Results 1 to 7 of 7
    Oct 09 2009
    B8 S4, B5 A4 Stage 1
    Fremont, CA
    iPhone 12 (iOS 14) with Tune2air Issues
    Hey all,
    I searched the B8 S4 and A4 forums and couldn't find a solution. Ever since receiving my iPhone 12 Pro with iOS14, I've been having issues with my Tune2air. The Tune2Air has a stable connection to my phone as I can see my phone is connected via bluetooth. However, the Audi MMI drops the connection to the Tune2Air unit after about 5 seconds. Which is frustrating, because this shows the bluetooth connect CAN works since I can hear music streaming for 5 seconds, but then it just stops. I have tried the following:
    1. Disconnecting and Reconnecting Bluetooth (Result: No change, still disconnects after 5 seconds)
    2. Forgetting Tune2Air as device and repairing (Result: No change, still disconnects after 5 seconds)
    3. Bought a new Tune2Air! (Result: No change, still disconnects after 5 seconds)
    Lastly, I have tried downloading the latest firmware from Tune2Air, but the company has not gotten back to me via email with a license code that I can use to access the firmware. (What a dumb system). Any ideas here? I may just resort to buying one of the FM transmitters...
    Delivered 12/31/09
    Audi 2010 S4 Meteor Gray 6MT
    Prem + // Nav // B&O // Sport Differential // 19" Wheels // Carbon Inlays
    Mods:
    License Plate LED - 1.03.10 // 6000K HID - 1.10.10 // Interior LED - 1.10.10
    Clearbra - 1.12.10 // 30% Tint - 1.12.10 // Hoen Endurance Fogs - 1.15.10
    JHM Short Shifter - 2.22.10 // Vagcom'd - 3.5.10 // HRE M40 19x9 - 4.6.10
    APR Exhaust - 4.6.11 // H&R OE Sport Springs 4.6.11
    Veteran Member Four Rings JACKAL's Avatar
    Mar 28 2017
    Infiniti QX70S, Indian Scout Bobber
    Southeastern Wisconsin
    Quote Originally Posted by Nvius View Post
    Hey all,
    I am in the exact same boat. It's extremely frustrating and I also have not found a solution. I've never been overly impressed with Tune2Air, but I'm about ready to throw in the towel and give Apple CarPlay a try.
    B8 Sprint Blue S4 | 6MT | 034 Motorsport Stage 2+ E40 (3.40 PR) | Tampa Autosports Ported Blower | AEM Water/Meth 1000cc | Test Pipes | CTS Turbo Downpipes | MF 11385 | AWE Touring | Injen Intake | 75mm Ported TB | Merc Racing HX | Stoptech 6 Piston BBK | Stainless Brake & Clutch Lines | SB Stage 3 End. Clutch | Eurocode Short Shifter | D-Steering Wheel | Autotech HPFP | 034 Motor Mounts | Low Kick Spoiler | RS Bumper | Verde V99 19x9.5 Wheels
    Veteran Member Three Rings BR11S4's Avatar
    Apr 29 2019
    Cincinnati, OH
    Same. I constantly have to now hit the power button on tune2air in glove box. Once it restarts its fine for awhile.
    Oct 09 2009
    Fremont, CA
    Disappointing to here you guys are having the same issues.
    @Jackal, is there a way to add Apple Car Play to our B8's?
    Delivered 12/31/09
    Mods:
    Mar 28 2017
    I believe so. I ordered something yesterday on Amazon and I’m going to give it a shot when it arrives either tomorrow or Sunday so stay tuned. From what I’m told in the ‘RSNAV Alternatives’ thread, it should be a much better option. I will report back as soon as I have something to share.
    Jul 14 2013
    British Columbia, Canada
    No issues with me on ios14 with my iPhone 12 pro and Tune2Air. Could be the software on your device itself, have you tried erasing the phone without loading any of your data to see if it continues to disconnect?
    2011 Phantom Black Effect S4 6MT Prestige, Sport Differential, Flat-Bottom Steering wheel with red stitching, RS4 Aluminum pedals, 034 Transmission mount, Roc-Euro Intake, Roc-Euro Short Shifter, 90mm AWE Touring Exhaust with stock downpipes, Unitronic Stage 2+, JHM 179mm Overdrive Crank Pulley, MercRacing heat exchanger, Stasis rear sway bar, CR-15, Gloss Black RS4 Grille, Sachs Xtend Clutch, 034 Density-Line Motor Mounts, Bilstein B12 Suspension Cup-Kit
    Established Member Two Rings sbw's Avatar
    Aug 26 2008
    2013 S4 White - 2012 Grand Cherokee Grey
    I noticed my 12 pro had connected but didn’t display song data from Spotify using bluetooth and the 3G MMI. Only reason I’m pointing it out is because I’m not using Tune2Air and figured you guys should be aware something seems to be affecting it. I assumed it was an issue with iOS. I just upgraded to iOS 14.2 and will see if that improves things.
