Results 1 to 14 of 14
    Senior Member Two Rings Ayo_wtf's Avatar
    Sep 13 2019
    12' Ford Raptor Supercrew, NA 92' Mazda Miata, Z31 86' Nissan 300zx
    Miami, FL
    Car not starting multiple fault codes?
    Hey guys so I finally got my ross-tech cable in and I ran the codes on my car to see what the issue is and these are the results I got. Can anyone help me out and make sense of whats the issue? Should I clear the codes and try to start it?
    Saturday,14,November,2020,16:42:24:26645
    VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
    VCDS Version: 20.4.2.0 (x64) HEX-V2 CB: 0.4513.4
    Data version: 20200730 DS317.0
    www.Ross-Tech.com
    VIN: WAU2FAFC8HN076611 License Plate:
    Chassis Type: FC-AU57 (4G8)
    Scan: 01 02 03 05 08 09 13 15 16 17 19 1B 20 22 28 34 36 3B 3C 42
    44 46 52 53 55 5F 62 6C 6D 72 82 85 8B 8E 8F 90 A9 BA
    VIN: WAU2FAFC8HN076611 Mileage: 46458km-28867miles
    01-Engine -- Status: Malfunction 0010
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: OK 0000
    13-Auto Dist. Reg -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: OK 0000
    19-CAN Gateway -- Status: Malfunction 0010
    1B-Active Steering -- Status: OK 0000
    20-High Beam Assist. -- Status: OK 0000
    22-AWD -- Status: OK 0000
    28-HVAC, Rear -- Status: OK 0000
    34-Level Control -- Status: Malfunction 0010
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    3C-Lane Change -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: Malfunction 0010
    52-Door Elect, Pass. -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    5F-Information Electr. -- Status: Malfunction 0010
    62-Door, Rear Left -- Status: OK 0000
    6C-Back-up Cam. -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    82-Heads Up Display -- Status: OK 0000
    85-On Board Cam. -- Status: OK 0000
    8B-Adaptive Cruise 2 -- Status: OK 0000
    8E-Image Processing -- Status: OK 0000
    8F-Pretens. Frt Left -- Status: OK 0000
    90-Pretens. Frt Right -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    BA-Motor Mounts -- Status: Malfunction 0010
    Address 01: Engine (------CTGE) Labels:. 06E-907-551-CGW.clb
    Part No SW: 4G0 906 014 D HW: 4H0 906 014
    Component: 4.0l V8TFSI / H63 0001
    Revision: NCH63---
    Coding: 1A2500326546010E3000
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_ECM40TFS0114G0906014D 001001
    ROD: EV_ECM40TFS0114G0906014D.rod
    VCID: 2313EB070B5379436F1-8076
    9 Faults Found:
    4527 - Coolant Fan Control Circuit 1
    P0480 00 [036] - Electrical Malfunction
    Intermittent - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 12
    Mileage: 46459 km
    Date: 2020.11.01
    Time: 09:44:53
    Engine speed: 0.00 /min
    Normed load value: 0.0 %
    Vehicle speed: 0 km/h
    Coolant temperature: 30 °C
    Intake air temperature: 30 °C
    Ambient air pressure: 1010 mbar
    Voltage terminal 30: 11.756 V
    Unlearning counter according OBD: 40
    Engine status: COENG_READY
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 1
    4528 - Coolant Fan Control Circuit 2
    P0481 00 [036] - Electrical Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 15
    Mileage: 46459 km
    Date: 2020.11.01
    Time: 09:44:53
    5456 - Starter Will Not Turn
    P3054 00 [229] - Jammed or Electrical Malfunction
