Results 1 to 2 of 2
    Nov 15 2020
    New Hampshire
    Smile Solved: 2004 Allroad - Bosch 5.0, 5.3 or 5.7 ABS?
    I recently replaced the ABS module in my 2004 Allroad 2.7T. The used one I installed had the same part number on it as the original, "8EO 614 111 AS" and looked identical in all aspects as the original. I'm confused as the number matches for a 5.3 but the module and connector looks like a 5.0? Does this mean the actual control module is under the rear seat? I've been trying to code it assuming it was a 5.7 but according to some sites the 5.0 with ESP uses 5.3 coding with ESP? Anyone code an Allroad ABS module recently? Did you code as a 5.3 or a 5.7?
    Nov 15 2020
    New Hampshire
    SOLVED: Not sure how many know this as no one responded but in my 2004 Allroad the ABS computer is NOT in the ABS valve body like most Audi's. It is a hybrid Bosch 5.0 ABS valve body (under the hood) which uses a Bosch 5.3 computer shared with the Electronic Stability processor located in the passenger footwell just below the glovebox. You program it as a Bosch 5.3 ABS
