Results 1 to 35 of 35
    Sep 17 2005
    Fremont, California
    Available Now: X34 Carbon Fiber Intake for 3.0t B8/8.5 S4 & S5!
    After months of anticipation, the X34 Carbon Fiber Intake for Audi B8/8.5 S4/S5 3.0 TFSI is finally here!
    Significant effort went into developing this comprehensive performance-improving intake solution for the Supercharged 3.0 TFSI engine found in the B8 and B8.5 generation of S4 and S5. Subsequently, the X34 Carbon Fiber Intake, Audi B8/8.5 S4/S5 3.0 TFSI offers discerning enthusiasts measurable increases in horsepower and torque, more aggressive induction sound and supercharger whine, and a beautiful carbon fiber heat shield to prevent hot air from the engine bay from entering the intake.
    Throughout the development process, multiple designs were modeled, prototyped, and tested - all to ensure that the X34 Carbon Fiber Intake delivers measurable performance benefits and superb fitment. The result is an optimized open-airbox design that utilizes the factory fresh air duct inlet to channel cool outside air to the filter. This large airbox design allows for a massive 5" inlet conical air filter, free of restrictive shrouding, and channels air through a CFD-optimized 4-ply silicone inlet hose that smoothly increases air velocity to the throttle body.
    Minimizing Unnecessary Filter Shrouding
    034Motorsport focuses on optimizing every aspect of the intake system across a broad range of variables and compromises. A critical component of a high-flowing performance intake is the ability for air to flow around and into the filter. If the air cannot flow freely around the filter, it will be restricted from getting into it. Many aftermarket kits fit too large of a filter in an enclosure that cannot accommodate its size, thus choking the filter and reducing its overall flow. This often happens when a product is engineered for one variable at the expense of others. 034Motorsport conducted extensive tests and refined its development of the intake design to allow for maximum airflow surrounding the air filter, allowing for optimal airflow to, and through, the filter. The final result is the right size filter in the right size filter housing, creating maximum airflow and performance with OEM level filtering; the ultimate goal of any intake system. Be cautious of any intake that brags only of the air filter size, without taking into account the detrimental effects of shrouding the filter.
    Maximizing Airflow
    034Motorsport engineers first created a CFD-optimized 4-Ply silicone intake tube, which is a direct, high-performance replacement for the plastic factory accordion/sound deadening hose. Using CAD software and 3D scanning technology, 034Motorsport was able to optimize the cross-sectional area of the intake tube while being mindful of space constraints. The resulting part is a functional work of art - maximizing performance given the factory space constraints and featuring smooth transitions that ensure optimal airflow to the throttle body.
    Performance Air Filter
    The 034Motorsport Carbon Fiber Cold Air Intake system houses a high-flow conical air filter with a double-layer pleated cotton filtration medium, capable of trapping particles as small as 5 Microns. This air filter design offers increased flow through an enlarged filtration surface while ensuring superior filtration. We have tested this air filter in applications over 800HP with minimal restriction, and superior OEM quality air filtration.
    While many intake kits leave the air filter unsupported and ”flopping” around, 034Motorsport engineers designed a clever air filter support that not only prevents unwanted movement but also allows compliance to accommodate engine movement under varying load conditions. An added benefit is an air shroud that doesn’t move and rub on other engine compartment components like many other designs on the market do.
    PRESSURE DROP IMPROVEMENTS
    Pressure Drop is the difference in ambient air pressure and the air pressure measured at the throttle body across the engine's rpm range. The higher the pressure drop at any given rpm, the more restrictive the intake system is, reducing airflow.
    Intake Configuration Pressure Drop
    X34 Carbon Fiber Cold Air Intake -0.97 psi
    Stock Intake -2.18 psi
    Dyno-Verified Wheel Horsepower & Torque Gains
    034Motorsport's engineering and development efforts were validated on multiple vehicles using our Mustang AWD Dynamometer to ensure that the 034Motorsport Audi S4 Cold Air Intake System provided substantial increases in horsepower and torque on both stock supercharger and ones with ported supercharger kits alike.
    PEAK WHEEL HORSEPOWER & TORQUE WITH STAGE 2+ E40, 57.75/190MM Pulley Combo
    • Stock Intake: 416 WHP / 396 WTQ
    • 034 X34 Intake: 436 WHP / 416 WTQ
    • Peak Crank Gains: 26 HP / 24 TQ
    FEATURES
    • Developed In-House by 034Motorsport's Engineering Team
    • Fits Both Left and Right Hand Drive Configurations
    • High-Quality Carbon Fiber Air Block-off Shield
    • High-Gloss Epoxy Finish
    • 4-Ply Gloss Black Silicone Intake Tube
    • OEM+ Fit and Finish
    • No Rubbing or Excessive Movement
    • Dyno-Proven Horsepower Torque Gains
    • Improved Airflow from Factory Airbox and Intake Tube
    • Enhanced Engine Induction Sounds
    • Improved Throttle Response
    • Large 4" Inlet Conical Pleated Cotton Air Filter
    • Reduced Intake Air Temperature
    • Securely Installs Using Factory Mounting Grommets
    • Simple, Straightforward Installation Instructions
    Whats Included:
    • X34 Carbon Fiber Heat Shield
    • X34 4" inlet Silicone Hose
    • X34 4" Double-Layered Cotton Pleated Filter
    • X34 Secondary Air Injector Hose
    • Metal mounting bracket for intake hose
    CHECK IT OUT HERE!
