Results 1 to 22 of 22
    Aug 12 2012
    Florida
    Audi TTRS Build Guidance
    I just picked up an 2018 Audi TTRS in Black. Going down the tuning route (she will be a competitor for my fully built F90 :)..) I obviously have a lot of questions regarding different tuning platforms and setups. I am sure these issues have been exhausted in prior threads. However, I am going to ask them here (at the risk of getting flamed). Nevertheless, hoping everyone can give some perspective and guidance on which manufacturer of different components to use. Plan is to go full E85 (eventual turbo upgrade) for now just full bolt-ons, excluding the turbo upgrade. In any event
    Tuning:
    From a pure power perspective should I go APR vs. Unitronic or another customer tuner such as Rrhamani (what others are available). I know must tunes are basically the same, but curious for other's perspectives (is there a sticky thread of 60-130 or quarter mile times to see what others are putting down in terms of numbers).
    Please note any other advantages and disadvantage of the different tuning options (for example, I believe you can toggle fuel maps in the dash with APR, whereas your can flash-tune at home with Unitronic).
    Also, I see there is no longer a Stage 2 option for APR? Only a Stage 1+ ? Is Stage 1+ basically the same thing? I don't understand why the Stage 2 isn't available any longer.
    What is the better TCU upgrade?
    Also, if I do e85, I believe I require Injectors and new plugs? If i get the new injectors and plugs and flash back to 93, will those be compatible? Or only with e85? Kind worried about whether I upgrade the injectors and plugs that I will still be able to toggle back and forth between e85 and 93 reliably for daily use.
    Inlet hose
    Which is best. I was thinking of going with APR, but the Untitronic site seems to suggset that their 4" hose gets better air flow than the APR hose. What other manufacturers available? What is recommended by others?
    Intercooler
    Is this even necessary for initial e85? Moreover, if it is, again, which manufacturers are available? Anything recommend over something else? I see an APR intercooler and a forge (maybe) brand? What are experiences with the intercooler? Any others. Goal here is MOST performance.
    Intakes?
    Does this add any vlaue or just sound? It looks like on APR site airflow is reduced with joined with their intake vs. factory? Am I reading this wrong?
    Downpipes
    What downpipe options are available recommended? It looks like APR doesn't make downpipes anymore? Should I go IE? USP custom? Others? Moreover, can I do de-catted and use the APR Tune. I heard / read something about how a lot of tuners are no longer removing the CEL via tuning due to EPA liability concerns? So, does that mean if I get a de-catted downpipe from one brand and then, say, go with APR for tuning does that mean that I am going to have a CEL? If so what are my options? Different tuner or am I stuck with a catted setup?
    Exhaust
    Any recommendations?
    Spacers / Coils / Suspension
    Recommendations here? I hate the factory ride hide and wheel setup :(
    Turbos
    I will eventually upgrade turbos, so if there is anything more experienced tuners can add regarding the upgrade please advise.
    Other
    Anything else you'd like to add :D
    Ill try to get pictures up later
    JA
    Aug 12 2012
    Florida
    I decided to go w unitronic for tune. Flashed stage 1 today . Apr inlet, intercooler,
    And plugs going on tomorrow. Then I’ll up to e85 1 + ... iroz downpipes to follow
    Jun 30 2020
    2018 TTS, 15 S1000r, 14 Z1000, 1990 ford festiva
    Southern Indiana
    I went apr and i would will be switching to unitronic soon. APR seems to be not as strong. Their e85 file uses factory injectors. unitronic wants you to upgrade the injectors and adds a bit more up top. So if you want to run e85 and simply max out the stock turbo go uni.
    Jun 30 2020
    Southern Indiana
    Also going unitronic they have more tunning options on turbos. They offer the same tunes as apr but more. Go uni now max out the stock turbo and it will prepare you better for hybrid turbos in the future.
    Established Member Two Rings RSpeeds's Avatar
    Nov 04 2019
    2020 BMW X3M
    Quote Originally Posted by JBA87 View Post
    Tuning:
    Inlet hose
    Which is best. I was thinking of going with APR, but the Unitronic site seems to suggest that their 4" hose gets better air flow than the APR hose. What other manufacturers available? What is recommended by others?
