louder than my exhaust.
    2011 Audi S5
    (GONE) 2011 Audi A5 2.0T [APR STAGE 2] [034 MotorSports HFC]
    Veteran Member Three Rings Rob01S4's Avatar
    Jan 29 2006
    2024 C8 Stingray Z51
    Delray Beach, FL
    I have non resonated and I agree it’s still tame. I will most likely add the middle resonator if/when I go catless or sport cat in the future just in case.
    2019 Navarra Blue S5 Sportback
    CarbnLab/iE/034/TTE810/Milltek/Unitronic
    Nov 11 2020
    Lake Tahoe, CA
    Thanksis guys for the info. Will be doing the down pipe as well. I’m definitely not looking for the loudest. Any of you have the optional Milltek valve control?
    Veteran Member Three Rings Dais0948's Avatar
    May 04 2018
    New Jersey
    Quote Originally Posted by Sierra Audi View Post
    For what its worth I spoke with a few venders and they recommended resonated if you are cat less or have sport cat because of excessive drone. I have a sport cat on the OE cat back and its twice as loud as stock.
    2019 S4, IE stage 3 + TTE710.
    Nov 03 2016
    CA
    Both the resonated and non resonated are valved
    2011 Audi S5
    Nov 11 2020
    Lake Tahoe, CA
    Quote Originally Posted by Dais0948 View Post
    This is very helpful. Last thing I want is highway drone.
    - - - Updated - - -
    Quote Originally Posted by brilliant_black View Post
    Feb 27 2019
    Los Angeles, CA
    Here is non-res with sport cat:
    https://youtu.be/vjHLXnZVRYM
    Jan 26 2019
    Quote Originally Posted by RoB9 View Post
    That sounds ridiculously good! Any CEL with the CTS dp?
    Feb 27 2019
    Los Angeles, CA
    Yes, this one does give you a CEL.
    Nov 11 2020
    Lake Tahoe, CA
    Sounds real nice. Is there a workaround for eliminating the CEL? I’m planning on going with a 200 cell cat.
    Jan 29 2006
    Delray Beach, FL
    Custom tune shops will do it. Most other companies like EPL or APR won’t. I would go with EPL and live with the cel
    Nov 11 2020
    Lake Tahoe, CA
    Quote Originally Posted by Rob01S4 View Post
    Only prob would be when required smog check comes around for registering in CA. Can’t have a check engine light illuminated or it will fail.
    Jan 29 2006
    Delray Beach, FL
    I would consider a sport cat that would have less chance of cel or get a custom tune.
    Nov 11 2020
    Lake Tahoe, CA
    [QUOTE=Rob01S4;14354545]I would consider a sport cat that would have less chance of cel or get a custom tune.[/
    Milltek makes the 200cell DP, any idea if that would work?
    Nov 11 2020
    Lake Tahoe, CA
    Assuming the increased airflow is causing the CEL? Just wondering if a spacer on the O2 sensor would be the fix?
    Feb 27 2019
    Los Angeles, CA
    No to spacers for now and the Milltek probably won't work. The one that seems to not have a CEL is the RedStar but that's pricey AF.
    Nov 11 2020
    Lake Tahoe, CA
    Got it. Thanks for all the info RoB9.
    Veteran Member Four Rings BrockDM's Avatar
    Jan 21 2018
    Orland Park, IL
    As Dias said above, the best combo if you plan on running a downpipe/test pipe is:
    Catless/Cat delete? Get resonated catback.
    Quality high flow cat? Get nonresonated catback.
    If you want a nice tone and the benefits of a full exhaust but don't want it loud, get a high flow cat and resonated. On the flip side, it is NOT recommended to get a cat delete and nonresonated. Multiple people have said it's incredibly loud and the drone is very annoying.
    I personally run the Milltek cat delete with the stock exhaust and it's perfect for me. Definitely not quiet but not over the top. Anymore and I'm sure my neighbors would speak up.
    Here's my current setup:
    Nov 11 2020
    Lake Tahoe, CA
    Quote Originally Posted by BrockDM View Post
    That’s very nice Brock. Essentially what I’m after. I’ll definitely be running some sort of catted DP, so non resonated seems to be the right call.
    Nov 03 2016
    CA
    I came from a muffler and resonator deleted 4.2 S5 so this miltek non res catback feels silent lol
    2011 Audi S5