    MIL ON - Not Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 46459 km
    Date: 2020.11.01
    Time: 09:44:51
    Voltage terminal 30: 11.449 V
    17876 - Exhaust Pressure Control Valve 2
    P049F 00 [047] - Malfunction
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 46422 km
    Date: 2020.10.31
    Time: 16:35:45
    Engine speed: 4032.00 /min
    Normed load value: 63.9 %
    Vehicle speed: 156 km/h
    Coolant temperature: 93 °C
    Intake air temperature: 54 °C
    Voltage terminal 30: 13.334 V
    Engine status: COENG_RUNNING
    Engine status-Test_Program_Co Eng st COMPU VERB UBYTE: 3
    7636 - Post-Catalyst Oxygen (Lambda) Sensor Correction; Bank 1
    P2096 00 [237] - Too Lean
    MIL ON - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 8
    Mileage: 41686 km
    Date: 2020.07.25
    Time: 10:04:12
    Engine speed: 1468.50 /min
    Normed load value: 23.5 %
    Vehicle speed: 85 km/h
    Coolant temperature: 99 °C
    Intake air temperature: 43 °C
    Voltage terminal 30: 13.970 V
    22593 - Fuel Level Sensor Circuit
    P0461 00 [096] - Implausible Signal
    15356 - Oxygen (Lambda) Sensor Signal B1 S2
    P2270 00 [096] - too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 44893 km
    Date: 2020.09.26
    Time: 22:14:09
    Engine speed: 1560.00 /min
    Normed load value: 17.3 %
    Vehicle speed: 75 km/h
    Coolant temperature: 100 °C
    Intake air temperature: 52 °C
    Voltage terminal 30: 13.452 V
    Unlearning counter according OBD: 2
    Rear cat conv temp main cat conv model value: 498.58 °C
    O2 sens. dwnstrm. of cat.: gradient transf. rich -> lean: 0.10 s
    O2 sensor dwnstrm. of cat.: gradient transfer lean -> rich: 0.16 s
    O2 sensor dwnstrm. of cat.: delay time transf. rich -> lean: 0.00 s
    O2 sensor dwnstrm. of cat.: delay time transf. lean -> rich: 0.42 s
    20040 - Oxygen (Lambda) Sensor Signal B2 S2
    P2272 00 [237] - too Lean
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 46120 km
    Date: 2020.10.24
    Time: 05:31:56
    Engine speed: 1659.00 /min
    Normed load value: 29.0 %
    Vehicle speed: 96 km/h
    Intake air temperature: 48 °C
    Voltage terminal 30: 13.853 V
    Rear cat conv temp main cat conv bank 2 model value: 625.91 °C
    O2 sens. dwnstrm. of cat. bank 2: gradient transf. rich -> lean: 0.09 s
    O2 sens. dwnstrm. of cat. bank 2: gradient transf. lean -> rich: 1.50 s
    O2 sens.dwnstrm. of cat. bank 2: delay time transf.rich -> lean: 0.00 s
    O2 sen dwnstrm. of cat. bank 2: delay time transf. lean -> rich: 0.00 s
    4116 - Oxygen (Lambda) Sensor B1 S1
    P2196 00 [237] - Signal too High (Rich)
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 2
    Mileage: 44336 km
    Date: 2020.09.16
    Time: 09:01:40
    Engine speed: 2187.00 /min
    Normed load value: 35.3 %
    Vehicle speed: 128 km/h
    Coolant temperature: 98 °C
    Intake air temperature: 46 °C
    Voltage terminal 30: 13.711 V
    Readiness: 0000 0000
    Address 02: Auto Trans (J217) Labels:| 0B5-927-156.clb
    Part No SW: 4G0 927 166 F HW: 0B5 927 156 K
    Component: 0B5 40TFSINAR H03 0007
    Revision: --H03---
    Coding: 000001
    ASAM Dataset: EV_TCMDL501021 001022
    ROD: EV_TCMDL501021.rod
    VCID: 3039144B4AA5D2DBE23-8064
    No fault code found.
