Originally Posted by
EthanS
Used to run an APR stage 2 plus a4 b7 in Virginia for years without an intercooler and never ran into any issues. I didn't think the IC was a necessary upgrade here. Just my personal experience.
MikTip
An intercooler is best experienced installed. They make a noticeable difference. Especially in the heat soak arena. On my B6 A4 the FMIC provided the car with zero heat soak issues. Basically 1 shot of boost and you feel diminished performance until everything cools back down. On my S3 the IE intercooler also provides for zero heat soak issues. Zero diminished performance. The intercooler also reduces intake charge temp to ambient temp. The difference is quite noticeable. If you would of installed an aftermarket intercooler you would experience the difference.
EthanS
Fair points. I don't doubt an IC would make a perceivable difference, but I evaluated my needs at the time and as a zippy DD it never came close to encountering heat soak or diminished performance from what I could tell.
This. Nothing against you Ethan, but people always comment that they didn't run into any issues or they didn't see any performance reduction but they never had it installed/ experienced it installed. I haven't met many (none that I can recall) that installed an IC and DIDNT comment that they noticed it made a big difference. So not trying to call you out specifically by any means, but if you dont have a IC, you can't really comment on how much it did or did not impact performance.
I was able to run a all out 29psi tune on the stock turbo with an IC. That would have been a death wish (even moreso) on stock IC. Even at typical stage 2 24-25psi spike on stock turbo it makes an enormous difference after one run. After ONE run a stock IC heatsoaks at stage 2 levels and has difficulty getting back down to normal temps. One run could be a spirited on ramp burst from 2nd to 4th. You dont have to be racing for it to make a big impact, especially on hot days just under normal driving conditions I could tell a massive difference.
