Results 1 to 22 of 22
    Dec 07 2017
    Spruce Grove Ab Canada
    Brightest headlight bulb
    Has anyone tried the osram d3s 7000k cool blue boost hid bulbs? They actually any brighter than stock and dont throw any codes? I do a lot of mountain driving in the winter at night for snowboarding and never been blown away by the stock headlights by any means
    Veteran Member Three Rings 3.0ss's Avatar
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    I’ve got the CBB’s and they’re great, they’re not 7000k more like 5500k as they lie for advertising but they’re bright.
    2010 S4 Prestige 6MT - Brilliant Red | 034 Stage 2 | 034 190mm | Merc HX | Milltek Resonated Exhaust | Gutted/Reinforced Cats | S34 Intake | JXB Short Shifter Kit | AG M580's | Bilstein B8s | H&R Sport Springs
    2018 Q7 Prestige - Orca Black/Cedar Brown Valcona | Luxury Pack | Driver Assistance Pack | Cold Weather Pack | Towing Pack
    2014 Q5 P+ - Lava Gray Pearl | 3.0T | B&O | MMI+
    Apr 23 2019
    I have CBB, the light is much brighter and alot whiter.
    Only problem is maybe longevity.
    I bought a pair and they lasted 3 months before one bulb burned out. Hope it was some factory defect, didn't read much reviews about the same thing happening. I bought another pair because they were so good.
    Jul 31 2016
    PA
    Quote Originally Posted by Tjtubbs View Post
    For that kind of driving you should look at the osram night breaker lasers. They won't be the whitest bulb out there but the performance is outstanding.
    You are only going to get so much out of the stock projector so maybe consider an upgrade there too if you do a lot of night driving.
    Sent from my SM-G988U using Audizine Forum mobile app
    Custom DP 194/57 E40 Water-Meth (Aquamist) | BG HPT ZF8 Tune | APR CPS with AWE Reservoir (Divorced Coolant Loop) | APR Open Intake and 034 Intake Tube | RSE Heat Shielded HFCs | CTS Downpipes with Vibrant UQ Resonators Added | AWE Touring Exhaust | 034 RSB | Bilstein B8 Shocks and H&R -3 Springs | ECS Trans and Drivetrain Inserts | 034 Trans and Motor Mounts | Moog Front End Links | Headlight Projector Retrofit and Painted Housings
    Established Member Two Rings Atrevido's Avatar
    Mar 19 2018
    Florida
    Please remember the 7000K you mention refers to the color temperature, or shade of light. Focus on lumens as well if you want brightness.
    If you have a few minutes, check out https://www.youtube.com/watch?v=8v4QgnPLjVU. They explain the difference, and are the
    reason I chose to go with the Osram CBI 5500K. They're a definite improvement over stock.
    2013 S4 / 6MT / Phantom Black / APR Stage II Single Pulley / Sports Diff / RS4 Grille / Sachs Performance XTend Clutch / ECS Lightweight Flywheel / ECS Transmission Mount Insert
    ECS X-Pipe / K&N / Modded Air Box / CR-15 / Osram CBI 5500K HID / Zimmermann / Akebono / Pirelli P Zero AS Plus 3 / Hard-wired Valentine V1 Gen 2
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    I second upgrading your projectors if you want the best light output possible, the OEM projectors suck imo. I put the CBB's in my stock projectors and meh, I still struggled to see farther down the road and I wasn't pleased with it. I live out in the country with no street lamps anywhere so I need as much light as I can get, I swapped in some G5 projectors and the light output is incredible. If you have ~$250 and a free weekend I'd 1000% recommend upgrading them. Since you do a lot of mountain driving there's a few people who have mounted light bars behind their grill if you REALLY want to throw some light on the road.
    https://www.audizine.com/forum/showt...Projector-Swap
    Mar 05 2016
    If you’re looking for the brightest output, I wouldn’t suggest 7000k colour, stay in the range of 4k to 5.5k. I replaced my stock bulbs with the Osram Night Breaker Laser and tou see a significant difference. There are currently the brightest D3S bulbs in the market. If that not enough for you, you need to go with plan B, upgrading the projectors iself.
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
    Dec 07 2017
    Awesome thanks for the input, i think ill go the full projector swap route
    Jul 26 2019
    S4, Q7, Q5
    Cumming, GA
    Sweet, best of luck man! If you have any questions abt it I’m happy to help!
    Jul 31 2016
    PA
    You wont be disappointed. Could consider swapping to a D2S system too, check out theretrofitsource.com or talk to Cesar at Lightwerkz for some good options too.
    May 07 2020
    Toronto, Ontario, Canada
    Quote Originally Posted by djn876 View Post
    I'm looking to replace my projector bulbs in my 2010 s4 when they burn out what ones do you all recommend. Looking for the brightest ones I can get that are white in colour
    Jul 31 2016
    PA
    Quote Originally Posted by higsy98 View Post
    Probably an Osram CBI or Philips XtremeVision. Spend some time on the couple sites I referenced above, they have a lot of stuff listed.
    Mar 05 2016
    Osram Night Breaker Laser and Philips Xtrem Vision Gen 2 are the two brightest bulbs you can get.
    May 07 2020
    Quote Originally Posted by TC_S4 View Post
    Those led? If not are leds good?
    Mar 05 2016
    No, we’re talking headlights HID D3S bulbs. You can not put led bulbs on HID’s projector housing.
    LEDs are more for the fog lights.
    Jul 31 2016
    PA
    LEDs should not go into a housing that isn't designed for an LED. Your light output will be worse, and you will just blind everyone on the road. As stated, they won't swap directly in to the HIDs anyway. The bulbs mentioned are not LED. You would likely need a D3S HID bulb.
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    Have you thought about adding an LED light bar behind you grille. I have seen this done and those things will brighten up the sky.
    Sent from my SM-G970U using Tapatalk
    May 07 2020
    Quote Originally Posted by DarrenOman View Post
    Like in front of the heat exchanger?
    Nov 03 2014
    2009 Gray A3
    California
    Yes. Either on the crash bar behind the grille or under the grille on the top of the upper lip.[IMG][/IMG]
    Mar 05 2016
    That looks rice, I'll did something like that on my Honda Civic, was cool back then, not so much on an Audi
    Nov 03 2014
    2009 Gray A3
    California
    Personally I would install a light bar unseen, behind the grille on a seperate switch. Especially if you are dark back roads.
    May 07 2020
    I'm curious if you mount it in front of the heat exchanger if it overheats