    Address 03: ABS Brakes (J104) Labels:. 4G0-907-379-V2.clb
    Part No SW: 4G0 907 379 S HW: 4G0 907 379 S
    Component: ESP9 Premium H01 0530
    Revision: -------- Serial number: --------------
    Coding: 65BED44BA67D2BD21B00
    ASAM Dataset: EV_ESP9BOSCHAU57X 004018
    ROD: EV_ESP9BOSCHAU57X.rod
    VCID: 41DF418FF10F4B531DD-8014
    6 Faults Found:
    124416 - Function Restriction due to Faults in Other Modules
    U1113 00 [032] - -
    [Ldm_ApbFailureState]
    154624 - Tire Pressure Warning
    C102D 00 [032] - -
    154880 - Tire Pressure Warning
    C102D 00 [032] - -
    155136 - Tire Pressure Warning
    C102D 00 [032] - -
    155392 - Tire Pressure Warning
    C102D 00 [032] - -
    161536 - Tire Pressure Warning
    C102D 00 [032] - -
    Address 05: Acc/Start Auth. (J393) Labels:. 8K0-907-064-05.clb
    Part No SW: 4H0 907 064 HR HW: 4H0 907 064 HR
    Component: BCM2 2.0 H61 0825
    Revision: 00002001
    Coding: 0DAA6F4E000000000000
    VCID: 0059848BBA05825B523-8054
    Subsystem 2 - Part No SW: 4H0 905 852 C HW: 4H0 905 852 C
    Component: J764 ELV MLB H40 0046
    Serial number: 3216000243939012
    Address 08: Auto HVAC (J255) Labels:| 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 BL HW: 4G0 820 043 BL
    Component: KLIMA 4 ZONEN H14 0113
    Serial number: 14111600040617
    Coding: 680330785D0000
    ASAM Dataset: EV_AirCondiComfoUDS 003008
    ROD: EV_AirCondiComfoUDS_003.rod
    VCID: 6A8DC623ACF9680BEC7-803E
    1 Fault Found:
    0276 - Engine Off Timer Performance
    P150A 00 [009] - -
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 2
    Reset counter: 52
    Mileage: 46114 km
    Date: 2020.10.24
    Time: 00:00:39
    Voltage terminal 30: 13.89 V
    Terminal 15 status: Terminal 15 on
    Address 09: Cent. Elect. (J519) Labels:. 4H0-907-063-V2.clb
    Part No SW: 4H0 907 063 GM HW: 4H0 907 063 AM
    Component: BCM1 2.0 H20 0368
    Revision: 21020001 Serial number: 00001517668002
    Coding: 01050011043C9FF2F90048C7A0007800CF9CC208AE08022180 00089C710017020060002D0B0000
    VCID: 79AFE96FD9DFD39315D-802C
    Subsystem 1 - Part No SW: 4G1 955 119 HW: 4G8 955 119 Labels: 1KX-955-119.CLB
    Component: WWS57X 160929 H38 0080
    Serial number: 161012075414
    Coding: 0045F7
    Subsystem 2 - Part No SW: 81A 955 547 A HW: 81A 955 547
    Component: G397_RLFS H06 0002
    Serial number: 20027967X81A955547A0
    Coding: 02006E
    Subsystem 3 - Part No SW: 4G0 941 531 AN HW: 4G0 941 531 AN
    Component: E1 - LDS H07 0044
    Serial number: 31 10 2016 00000277
    Subsystem 4 - Part No SW: 4G0 907 410 A HW: 4H0 907 410 A
    Component: USHL4.2 H30 0030
    Serial number: 00000000095Z027E4F2E
    Subsystem 5 - Part No SW: 4H0 907 705 K HW: 4H0 907 705 C
    Component: EVLS-SG H08 0300
    Serial number: WA125581000026235152
    Coding: 020300
    Subsystem 6 - Part No SW: 4H0 907 658 B HW: 4H0 907 658 B
    Component: AQ_Hum_Sensor H01 0005
    Serial number: 8E688A5800PAG0MUFU03
    Address 13: Auto Dist. Reg (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 561 B HW: 4G0 907 561
    Component: ACC3 H21 0055
    Serial number: 00000000000000
    Coding: 7E01010101
    ASAM Dataset: EV_AdaptCruisContrAU57X 002015
    ROD: EV_AdaptCruisContrAU57X_002.rod
    VCID: 290FF92F697FA31325D-807C
    Address 15: Airbags (J234) Labels:* 4H0-959-655.clb
    Part No SW: 4G0 959 655 B HW: 4G0 959 655 B
    Component: Airbag10.43 H62 0092
    Revision: -------- Serial number: 003G0003NWA1
    Coding: 303331333131303134334A55304C34473853
    ASAM Dataset: EV_AirbaAU10BPAAU64X 001014
    ROD: EV_AirbaAU10BPAAU64X_VW51.rod
    VCID: 3431185BBEBDEEFB86B-8060
    Seat occupied recognition:
    Subsystem 1 - Part No SW: 5C6 959 339 B HW: 5C6 959 339 B
    Component: BF-Gewichtss. H15 0046
    Serial number: 6940000Y160001JPJC07
    Crash sensor for side airbag: driver side:
    Serial number: 3575HRB405747OGUB06H
    Crash sensor for side airbag: front passenger side:
    Serial number: 3585HRB405D49IMA213
    Crash sensor for side airbag: rear: driver side:
    Serial number: 3515JRB4008579TIFOEW
    Crash sensor for side airbag: rear: passenger side:
    Serial number: 3525JRB4008579TIMQ5X
    Crash sensor for front airbag: driver side:
    Serial number: 3554VRB400S57HS6Q20.
