Where on the scan tool I can isolate the misfire ? Of course if it's only on a specific cylinder I can switch a coil pack to see if it's a coil pack issue. The spark plugs are changed in June by Denso IK22 or 24 I don't remember.
The error code will tell you which cylinder(s) is misfiring.
I changed the pcv valve in June but with a Chinese part. How can I verify if it's a pcv valve issue ?
Regarding the PCV valve, first carefully pry the top round cap off. The rubber diaphragm and spring are underneath. Make sure the diaphragm is not torn and the area under it is clean. If not, clean with brake cleaner (not carb cleaner) and Q-tips, then reassemble. It's very easy to do. Carefully detach the corrugated tube that runs to the IM at the IM and PVC valve and inspect it for cracks and degraded rubber O-rings. The connection points are easliy broken so take you time disconnecting the tube. (It helps to push the tube on with a little wiggling, then press the lock ring and then pull off also with gentle wiggling.) Make sure the check valve in the PCV valve is working by blowing into the port towards the valve cover. Absolutely no flow should occur, but when sucking on it (don't let the neighbors see this part) it should flow freely towards the IM. Also, carefully inspect for cracks the other corrugated tube that runs from the most rear port of the PCV valve to the oil filter housing.
If you want to run your car with the PCV valve isolated to see if it runs any differently, do the following: Leave the rear tube connected to the PCV valve. Securely place a rubber cap over the IM port. Also, block the port on the PCV valve that attaches to the tube going to the IM (2nd to the rear). In this configuration the IM will not be drawing any blow-by gas directly into the IM. Also, in this configuration, the diaphragm valve will not be activated so all blow-by pressure should flow through the PCV valve directly to the right front pre-turbo breather port. To verify you are not pressurizing your crankcase, run engine at idle RPM with the oil fill cap loosened but still in place. There should be no pressure trying to push the oil fill cap off the VC. Have your mother-in-law in the driver's seat raise the engine RPM (no more than 2000RPM) to see if there is any increase in pressure pushing the cap off the VC. If no pressure increase secure the oil fill cap and take the car for a short drive to see if it runs any differently. If not, you can conclude that the PCV valve is not the source of your problem. Reconnect the tubes to the IM and PCV valve.