    Intercooler
    Intakes?
    Downpipes
    Exhaust
    Turbos
    Other
    Tuning
    You will find that most will suggest Unitronic and from what I can tell they have offered a good product. It also sounds like they are looking to improve upon their software some more. If you are the kind of person that wants an easy flash and to basically forget it then an option like Unitronic will suit you well. You do mention going with a larger turbo though. Since, at least at this time, Unitronic only offers OTS tunes and not custom tunes you will be limited to the turbo's they have created tunes for.
    A newer option, that in my opinion will be the go to tuning option for this platform once it ages a little bit, is in Beta. It is called the DS1. You will have more features than the other tuning options you mentioned. Things like rolling anti lag, on the fly adjustable launch control rpm, gauge hijacking, flex fuel, and more. You can use their stage 1 and stage 2 OTS maps while you're running the stock turbo. Once you go with a larger turbo you really should be running custom tunes. They have a stage 3 (hybrid) and stage 4 (full frame) base files for a custom tuner to build off of. Be sure to consider this when shopping for tunes.
    I haven't heard much about other companies and at this point plan to run the Unitronic TCU stage 2 flash. If you do end up going with someone like APR then I would stick to their TCU solution too as they were developed together.
    Yes, injectors and plugs. Eventually you will need a better LPFP if you continue down the upgrade path. You can run them with E and pump just fine. For solutions like Unitronic, for now, you will need to flash at the pump. Solutions like the DS1, the tune will adapt on the fly.
    Inlet
    I will be going with the Unitronic 4 inch inlet. I honestly believe there is no reason that anyone should be purchasing a 3 inch inlet at this point. They have adapter rings so it will work with larger turbo's once you go that route.
    Intercooler
    I haven't made up my mind about intercoolers yet. Keep in mind that not all intercoolers that fit the RS3 will fit, without modification, on the TTRS. I will say I was surprised on how well the stock unit did. I am on a stage 1 tune and it is cool out now but I saw an increase of 35F over a 1/4 mile pull. I am not saying I recommend staying on the stock intercooler but this has removed some of the urgency for me to replace it. The last thing you should consider is how it will look in the front of you car. I also have an all black TTRS and my intercooler is black from the factory. I think putting an aluminum intercooler on it would take away from the front end.
    Intakes
    You have to decide if it financially makes sense to go with the higher end intakes. The sealed carbon fiber options have shown to add a few more horsepower. The open air intakes have been shown to sound great but not really net any power. I have personally struggled with this decision but I have decided that over $1,000 for an intake is just silly. I will probably pick up the CTS unit and wait until there are more better low cost solutions.
    Downpipe
    Iroz seems to be the popular choice here and is what I will plan to go with when I pick one up. A LOT of people complain about wastegate rattle which Unitronic doesn't tune out. Some other custom tuners say they have a fix for it. APR is no longer openly supporting the removal of emission systems. This means you will have a cell and they will not sell catless downpipes. I believe Dyno Spectrum (DS1) has the same stance but since they are an open platform you can go into the OTS and turn it off yourself.
    Exhausts
    I have no input on this.
    Turbos
    The first thing you need to decide is if you plan to build the engine or not. People have seen engine failures on the stock turbo running E85. The rods in this engine aren't strong enough the for torque everyone wants to run. If you are planning to build the engine then hybrid or full frame? From what I can tell most people like the TTE700 & TTE777 and the Iroz full frame kits. I used Pure Turbos hybrid on my last two BMWs and have had great experiences with them. I will say that someone has reported blowing their Pure 800 due to excessive exhaust gas temps. I will look more into this but would be looking at their Pure 850 option which is ball bearing.
    Other
    Think out what all you want out of the car. Maybe think about the performance or purpose and then look at other builds to see what need to be done to get there. Don't waste money switching tuning companies or going hybrid when you know you will want to go with a full frame kit. Think about how much money you can justify spending on this car and try to stick to that. I think the TTRS is a great car. The fact that the rods need to be upgraded to run larger turbos is a bummer. The fact that you can run 9's on the stock turbo though is pretty nuts. Congrats on your purchase and enjoy. Also post up when you're doing things to it. The TT section gets a lot less action than the RS3 section.