    Crash sensor for front airbag: front passenger side:
    Serial number: 3564VRB400Q57HS6NH16
    Address 16: Steering wheel (J527) Labels:. 4H0-953-568.clb
    Part No SW: 4H0 953 568 G HW: 4H0 953 568 G
    Component: Lenks.Modul H05 0005
    Revision: -------- Serial number: 90372PKF000K3
    Coding: 0000FC
    VCID: 372B2F57AF4B05E3A39-8062
    Subsystem 1 - Part No SW: 8U0 951 528 H HW: 8U0 951 528 H
    Component: E221 - MFL H08 0010
    Serial number: 12 10 2016 A0015755
    Address 17: Instruments (J285) Labels:| 4H0-920-xxx-17.clb-SRI1
    Part No SW: 4G8 920 988 M HW: 4G8 920 988 M
    Component: TBenUsaAccNv H15 0225
    Revision: 15001307 Serial number: 658111116596019
    Coding: 0BC70107BF53D705020300
    ASAM Dataset: EV_RBD4K 004060
    ROD: EV_RBD4K_AU57.rod
    VCID: 44D1489BEE1D5E7B36B-8010
    Address 19: CAN Gateway (J533) Labels:* None
    Part No SW: 4G8 907 468 H HW: 4G8 907 468
    Component: J533--Gateway H15 0096
    Revision: -------- Serial number: 00000002436447
    Coding: C0ED074814
    ASAM Dataset: EV_GatewPkoUDS 002000
    ROD: EV_GatewPkoUDS_002_AU57.rod
    VCID: 3D273D7F8DF72FB3795-8068
    Battery Monitoring Control Module:
    Subsystem 1 - Part No SW: 8S0 915 181 B HW: 8S0 915 181 B
    Component: J367-BDMHella H10 9070
    Serial number: 2830052104
    Voltage stabilizer:
    Subsystem 2 - Part No SW: 8K0 959 663 F HW: 8K0 959 663 F
    Component: J532_DCDCStab H23 0022
    Serial number: 160903000000000003DA
    1 Fault Found:
    6657 - Generator
    U1052 00 [008] - No Communication
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 92
    Mileage: 46458 km
    Date: 2020.11.01
    Time: 00:03:14
    Voltage terminal 30: 11.8 V
    Voltage terminal 15: 11.8 V
    Control Module temperature: 30 °C
    System status: Terminal 15 on
    IN ESP_standstill flag: standstill detected
    Engine running: OFF
    IN ZAS_Te_X: OFF
    Terminal 15 status via CAN: On
    Terminal 15 status: On
    Datenfeld: 0
    Address 1B: Active Steering (J792) Labels: None
    Part No SW: 8K0 907 144 N HW: 8K0 907 144 N
    Component: DYNAMIKLENK. H06 0740
    Revision: 52001005 Serial number: --------------
    Coding: 0E0100
    VCID: 3A2D36639C59188B5C7-806E
    C7.5 17' Audi S7 Prestige | Tornado Grey Metallic |
    Gone but not forgotten:
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Sep 13 2019
    Miami, FL
    Address 20: High Beam Assist. (J844) Labels: None
    Part No SW: 4H0 857 511 HW: 4H0 857 511
    Component: FLA H04 0021
    Revision: AA001002
    Coding: 04018E64747464545425363E00
    VCID: 678BBF17BF6B5563F39-8032
    Address 22: AWD (J492) Labels: 4H0-907-163.clb
    Part No SW: 4H0 907 163 B HW: 4H0 907 163 A
    Component: 4 Wheel Drive H19 0200
    Serial number: 000711160001001
    ASAM Dataset: EV_AllWheelDiffeQSPFR 003026
    ROD: EV_AllWheelDiffeQSPFR.rod
    VCID: 2809FC2B72759A1B3A3-807C
    Address 28: HVAC, Rear (E265) Labels:* 4G0-919-158.clb
    Part No SW: 4G0 919 158 Q HW: 4G0 919 158 Q
    Component: KLIMA FOND H08 0113
    Serial number: 17111600040356
    Coding: 20
    ASAM Dataset: EV_ClimaContrUnitRearUDS 003004
    ROD: EV_ClimaContrUnitRearUDS_003.rod
    Address 34: Level Control (J197) Labels:. 4G0-907-553.clb
    Part No SW: 4G0 907 553 G HW: 4G0 907 553 F
    Component: LUFE-DAEMPFER H19 0783
    Coding: 008006
    ASAM Dataset: EV_AirSuspe 003025
    ROD: EV_AirSuspe_VW51.rod
    VCID: 2F3B1737579BCD23FB9-807A
    1 Fault Found:
    403200 - Function Shut-Off Active
    C10C8 00 [008] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 57
