Results 1 to 19 of 19
    Sep 30 2016
    Quebec City
    MMI 3G High Plus Nav OEM Audio Integration Holy Grail (forget mObridge)
    I read many forum and everyone seems to agree there is no way to upgrade the MMI 3G High Plus Nav audio system other than taping to the speaker wire and try to feed an aftermarket amplifier with it...
    Until now...
    I bought this:
    Out of eBay. (look for Adapter Trioma "MOST-RCA 3.0"). It cost less than half of what a mObridge cost, and the mObridge is well known to now work with the more recent MMI versions. But this Russian-made converter do work! You only have to plug it into your MOST optical chain using this kind of cable:
    and it will provide CLEAN line level output for front/rear and sub without any crappy factory equalization, DSP or time alignment. The signal is flat from 20hz to 20khz, so it is perfect to feed an aftermarket amp with built-in crossover and get the audio upgrade you're dreaming of. It really work plug and play, and I did not lose any of the car feature, even the radio tune still work (as you may know the tuner is integrated with the stock amp in the trunk). And the audio quality is unbelievable.
    Apr 02 2018
    UK
    This has been around for quite a while and loads of people I know have used it. How do I know?
    I do an Audi OEM amplifier connector break out board which allows you to feed your after market outputs back to the speakers without needing to change the plugs or wiring.
    Yup, as you said, that kit does work well.
    Sep 30 2016
    Quebec City
    Glad to know! I was looking for this since a while and everyone only talk about mObridge and Helix. The mObridge did not impress me and barely work in my B8.5 A5, but this kit is flawless.
    Also glad to know more people are aware of true audio integration solutions for Audi exists, because working with speaker level input from factory amp is never good at my opinion if you didn't like the OEM sound at first.
    We need to share this kind of information to help other people out.
    Quote Originally Posted by bruce_miranda View Post
    Apr 02 2018
    UK
    True and when you use it with the breakout board. You can have a nice clean install as well with no factory harness splicing cutting etc.
    Jul 29 2019
    2006 Scion Xb
    Hampton Roads
    Where do you find that board?
    Apr 02 2018
    UK
    I make and sell them. And when you combine that with the male plug that you can buy via Audi or Aliexpress you can even have it plugged back to the amplifier too.
    Jul 29 2019
    2006 Scion Xb
    Hampton Roads
    I’m not exactly following, I would possibly but the board from you, then buy that connector but how would that go into the amp?
    Apr 02 2018
    UK
    May be these pictures in this thread make it clearer.
    https://www.audizine.com/forum/showt...nterface-cable
    The connector on the board takes the harness connector that would normally have been connected to the OEM amplifier. That instantly gives you access to power and all the speaker wires via the terminal blocks (or soldered wires).
    If you do need to go back to the OEM amplifier from the break out board, you attach the wires from male plug that you can buy from Audi or Aliexpress.
    Sep 25 2020
    palanza
    Quote Originally Posted by jackstone View Post
    Until now...
    I bought this:
    Where can I get this cable and does this bypass the oem amp and i can remove it or does the oem amp have to stay plugged in?
    Apr 29 2019
    South Holland
    Following 👍🏾😬
    Aug 14 2021
    Apex,NC
    Bruce, Would like to learn more on your Audi audio knowledge. I am researching the needed items to begin my Audi 2018 A6 base audio system install with the MMI 2G version. If I could install my new Hertz components using factory wires and have the cross overs in the trunk with amps that would save a lot of time. If that what the break out board does?
    Apr 02 2018
    UK
    Yes it can do that. But have you checked if your amp has the 38pin plug. Also just bear in mind that you can have the crossovers in the boot only if you have separate speaker outputs from the factory amp to the factory speakers. If the speakers split between woofer and tweeter in the doors, running off the same factory amp output, then you can't.
    Aug 14 2021
    Apex,NC
    Trying do determine which plug I have. I have the base system with MMI 2 and not sure where amp is located. I would probably be better off running new wires to eliminate any problems with crossover and have the option to go active if the desire should occur down the road. I know from a previous install in a GMC truck that it can be a pain getting wires into door. I guess that is part of upgrading.
    Apr 02 2018
    UK
    Audi only uses passive crossovers mounted on the speakers themselves. So there are no crossovers hidden in the wiring of the car. Most channels are actively crossed over at the amplifier. But in some places there is a passive crossover employed to split a mid/woofer into a tweeter.
    Aug 14 2021
    Apex,NC
    I appreciate all the info. So tough to find much out before tearing into a car without contacting a pro installer. I am interested in how well the Trioma works from anyone in here that have purchased beyond the OP. Want to have very good SQ setup in this car. Seems to be pretty sound acoustically with the stock stereo so I have high hopes of being able to build something that sounds great. The Trioma is less than half price of other signal converters I have been looking at. Will be running the fiber signal into a Hertz DSP so I donÂ’t think the price difference would be a huge factor.
    Veteran Member Three Rings Bobby Kinstle's Avatar
    May 16 2019
    2019 Subaru Ascent
    Livermore, CA
    The only "crossover" you are going to find are filter caps on the tweeters.
    Jun 25 2019
    Ottawa/Ontario/Canada
    Anyone know where to get the triangular cable jackstone shows in the photo.
    Jackstone I sent you a pm
    Apr 02 2018
    UK
    Quote Originally Posted by dkb7 View Post
    That is called a MOST bus extension or splitter cable.
    Mar 21 2006
    Revo Tuned 2.0L w/35r
    Lakeland, FL.
    I have MoBridge in my S7 and it works flawlessly
    BetaAlphaTauMember#6
    I'm back bitches!
    35r and REVO...what?
