Results 1 to 13 of 13
    Jun 09 2014
    Austin, TX
    Damaging to drive with Downpipe on stock tune?
    I’m having a local shops install my Uni Down pipe and mid pipes. They are not a Uni dealer so they wanted to charge me a few hundred bucks to also flash the ECU to Uni stage 2.
    I have the Uni connect cable and was planning to flash the ECU myself at hone after I drive home from the shop. It’s about 15 miles I would have to drive the car on stock tune with Downpipe to get home. I will drive like a grandma and not hit any boost.
    I assume this is totally fine and will not damage the car?
    2020 RS-3 Nardo Edition
    Unitronic Stg 2 ECU (E85), Unitronic Stg 2 TCU, Unitronic downpipe, Unitronic midpipes, UNI 4" Turbo Inlet, UNI 4" Carbon Fiber Intake, APR FMIC, ECE Dogbone Mount, MSS Track Adjustable Springs, Fuel-It Fuel Sensor, 18" Neuspeed RSE11R Wheels, Michelin PS4 Tires, IROZ DSG Catch Can, NGK Racing Spark Plugs
    Established Member Two Rings EthanS's Avatar
    Jul 31 2020
    '19 30AE Miata RF #1568/3000
    Northern Virginia
    From what I've read, it should not damage your car but it will throw a check engine light.
    Previous Cars: '06 A4 2.0T | '17 A3 2.0T
    Apr 22 2012
    Norway
    If you drive grandma with a low rpm I would be tempted to say that you will be ok even if you flashed your car before going to the shop.
    But I do believe that your approach is probably better
    Sent from my iPhone
    Sep 01 2012
    Edmonton
    Quote Originally Posted by EthanS View Post
    Do you have a link or references supporting this?
    2018 RS3 Panther Black
    Jul 31 2020
    Northern Virginia
    Quote Originally Posted by WAF View Post
    https://www.google.com/amp/s/forums....t-a-tune&amp=1
    This thread sort of sums it up. Also, whenever people take their cars in for emissions inspection with aftermarket downpipe, they will always flash black to a stage 1 or even the stock tune and run with that.
    Established Member Two Rings PTeezy's Avatar
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    Quote Originally Posted by S4_ATX View Post
    May I suggest taking a laptop to the shop and hopefully having wifi and just tune it there in the parking lot.
    Literally takes 15 minutes to tune your vehicle once you register your account with Unitronic.
    -Patrick
    Apr 22 2012
    Norway
    Quote Originally Posted by PTeezy View Post
    It is strongly recommended to add a battery charger when flashing!
    Sent from my iPhone
    Veteran Member Four Rings Bezlar's Avatar
    Apr 05 2006
    992 c4s
    Blue Springs
    You’ll be fine
    2005 1/2 imola S4 gone
    2004 mini s gone
    2007 gti gone
    2008 mini s gone
    2011 ibis avant gone
    2012 iced silver tts gone
    2015 golf r gone
    2018 rs3 garage
    Jun 02 2020
    Porsche 911 GT3
    Alabama
    Quote Originally Posted by context.eax View Post
    Sent from my iPhone
    Yes! Forgot to mention that. Thanks!
    -Patrick
    Active Member Three Rings SlowSedans's Avatar
    Oct 27 2018
    R8, RS4, RS3, S4 x 5
    Tahoe
    You are fine to run the uni dp on the sage 1 tune. You could run it on a stock tune.
    My posts are regularly edited or deleted, since 2004 because I tell consumers the truth about modifications or components from within the industry.
    Wastegate Rattle Fix info
    2017 rs3 nardo stage 2+
    2009 r8 phantom black & boosted
    2007 rs4 sprint blue snow car
    2000 s4 single turbo scary fast
    2001 s4 stage 3 street beater
    Sep 01 2012
    Edmonton
    https://www.google.com/amp/s/forums....hout-a-tune&=1
    Thanks, I'll check it out.
    Jun 09 2014
    Austin, TX
    Thanks for confirming my assumptions around this. I did not want to do anything that might damage my car. Sounds like it will not be an issue to drive home on my stock tune.
    I will definitely use a battery charger when I flash my car.
    I currently use a Mac computer. I believe that Unitronic requires a PC. Has any had any luck getting it to work on a Mac? Maybe using a VM?
    If not, does anyone know the cheapest PC or tablet that I can use to flash my car with the Unitronics software?
    Established Member Two Rings RSgoals's Avatar
    Sep 14 2018
    I setup boot camp on my MacBook just for the unitronic tune and it worked great!
