Intake manifold with fuel rail (Fuel rail and injectors are from another part-out RS6 I had. It's not the same one that cause the detonation on cylinder 8) I can include the factory Y-pipe as well.
PENDING
Lower and upper oil pan. Uncracked. Had a block off plate on one drain to allow for single turbo. Easily removable. Oil level sensor included.
$250
Engine block. Cylinder has pitting. May be able to bore out. I'm making a table out of it if it's no use to anybody.
$100
Engine timing covers. Uncracked; sexy.
$80
Harness and ECU. Stock tune. Wiring sheath next to secondary firewall was removed to get a count on what kind of QD cannon plug I needed to run. Some broken connectors. The section needed for crank position sensor, oil level sensor, and driverside engine mount was cut from P.O. I have the cut section as well.
HARNESS $200
ECU $500