    Date: 2000.00.00
    Time: 00:00:00
    Address 36: Seat Mem. Drvr (J136) Labels: None
    Part No SW: 4G8 959 760 HW: 4G8 959 760
    Component: MEM-FS H03 0157
    Revision: AA000000 Serial number: 00000226718036
    Coding: 00581B0000006001000001010101102030303232203232
    VCID: 77ABEF57EFCBC5E3639-8022
    Address 3B: Sensor Elect. (J849) Labels: 4G0-907-637.clb
    Part No SW: 4G0 907 637 L HW: 4G0 907 637 G
    Component: SARA 6D red H04 0056
    Revision: -------- Serial number: EJ1BPA7E02H9DD
    Shop #: WSC 00000 000 00000
    ASAM Dataset: EV_SARA2 005012
    ROD: EV_SARA2.rod
    VCID: 372B2F57AFCB05E3A39-8062
    Address 3C: Lane Change (J769) Labels:| 5Q0-907-566.clb
    Part No SW: 4G0 907 566 M HW: 4H0 907 566 F
    Component: SWA Master H08 0070
    Serial number: 0421332565
    Coding: 040211
    ASAM Dataset: EV_LaneChangAssis 001028
    ROD: EV_LaneChangAssis_AU21.rod
    VCID: 392F296F99DF139355D-806C
    Lane Change Assistant 2:
    Subsystem 1 - Part No SW: 4G0 907 568 M HW: 4H0 907 568 F
    Component: SWA Slave H08 0070
    Serial number: 0421958956
    Coding: 040211
    Address 42: Door Elect, Driver (J386) Labels:. 4H0-959-793.clb
    Part No SW: 4G8 959 793 H HW: 4G8 959 793 F
    Component: TSG FA H04 0511
    Coding: 011F5F035E00628002000413
    VCID: 45D7559FE5A76773215-8010
    Address 44: Steering Assist (J500) Labels:| 4G0-909-144.clb
    Part No SW: 4G0 909 144 T HW: 4G0 909 144 Q
    Component: RCevo H54 0202
    Revision: 00000001 Serial number: 0000399333
    Coding: 011001010001
    ASAM Dataset: EV_RCEPS 106007
    ROD: EV_RCEPS_106.rod
    VCID: 3A2D36639CD9188B5C7-806E
    Address 46: Central Conv. (J393) Labels:. 4H0-907-064-46.clb
    Revision: 00002001 Serial number: 0423083616
    Coding: 0126063A20BAF08580B00A8402030D47000000000000000000 0000000000
    Subsystem 1 - Part No SW: 4G0 959 719 HW: 4G0 959 719
    Component: GTO BF H01 0081
    Serial number: 00000000000000377627
    Subsystem 2 - Part No: 1K0 951 605 F
    Component: LIN BACKUP HO H01 0008
    Subsystem 3 - Part No SW: 4G8 959 591 A HW: 8V3 959 591 A
    Component: J245 PS40.402 H03 0004
    Serial number: 0000FST001ADLJS00000
    Coding: 101F02
    Subsystem 4 - Part No SW: 4G0 947 135 G HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00027021486
    Coding: 010000
    Subsystem 5 - Part No SW: 4G8 959 252 A HW: 4G8 959 252
    Component: HSP-SG H11 0031
    Serial number: WA125827000026788511
    Subsystem 6 - Part No SW: 3AA 962 243 D HW: 3AA 962 243 D
    Component: GEB.F.Heckoef H16 0811
    Serial number: 93936422
    2 Faults Found:
    03976 - Control Module for Rear Lid/Hatch Opening: Play Protection Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 6
    Fault Frequency: 5
    Reset counter: 78
    Mileage: 45704 km
    Time Indication: 0
    Date: 2020.10.20
    Time: 16:50:07
    01403 - Glass-Break Sensors; Rear
    011 - Open Circuit
    Freeze Frame:
    Fault Status: 01101011
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 132
    Mileage: 39865 km
    Time Indication: 0
    Date: 2020.07.03
    Time: 11:26:25
    Address 52: Door Elect, Pass. (J387) Labels:. 4H0-959-792.clb
    Part No SW: 4G8 959 792 H HW: 4G8 959 792 F
    Component: TSG BF H04 0511
    Coding: 011F5F035E00628002000402
    VCID: 44D1489BEE9D5E7B36B-8010
    Address 53: Parking Brake (----) Labels: 4H0-907-801.clb
    Part No SW: 4H0 907 801 M HW: 4H0 907 801 M
    Component: EPB-4 H01 0018
    Revision: -------- Serial number: 00000002031425
    ASAM Dataset: EV_ParkiBrake 001033
