Hey all,
I'm looking to add the driver side front mounted lower radiator from the S3/Golf R to my 2017 A3 S-Line. Currently I'm getting a parts list together to tackle this project. The parts for the radiator, mounting bracket, and ducting seem to be straightforward. I've compiled a list of the following parts which should complete the mounting of a new radiator and allow air to pass through properly:
1 x Radiator - 5Q0121251HA (Planning to use a CSF DSG Cooler for this)
1 x Radiator Mount Bracket - 5Q0121093BF
1 x Air Duct - 8V3807681AEESM
1 x Air Duct - 8V0121673B
1 x Air Duct - 8V0117339
1 x Protective Grill - 5Q0121557A
1 x Inner Fender Liner - 8V5821171B
Next is connecting to the A3's coolant loop. I'm trying to find out exactly what is needed here to run the system like the S3. I've been looking at diagrams of the A3 and the S3's coolant systems trying to figure out how the connection to the system would work.
Based on this diagram, I've come up with the following parts:
1 x Coolant Hose - 5Q0121051L
1 x Coolant Hose - 5Q0121101P
1 x Hose Bracket -5Q0121093BD
1 x Coolant Hose Adapter - 5Q0122291CJ
4 x Spring Band Clamp - N90687001
There must be more parts needed for the connection but not sure what else is needed. Any feedback would be greatly appreciated!
~James