    Get an upgrade dogbone mount, ECE is what I will go with.
    2020 X3M | 11.0 @ 128mph | MHD Stage 2 E30 Tune |
    2019 Audi TTRS | 10.55 @ 130mph E63 | Neuspeed RSe102 | PS4S Tires | DS1 | CTS 4 Inch Intake | CTS 4 Inch Inlet | CTS Turbo Outlet | SRM Ethanol Sensor Kit | Iroz Downpipe and Midpipes | ECE Dogbone | 980cc Injectors | 18 Inch Hoosier DR2's | IROZ 800hp Intercooler |
    Veteran Member Three Rings Jeff_Jeske's Avatar
    Nov 24 2018
    Madison WI
    I am a Unitronic customer and I give them 5 stars. When I purchased I bought the stage 2 ECU and TCU tune but decided run the Stage 1 software for a year because I wanted a catted downpipe. The UNI Stage 1 E85 tune with only a CTS FMIC allowed me to run a 10.6@130.
    This year I purchased the Unitronic catted downpipe and injectors and finally moved to Stage 2 E85. This allowed me to run 10.4@131 but the a Stage 2 car REALLY needs an intake and inlet to achieve full performance. I have not purchased either of those yet.
    One thing you may not see on this forum is a bunch tuner support and that is because most of the tuners use private WhatsApp groups to provide personalized support. The UNI group has hundreds of member that help other members as well as key players providing support from the manufacturer as well. I tell you this because those groups are active 24/7 and new features as well as parts are announced and sold inside those groups well before the general public hears about them. To compare and contrast, this forum is D E A D compared to the activity in these groups.
    Long story short, I would highly suggest you go with UNI as they have a strong and happy user base and a proven history of safe but outstanding performance.
    Nov 04 2019
    2020 BMW X3M
    Quote Originally Posted by Jeff_Jeske View Post
    I missed it, you probably did too. He was the second post and already ordered most of the parts and went with Unitronic. At least this thread will be here for others to reference in the future.
    Aug 12 2012
    Florida
    Wow the thanks guys for the info. So I got both tunes to test them .. however
    I just upgraded car to Stage 2 93.
    Mods are as follows:
    APR Stage 2 ECU
    Unitronic Stage 2 TCU
    Apr turbo Inlet and intake
    Apr intercooler
    USP Catted Downpipe
    93 Octane
    Full weight / 20” inch wheels / driver 190lbs
    I flashed yesterday, and installed all parts. Took car out for a quick 60-130 test in South Florida, and posted like a 10 flat, which seems VERY slow to me (felt fast but the time seems very slow). Temp was 82 and DA like 2200.
    Question: Does this time seem right ? And, how sensitive are these cars to temp / DA. I would have expected an 8 second time on 93 w this setup, with hopes of being in low 7 / high 6 once I flash over the e85. As I started carefully inspecting dragy times, I notice that most of the quick times on this same or similar setup are in much cooler temperatures (like sub 50 degrees) with low or even negative DA. I know driving conditions are important but I wasn’t anticipating like a 2 second reduction due to humidity and weather. My guess is that the tune is causing ignition timing retard in the hotter weather (are these engines air cooled?) ... which sucks .. as I was hoping to see the 6s w e85 and no turbos but not thinking that likely anymore in so Florida ... I’ll try to post some logs later
    I also have unitronic ECU and once the injectors arrive I’ll try switching to that tune to see if any improvement
    Thoughts
    Nov 24 2018
    Madison WI
    To achieve good results on pump gas you need to run E20. From the pump most 93 is E10 so you may need to add a gallon of E85 to every 6 gallons of 93 to achieve optimal knock fighting potential.
    You will also need to make a couple pulls to allow the car to adapt to that fuel. I typically see performance plateau after 4-5 wide open throttle pulls.
    Aug 12 2012
    Florida
    Thanks. It's possible that it was fuel related. I went to a Chevron, which has the worst 93 Gas. I was just shocked at a 10 second 60-130 on Stage 2. I was hoping for something closer to the low 8s. I have flashed to full E85, and will give that a whirl. Keep in mind the run was from a roll - not a launch. How do you typically shift? Do you keep in S or in M. And, if in M, what are you optimal shift points.