    ROD: EV_ParkiBrake_VW51.rod
    VCID: 323D1E4344A9E0CB947-8066
    Address 55: Headlight Range (J745) Labels:| 4H4-907-357-V2.clb
    Part No SW: 4H4 907 357 E HW: 7P6 907 357 B
    Component: MxB-ECU 001 0100
    Coding: 05FA0A1122600400
    ASAM Dataset: EV_HeadlRegulAUDIMXBAU64X 005009
    ROD: EV_HeadlRegulAUDIMXBAU64X_005_AU57.rod
    Led Headlamp Powermodule Left:
    Subsystem 1 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
    Component: LED LeiMo li. H07 7570
    Coding: E02000
    Led Headlamp Powermodule Right:
    Subsystem 2 - Part No SW: 7PP 941 472 K HW: 7PP 941 472 K Labels: 3D0-941-329.CLB
    Component: LED LeiMo re. H07 7570
    Coding: E02000
    Address 5F: Information Electr. (J794) Labels:* 4G1-035-MIB-HGH2.clb
    Part No SW: 4G1 035 025 D HW: 4G1 035 025 C
    Component: MU-H-LNS-US 053 0902
    Serial number: A741K0G7528836
    Coding: 017553020000000013220002041A00102F000DE5F17001047E
    ASAM Dataset: EV_MUHig6C3Gen2HBAS 001115
    ROD: EV_MUHig6C3Gen2HBAS_AU57.rod
    VCID: 1F1BE7F7273B5DA34B9-804A
    Data medium:
    Subsystem 1 - Part No SW: V03 959 801 GG HW: -----------
    Component: NAR 2017 --- 0057
    Serial number: --------------------
    Display unit 1 for multimedia system:
    Subsystem 2 - Part No SW: 4G1 919 605 B HW: 4G1 919 605 B
    Component: DU8 C7 SV H63 0007
    Serial number: AUZ8Z9GY806NQP
    Multimedia Operating Unit:
    Subsystem 3 - Part No SW: 4G1 919 610 F HW: 4G1 919 610 F
    Component: E380 BDT C7 H20 0250
    Serial number: 90349PKF0001P
    Compact Disc Database:
    Subsystem 4 - Part No SW: V03 959 800 EG HW: -----------
    Component: Gracenote2--- --- 3011
    2 Faults Found:
    0020 - Tuner for Satellite Radio
    B11CF 53 [009] - Deactivated
    Freeze Frame:
    Fault Priority: 4
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 44504 km
    Date: 2020.09.20
    Time: 20:42:51
    Voltage terminal 30: 14.3 V
    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
    Satellite radio tuner status-Channel selection for satellite radio: 0
    Satellite radio tuner status-Audio Signal: Not available
    Satellite radio tuner status-Antenna current: 0 mA
    Satellite radio tuner status-Reception quality: Not available
    Satellite radio tuner status-Satellite radio tuner: pre-activation status: 00
    Satellite radio tuner status-Satellite radio tuner: pre-activation value: 00
    0008 - Connection between Antenna Amp 2 for Radio and Antenna
    B1273 13 [009] - Open Circuit
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 0
    Mileage: 44504 km
    Date: 2020.09.20
    Time: 20:42:30
    Voltage terminal 30: 11.7 V
    Status of antenna 2 for radio-Antenna current: 0 mA
    Status of antenna 2 for radio-Connection between radio and antenna amplifier: Electrical OK
    Status of antenna 2 for radio-Connection between antenna amplifier and antenna: Open circuit
    Status of antenna 2 for radio-Reception level antenna 2: 255 dBµV
    Address 62: Door, Rear Left (J388) Labels:. 4H0-959-795.clb
    Part No SW: 4G8 959 795 H HW: 4G8 959 795 F
    Component: TSG HL H03 0511
    Coding: 010F1F024000628002000002
    VCID: 47CB5F97DFAB7563D39-8012
    Address 6C: Back-up Cam. (J928) Labels:* None
    Part No SW: 4H0 907 428 E HW: 7P6 907 441 G
    Component: TopView H09 0380
    Revision: 11001001 Serial number: 82330JG0365314
    Coding: 0217000101010100000102000000
    ASAM Dataset: EV_CamerSysteTopViewAUDI 008028
    ROD: EV_CamerSysteTopViewAUDI.rod
    Address 6D: Trunk Elect. (----) Labels:* Redir Fail!
