Results 1 to 16 of 16
    Established Member Two Rings Blueiris's Avatar
    Aug 13 2018
    B8.5 S4, B8 Q5, Honda Snow Blower, Craftsman Lawnmower...
    Boston/MA
    Deciding between PowerStop and Zimmermann brakes
    My 2015 B8.5 has 28k miles and the brake pad light came on last week. I plan to replace all 4 rotors and pads and am torn between these 2 companies. I am leaning towards PowerStop drilled and slotted rotors and Akebono pads. I looked into the Zimmermann rotors as well and have heard good reviews but looks like they only come in a drilled option. I dont track the car at all and to say it is a daily driver is generous, i drive about 5k miles per year. RckAuto seems to have the best price for PowerStop rotors and i beleive that FCPEuro has good prices on pads.
    I would love to hear your recommendation for brakes and am open to all suggestions. I would prefer just slotted rotors if possible due to reliability but am also open to drilled/slotted. Let me know what you guys have gone with and where would be the best place to purchase.
    2015 S4 Prem+ Black Optics
    Veteran Member Three Rings BR11S4's Avatar
    Apr 29 2019
    Cincinnati, OH
    Do not go with Powerstop. I have Evolution z26 kit and the fronts warped in less than 9k miles. I need to get around to replacing them. Shake at speed and vibrate when braking a lot of the time. Hard pass
    Apr 29 2019
    Cincinnati, OH
    Quote Originally Posted by BR11S4 View Post
    I’ve installed brakes on every car ive owned for last 20 years and never had an issue until these. Cheap Chinese junk imo
    Established Member Two Rings romanrnd's Avatar
    Nov 21 2017
    Cleveland, Ohio
    Zimmerman rotors for sure, but I'm not really a huge fan of the Akebono pads. I had them on my S4 and on our A6 and you lose the initial bite. Next time around I'm going with more performance oriented different pads.
    Mar 05 2015
    2009 A4 Cab: S-Line / 1996 Camaro Z28
    East Granby CT
    I'll throw out another option:
    Stoptech Cryo Treated Rotors
    Porterfield R4S Pads
    not the cheapest for either rotors or pads (actually quite the opposite) - but no issues with stopping power/ fade and brake feel is completely linear..... Also the Cryo Treatment keeps rotors looking like new - which is helpful on cars not driven often.
    2012 Moonlight Blue Metallic S4 | Premium + | DSG | 19" Peelers |Sports Diff | MMI w/Nav | B&O Audio | Advanced Key |
    After-Market Add-Ons: Rallitek Aluminum Paddles | USP LED Interior Lighting | Phillips Xtreme +50% Headlight Bulbs
    Performance Upgrades: 034 Stage 1 ECU & TCU | | APR I/C |
    Stoptech Cryo Slotted Rotors with Porterfield R4-S Pads |
    034 Springs / Koni Yellow shocks | Tires = Michelin Pilot 4S (255/35/19)
    Jun 14 2019
    QC, Canada
    Zimmerman rotors all the way. It's either those or pagid, all else are China pos parts.
    For pads you could go with zimmerman too. They are metallic but much less dust than oem and still brake good. That's what I bought when I did my brakes. Therefore I would suggest a complete zimmerman kit made in Europe with high quality standards and fabrication.
    Sent from my HTC U11 using Audizine Forum mobile app
    Aug 13 2018
    Boston/MA
    Thank you all for the input. If my rear rotors are in good condition, should I just replace the fronts with drilled rotors and leave the rears as is and just replace the pads? Also, where is the best place to purchase the Zimmermann rotors?
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    Go with FCP Euro: excellent replacement policy. That's where I got my Zimmermann rotors and Akebono pads.
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Sep 22 2015
    21 Q7, 21 X7
    Nashville, TN
    Another vote for not Akebono Ceramics. Stock brake setup is awful and I can't push the car AT ALL without shaking with my Zimmerman/Akebono setup.
    But definitely not Powerstop either. Don't go super cheap on brakes.
    Sold: 2014 S4 | EPL Stage 2 + TCU | ECS Intake | CR15 | 034Motorsport RSB | ECS Trans/Diff Inserts | Mr. Spectacular's 10" Subwoofer Box w/10w6
    Aug 13 2018
    Boston/MA
    I am leaning towards these 2 options from FCP Euro. Is the none ceramic pads option the way to go? Why are they cheaper?
    Attachment 205916
    Veteran Member Three Rings BucDan's Avatar
    Jul 19 2017
    San Diego, CA
    'I'm a fan of the Zimmerman/Akebono pad setup. I like the gradual bite and braking. If you like it hard and rough with the braking, go semi then. The brake feel is just different between the two.
    Veteran Member Four Rings sacandagaD's Avatar
    Jul 02 2013
    2015 S4 P+, 2008 Honda Element,2018 Porsche Macan GTS
    Saratoga Springs, NY
    I've used the Zimmermann/Akebono combo for years on two S4's, and the only time I ever had a problem, was once when I went with slotted rotors, and they chattered under hard braking, after they had some wear on them.
    2015 P+, Sepang Blue, Black/Black Alcantara / DSG / Sport Diff / Tech package / OEM Euro Auto-folding mirrors / EPL stage 1 ECU/TCU / BMC Air filter and AWE Intake tube / Carbon inlays / Hard wired V1 / CR-15 / 3M PPF / 19" AdvanApexV601/Hartmann Rotor reps / Akebonos / LED interior and reverse lights / ZxE fogs / Multiple Vag-com mods
    Loved but traded: 2011 S4 P+, Deep Sea Blue Metallic, Black/Silver Alcantara
    Established Member Two Rings Method's Avatar
    Jul 18 2017
    Portland OR
    +1 to the Zimmerman/Akebono setup. This is my DD and the occasional spirited drive through the backroads. This setup has been great.
    APR Stage 2SP + Intake, Light 11385 Mod, 034 Springs - SOLD
    2018 M3 Comp
    Veteran Member Three Rings oaybar007's Avatar
    Sep 17 2006
    Ellicott City, MD
    I run Zimmerman Z Coat rotors with Textar pads. Basically a stock set up more or less. Dirty, hard bite and good longevity.
    Brilliant Red 2004 A4 1.8t Quattro 6spd Ultrasport
    Florett Silver 2016 S4
    Sep 17 2006
    Ellicott City, MD
    What I would suggest going by is desired brake feel. That always make it easy for me. If you want the hard initial bite, and don't mind the dust, metallic is the way to. If you prefer a more linear bite, and less dust, ceramic is the way to go. Both perform just fine on the car.
    Jun 14 2019
    QC, Canada
    Quote Originally Posted by Blueiris View Post
    Attachment 205916
    Go with plain rotors. Keep it stupid simple : Zimmermann plain rotors front rear, Zimmermann / pagid / Textar pads front and rear. That's it that's all. You'll have oem equivalent which is the highest you can go before changing calipers and/or race parts.