    Nov 04 2019
    2020 BMW X3M
    For reference I ran a 12.5 stock with passenger, full tank, and groceries when it was 85F out, elevation was about 175 feet. Running the DS1 OTS 91 octane file (before their power update) on an otherwise stock vehicle I ran a 9.68. Temp was 61F and elevation was 190. This was during a 1/4 mile run so I would suspect a slightly better time had I started from 40 or so.
    93 octane file was 9.12, 51F out 160 feet elevation. This was also done during a 1/4 mile run.
    I would say 10 is slow for a pump gas stage 2 car. I have heard others say that APR isn't the fastest but have no first hand experience.
    Jul 12 2018
    UK
    I honestly thought the APR 93 was not too far off Unitronic, but worth giving that a try. As a bonus, you can download the Unitronic logging software and take fantastic logs via their cable on a run and that will help you see what's going on. 10s is really slow for sure, to compare I was running mid 8s on Stage 1 with full stock hardware in spring, and mid/high 7s on stage 2 in summer.
    For reference... TTRS full weight, Stg2 Unitronic, IE intake and downpipe, Forge intercooler. My winter bests on Ethanol are 10.1@138mph and 6.2s 60-130, but in summer that'll drop to 10.3@135 and high 6s maybe even into 7s, which is probably more like your current DA (which has a huge impact).
    Aug 12 2012
    Florida
    Yes. The time was definitely very concerning. The car didn't feel that slow. So, I was slightly taken aback from the time. Admittedly, it was very humid, and the car was literally brought to Stage 2 a few hours before (went from stock to stage 2 and then the first run was within a few moments). I flashed the e85 tune for APR and hopefully will be able to get a run in tomorrow or this weekend. I really wish UniTronic offered map switching via mobile app like the APR Tune (it's so convenient). My MPI Injectors arrive Friday, and I'm picking up my Untironic cable and the injectors on Saturday. If I don't see big improvements in time on APR, I'll flash to Unitronic to log. Speaking of Unitronic vs. APR. If I have APR STage 2 E85 loaded, does anyone know the flashing procedure if I want to try Unitronic. For example, do I nee to go to APR Dealer and flash to stock, Then loan Unitronic Tune or can I use the Uniitronic cable to flash APR STage 2 to Stock and then to UNI Stage 2?
    I don't think the other components would be a contributing factor (i.e. APR 4" Inlet and Intake vs. Unitronic probably not much different, similarly USP catted downpipes probably not that much different from IROZ de-catted downpipe, and APR Intercooler probably not that much different from other coolers). My guess is I probably had low quality 93 gas from Chevron in the take; which, when combined with the fact that the car had very little time to adapt to the performance parts (literally less than an hour from flash and full install of all Stage 2 components parts) and the high humidity/DA/temps, resulting in significant ignition timing retard, which caused the car to run a very low time.
    I am really hoping Stage 2 E85 (the setup I have with the parts I have) puts me in the mid-6s from a roll on the 60-130. I gotta roll my buddy's F90 M5 Stage 2 E30 until my built m5 comes back :D
    Btw, I ran times both in manual mode and in S. My Manual time (second run) was slightly slower than my S run (1st run). However, I noticed on S the cars auto shifts at like 500rpm prior to redline (is that normal)?
    In full manual, when do you recommend shifting? Do you take full through redline or early shift?
    Nov 24 2018
    Madison WI
    I leave the car in Sport mode for all things even the drag strip.
    Not running to the marked redline is normal in sport mode.
    Be advised if you are running a tire that is shorter than factory that will likely mess up the shifting as it's not based on RPM but some derivative of transmission shaft speed. Try to stick as close to 26" diameter as possible.
    Nov 04 2019
    2020 BMW X3M
    I'll be that guy... The DS1 (Dyno Spectrum) allows for on the fly map switching. When you flash the car you're flashing a stage. So for most people it will be stage 1 or stage 2. From there you can switch to different preconfigured maps within three seconds. They have up to 9 available slots. That combined with flex fuel makes it super convenient to make those types of adjustments.
    Aug 12 2012
    Florida
    Quote Originally Posted by RSpeeds View Post
    Yes. APR is similar.