    Part No SW: 4G8 959 107 T HW: 4G8 959 107 J
    Component: HDSG-Modul H14 0049
    Revision: 12014001 Serial number: 314600597
    Coding: 0A3305C122
    ASAM Dataset: EV_HDSGAu573 001022
    ROD: EV_HDSGAu571.rod
    VCID: 46D55293D8216C6B28F-8012
    Address 72: Door, Rear Right (J389) Labels:. 4H0-959-795.clb
    Component: TSG HR H03 0511
    Address 82: Heads Up Display (J898) Labels:* None
    Part No SW: 4G8 919 604 M HW: 4G8 919 604 M
    Component: HeadUpDisplay H09 0306
    Revision: 00000000 Serial number: 00000000000000
    Coding: C60000
    ASAM Dataset: EV_HUDContiC7 001027
    ROD: EV_HUDContiC7.rod
    Address 85: On Board Cam. (J852) Labels:| 7P6-907-217.clb
    Part No SW: 4H0 907 217 F HW: 4H0 907 217 A
    Component: DPC-SG H28 0081
    Revision: -------- Serial number: 262130025421000
    Coding: EA060000
    ASAM Dataset: EV_OnBoardCamerDPC 001007
    ROD: EV_OnBoardCamerDPC.rod
    VCID: 2C01003B668DB63BDEB-8078
    Address 8B: Adaptive Cruise 2 (J428) Labels:| 4H0-907-561.clb
    Part No SW: 4G0 907 541 B HW: 4G0 907 541
    Coding: 7E01010101
    ASAM Dataset: EV_AdaptCruisContr2AU57X 002013
    ROD: EV_AdaptCruisContr2AU57X_002.rod
    VCID: 270BFF177F6B9563339-8072
    Address 8E: Image Processing (J851) Labels:| 4H0-907-107-V2.clb
    Part No SW: 4H0 907 107 H HW: 4H0 907 107
    Component: BV-SG H34 0090
    Serial number: 005002451711167
    Coding: 03C1BA1B0111
    ASAM Dataset: EV_BC7 001001
    ROD: EV_BC7.rod
    Address 8F: Pretens. Frt Left (J854) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 945 B HW: 4H0 980 945 C
    Component: RGS-VL H16 0080
    Coding: 0066E608031F0376070308014240C0010000
    ASAM Dataset: EV_RGS_L 002004
    ROD: EV_RGS_L_VW51.rod
    VCID: 313F114F41AFDBD3EDD-8064
    Address 90: Pretens. Frt Right (J855) Labels: 4H0-980-94x-RGS.clb
    Part No SW: 4H0 980 946 B HW: 4H0 980 946 C
    Component: RGS-VR H16 0080
    ASAM Dataset: EV_RGS_R 002004
    ROD: EV_RGS_R_VW51.rod
    Address A9: Struct. Borne Sound Labels: None
    ASAM Dataset: EV_SoundActuaGen2AU64X 003010
    ROD: EV_SoundActuaGen2AU64X.rod
    VCID: 55F785DF1587D7F3515-8000
    Address BA: Motor Mounts (J931) Labels: 4H0-907-145.clb
    Part No SW: 4H0 907 145 B HW: 4H0 907 145
    Component: AEM - LEAR H10 0008
    Revision: 00001001 Serial number: 97813007694601
    ASAM Dataset: EV_AEMLearAU64X 002016
    ROD: EV_AEMLearAU64X.rod
    1 Fault Found:
    1294 - Actuator 1 for Drivetrain Mounts
    C1131 07 [009] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 51
    Mileage: 46387 km
    Date: 2020.10.31
    Time: 14:01:31
    End----(Elapsed Time: 03:40, VBatt start/end: 11.7V/11.7V. VIgn 11.7V)-----
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Sep 13 2019
    Miami, FL
    Hey guys so I ended up resetting the codes, then seeing what was left and it was the cooling fan one, so I took out the 40 amp fuses for the cooling fans, sww they were fine and put them back in. After I did that she started right up so I guess I just needed to reseat them? We will see if any problems rise up in the future!