    Veteran Member Three Rings hellovaras's Avatar
    Oct 28 2018
    PNW
    I noticed no to heat shield. How does this help with heat from the engine?
    Sent from my GM1917 using Tapatalk
    2013 Monsoon Grey B8.5 S4 6MT | ECS CF Wing | ECS CF Front Lip | Canyon Run-15 Strut Brace | ECS Front Strut Tower Bar | Injen CAI | ECS Center X-Pipe | 034 Motorsports Rear Sway Bar | ECS Tuning Lower Control Arm Brace | Ziza Interior Light Kit | Luft-Technik Intake Air Scoop | ECS CF Antenna Cover | ECS CF Rear Diffuser | IE Stage 1 |Do Tinted Windows Count?
    Veteran Member Three Rings Maddog3xx8's Avatar
    Sep 02 2009
    Ashland MA
    B8 SQ5 fitment?
    B8 SQ5 - 034 Stage 2+ DP Tune / Pulley Ratio 3.209/ 034 ZF Tune / Ported Blower with Port Matched 75mm TB / AWE 102mm Touring Exhaust / AWE Non Res Downpipes / AWE Cold Front HX / ARM 3.5 Intake / V-FF 102s 20x10 / DWS 295/40/20 Square / 12mm Spacers Front & 15mm rears / ST Coilovers / EuroCode front Sways & 034 rear sways/ 034 Links/ EuroCode Alu Kreuz / 034 Mounts / RSNAV 8.8 / P3 Gauge / CF Mirrors / Vosh Front & Rear BBK / SS brake lines
    Veteran Member Four Rings 2by2handsofblue's Avatar
    Jun 02 2019
    RIP my 98 saturn sc1 5sp that had 294k miles on it.
    serenity valley
    Why not make a enclosed airbox. Or have a option.
    we are the borg! resistance is futile.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by hellovaras View Post
    I assume you meant no Top enclosure for the intake. This open-element design maximizes positive intake pressures, reducing pressure drop. The bulk of the heat in the engine bay is blocked completely by the heat shield pictured above.
    Quote Originally Posted by Maddog3xx8 View Post
    B8 SQ5 fitment?
    B8 SQ5 variants will be coming in the future!
    Quote Originally Posted by 2by2handsofblue View Post
    We tested open and closed airbox variants, and found the open element design to perform the best for all power outputs. Having the open design means there is no negative pressure found around the air filter, thus allowing the filter and intake to flow better. The bulk of all heat is blocked by the heat shield, allowing the filter to breathe fresh cool air coming in from the factory front ducting system.
    We are not selling a lid for the box as it would not help with performance, nor would it be easily compatible with this design. To incorporate the ability for a lid to be added would inevitably raise the overall cost of the intake, which was not something we wanted to do. Our goal was to produce a cost-effective, high-performing, and perfect fitting intake solution that maximizes performance, sound, aesthetics, and quality.
    -Nick@034
    Junior Member One Ring
    Aug 10 2019
    Eastern Washington
    Thanks for sharing this with us. Do you have any data on the effect on IATs relative to stock?
    2016 S4 | Premium Plus | DSG | Sport Diff
    Oct 28 2018
    PNW
    Quote Originally Posted by 034Motorsport View Post
    -Nick@034
    Thanks
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by 6.0 Silverado View Post
    We have internal testing to verify IATs are not affected, but no pretty graphs to share. Temperature probes are placed throughout the engine bay during development to verify this. We have no reason to lie about this, as we would never make or sell a product that negatively affects performance.
    On our in-house B8 S4 we saw a 26hp and 24tq increase over the stock intake on Stage 2+.
    -Nick@034
    Jun 02 2019
    serenity valley
    Sorry I didnt word it correctly but glad u got the point lol.
    Well it's something to think about. There are few options out there.
    Thanks
    Aug 10 2019
    Eastern Washington
    -Nick@034
    Sweet! I might pick one of these up. Thanks.
    Established Member Two Rings onelowboi's Avatar
    May 31 2019
    bay area
    Is the silicone hose 5” necked down to the stock size? Would the throttle body include a new hose that would increase the sizing?
    Mar 05 2016
    Is this silicone hose same to the old one SKU: 034-112-6005?
    Can we buy the heat shield separately?
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by TC_S4 View Post
    The hose you are referencing is designed for the stock intake, not our upgraded X34. The X34 uses a massive 5" conical filter inlet, which requires a larger hose. This larger hose is included in the X34 Kit.
    -Nick@034
    Veteran Member Three Rings Speedooooo's Avatar
    Sep 13 2015
    Cincinnati, OH
    Any plans on making this for the C7/C7.5 A6?
    2018 Glacier White A6 3.0T | Driver Assistance | Sport | Black Optics
    2016 Mythos Black Q5 3.0T SOLD
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by Speedooooo View Post
    Yes, this is in development.