    Nevertheless, I switched maps to e85. I had about 3/4ths of a tank on pump E85 (probably around E80). From a roll on the street, full weight w 20 inch stock wheels and Pirellis in S Mode, car ran a 60-130mph in 8.4 seconds. While this was an almost 2 second improvement from the 93 run, this time still seems quite slow for for E85. The temp was 81F and DA 1700 according to dragy.
    Again here are the mods:
    APR Stage 2 E85 ECU
    APR Inlet & Intake
    APR Intercooler
    USP Catted Downpipe
    I still think this should be in the low 7s /high 6s on the 60-130MPH? Am I missing something?
    Does anyone know how I can datalog with the APR Mobile APP?
    JA
    Aug 12 2012
    Florida
    Quote Originally Posted by Ross_T_Boss View Post
    This is exactly what I was expecting. I just flashed to E85 and did 8.4 on the 60-130 from a roll. Admittedly it was the first run in 81 degree weather and 1700 DA. But, still I was hoping to hit the high 6s at least. Sigh... Looks like I'll need to try Unitronic, unless car just needs a little more adaptation (it's been Less than 24 hours since installed all performance parts and flashed car).
    Aug 12 2012
    Florida
    I was able to muster an 8.05 today (still on APR). Similar temp and DA. So a 0.35 second improvement from yesterday. Perhaps car getting more used to the mods. Let's see if she dips into a 7 before I test Unitronic. I'm anticipating that their file may be a tad stronger because of the Injectors.
    Aug 08 2017
    2005 TT VR6 DSG - project car
    Beaumont/Alberta/Canada
    I’m running Unitronic ECU/TCU stage 2 full bolt on, injectors etc for E85. Unitronic has IME the best customer service I have ever seen from a company, and the fact you can swap tunes with your laptop in the car makes it very user friendly. I’m at the point where the next upgrade will be a turbo. You can check out my build thread here if your interested to see what I’ve done to my car.
    The basic rundown on engine performance mod’s,
    • Unitronic stage 2 ECU/TCU (E85 & 94oct tunes, summer/winter)
    • Iroz DP & MP
    • Wagner tuning competition IC
    • Unitronic/MPI injectors
    • Unitronic 4” turbo inlet and airbox
    • Unitronic/P3 gauge pod
    • Zietronix fuel sensor, gauge kit
    2018 TTRS / Unitronic / MSS / IROZ / ALPriority / NetRadar / Automotive Passion - IG 12453_tt
    2005 TT VR6 DSG new project
    Aug 12 2012
    Florida
    Got a 7.98 last night on a 1/2 tank and APR.
    Aug 12 2012
    Florida
    Switched to Unitronic and installed injectors
    7.34 first run .. pretty big improvement from apr best of 7.98 .. same setup (minus the injectors)
    Junior Member Two Rings
    Sep 08 2020
    Atlanta GA
    Tuning:
    Inlet hose
    Intercooler
    Intakes?
    Downpipes
    Exhaust
    Turbos
    Other
    JA
    I bought a 2018 TT RS about 5 weeks ago myself. Mine is Catalunya red and only had 1,800 miles on it. I am also planning on heavily modifying and upgrading mine as well. I have a 7-page project doc with all the links to different builds, parts, manufacturers, and additional research I did across all of the available options. I have a bunch of parts currently being shipped to me right now and will have them installed within the next 1-2 weeks.
    For the first round of upgrades I am going to stage 2 e85.
    Unitronic:
    Intercooler (This is not released yet, but will be announced this Monday)
    4 inch intake
    4 inch turbo inlet
    Downpipe
    Midpipes
    Upgraded MPI injectors
    Vargas Turbo Technologies:
    Engine Catch Can
    DSG Catch Can
    APR:
    Upgraded coil packs
    Upgraded cold performance spark plugs
    Custom:
    Custom titanium fabricated intercooler piping from turbo to throttle body inlet
    Tune:
    Unitronice Stage 2 e85 ECU tune
    I will have a couple of other rounds of upgrades coming after this as well. Getting a full aero kit with diffusers, side skirts, canards, wing etc. I will also be going with Essex AP racing brake kit, upgraded coil overs and a few additional 034 motorsports parts as well. The final big performance upgrades will be getting the engine built with forged internals and a big full-frame turbo to match.