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Sep 13 2019
    Miami, FL
    So small update I turned it off then tried turning it back on and it wont start with the same error Coolant System fault! so im gonna charge my laptop and run the codes again
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    FWIW the car not starting sounds more like this fault...
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 46459 km
    Date: 2020.11.01
    Time: 09:44:51
    I think you might need to replace the starter or find out what the electrical problem with the starter is first.
    FWIW fuses are generally not like Nintendo cartridges...reseating them will do nothing...they are either working or blown...
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Sep 13 2019
    Miami, FL
    Quote Originally Posted by gk1 View Post
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Mileage: 46459 km
    Date: 2020.11.01
    Time: 09:44:51
    If its a starter problem then why does it start up fine when I reset the faults? I cleared the DTC and then it started right up drove perfectly etc then I turned it off, went to turn it back on and it told me Coolant System Fault. Since the fuses looked fine, I feel like the radiator fans are shot but I dont understand why the car wont start with them being broken.
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Mar 30 2018
    long island
    There was a thread recently of intermittent start issues. Appearantly staters on these cars don't just fail...they will continue to work randomly.
    Sep 13 2019
    Miami, FL
    Quote Originally Posted by daytona rs7 View Post
    How can I further diagnose the starter issue? Do you happen to have a link to the thread?
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by Ayo_wtf View Post
    As daytona said, the starter is not necessarily the starter like on old cars. It may work for a bit, then there is an electrical fault and it stops.
    It's also possible you may have a wiring issue somewhere affecting both the starter and fans too. It is very hard to diagnose that over the internet.
    This is one of the instances where a good shop would be able to help more than the forum.
    Otherwise you start replacing the expensive fans, but then you might find out there is another issue with something else and/or the starter too. A shop is going to do a better job of degerming if there is a wiring/electrical problem first before starting to throw parts at it.
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Sep 13 2019
    Miami, FL
    Otherwise you start replacing the expensive fans, but then you might found out there is another issue with something else and/or the starter too. A shop is going to do a better job of degerming if there is a wiring/electrical problem first before starting to throw parts at it.
    Yeah I didnt want to take it to a shop and see if i could do it myself but its looking like thats going to be the route i gotta take
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Sep 15 2017
    2017 S6, 2016 MBZ E400, 2022 Acura MDX
    Huntington Beach, CA
    Maybe I'm missing something here but the scan you provided is for a 2017 S7 with 28,867 miles. Why wouldn't this problem be covered under the 4 yr/48K warranty?
    Sep 13 2019
    Miami, FL
    Quote Originally Posted by DaddyO View Post
    Thats a solid point but 1. I got a call and they said my warranty was up and 2. I have downpipes installed and I really dont want to go through the hassle of uninstalling them.
    B8.5 14' Audi S4 P+
    Z33 06' Nissan 350z
    Established Member Two Rings B8s's Avatar
    Sep 26 2012
    Northern New Jersey
    did you ever find the resolution to this? I have a similar issue
    2012 PHANTOM BLACK // AIRLIFT V2 MANAGEMENT // 20x9 VOSSEN CVT // STASIS EXHAUST // ROC EURO INTAKE // I.E STAGE 1
    Veteran Member Three Rings TappaNuKegga's Avatar
    Apr 07 2016
    PA
    Did you ever get this resolved with your shop? What did the problem end up being?
    Sent from my HD1905 using Tapatalk