    -Nick@034
    Sep 13 2015
    Cincinnati, OH
    Can you comment on timing?
    Sep 17 2005
    Fremont, California
    It is still in development, so I do not have an ETA I can share at this time.
    Veteran Member Four Rings scmtkings4's Avatar
    Oct 06 2016
    Brooklyn, NY
    Is there any way we can purchase th x34 kit but with the larger hose body that you plan on releasing with the bigger throttle body? Just cause I'd have no use for the standard size so wondering if it's be possible to do a simple switch. Also is the bigger tube 5" necked down to 3.5"? Thanks!
    2014 S5
    AWE Touring Exhaust l ECS Intake l EPL Dual Pulley 93 l AMS Alpha Cooler
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by scmtkings4 View Post
    The larger hose will be available as a standalone upgrade path once it is available. The cost of the upgrade hose will be the same price difference between the stock and upgraded throttle body intakes. ETA on that is still TBD.
    As for current size, it is a 5" hose inlet for our massive conical filter, gradually necking down to the stock throttle body size, all while increasing air velocity and reducing turbulence.
    -Nick@034
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    The real McCoy, bring that real sexy intake back . Who has it now or is it on a wall @ 034?
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by RWD2quattro View Post
    It's on a wall as a display of artwork. Retail on that would've been well over $1000, which there simply is not a market for any more. Sure does look good though!
    -Nick@034
    Jul 31 2020
    Austin
    How loud is the supercharger whine with this intake? On a scale of stock (1) to roc euro or CTS (10)
    Mar 03 2020
    Cali
    Quote Originally Posted by Austin88 View Post
    Good question!!!!!!!!!!
    How loud would it compare to those toooo?!!
    Jun 02 2019
    serenity valley
    -Nick@034
    Well adding a cover wont be over 1I.
    The apr isnt 1k. It could be done I suppose. Or dont make a cf to cut down on cost
    Sep 17 2005
    Fremont, California
    Quote Originally Posted by TonyS4B8.5 View Post
    It's pretty dang loud! Our design is far less restrictive than those intakes (we've had a few come through and we've compared), thus allowing more supercharger whine to easily be heard through the system and outside/inside the car.
    -Nick@034
    Jun 02 2019
    serenity valley
    -Nick@034
    Is the filter serviceable? Like K&N filters?
    Sep 17 2005
    Fremont, California
    Yes, it is serviceable using our cleaning kit, as it uses a special light oil that performs best for cotton filters: https://store.034motorsport.com/034m...aning-kit.html
    Jul 31 2020
    Austin
    -Nick@034
    I was hoping you would say it’s on the quieter side. I had an 03 Cobra with open intake and got sick of the supercharger whine. I think I might go with your silicone intake tube and stock air box mod (drill hole in bottom) instead.
    Jun 02 2019
    serenity valley
    Drill a hole? Why?
    Jun 02 2019
    serenity valley
    Well I took the chance and bought the x34 for the s5.
    I hope they will make a cover for the cai. Cant hurt it to have an option to have a cover for it.
    Jul 31 2020
    Austin
    Drill a hole? Why?
    AZT did extensive testing and you can basically make as much power as aftermarket intake with slightly less heat soak by drilling hole in stock air box, upgrading drop in filter, and upgrading intake tube. 034 has a tube for $99
    https://www.audizine.com/forum/showt...x-hole-testing
    Jun 02 2019
    serenity valley
    Oh ok. Well I bought the x34. I'll post on here to do a review and how loud the sc whine is. I'm on stage 1.
    Aug 16 2020
    Nj
    I'm about to pull the trigger the on the intake for my lady's q5 and test for fitment. There are aftermarket intakes marketed as fitting both s4/s5 and q models. I believe only the tube might need trimming or maybe just manipulation.
    Looking to save during the black Friday sale and the lady wants some whine with her cheese...
    Aug 16 2020
    Nj
    By the by...the x34 does fit on the q5. It is what I would consider an "approximate" fit. There is a slight gap between the shock tower and the heat shield. I haven't seen a good photo of the s4/s5 tolerance in relation to the shock tower to compare but there's maybe a 1-1.5" tapered gap on the q5. Additionally, the bracket that ties the filter/ tube to the heat shield requires a longer bolt if you want to maintain the same connection. I also needed to use a fuel injection hose clamp to keep the vacuum hose from slipping off the barb on the intake tube near the throttle body. In closing, it fits and works just not with tight tolerances in relationship to the shock tower. I ordered knowing it may not fit as it's designed for the s4/s5 but I am content with the installed product.
    Veteran Member Four Rings ANMS4's Avatar
    Dec 18 2012
    Framingham MA
    -Nick@034
    Nick do the test include VS the RS7 intake also? Thank you
    2014 S8*SMR Intakes*HMD Exhaust*DS1 tuned by SLEEPERTUNED*E50* MELEN TCU TUNE
    SOLD 2014 A6-IE STG2 DP+ TB E40 tune and Melen TCU Flash, RS7 Airbox, AWE Touring Catback+Resonated DP, Ported SC By Shane
