I was trying to have my rear wheel bearings inspected, so my warranty company sent out an inspector.
Instead, unexpectedly, the warranty inspector found 2 issues:
1. Pinion (part of the rear differential?) - never seen this as a problem with any other owners, but the shop tells me they put the car on the lift, and revved it a few times and inspector claimed it was the pinion rattling...
2. Rattle on startup (I previously didn't notice this, but hey, if he's claiming that he heard that I'm not denying that either because I know the 3.0 TDI engines have this problem area sooner or later), and approved to have the timing chain tensioner changed. I'm also paying a couple hundred out of pocket to have all the other parts that go along (rails, timing chain, guides) changed as well because why replace one only part if all the others have the same number of miles right?
These two things together are $5k worth of labor and parts that the warranty company covered.
If you were me, even if you didn't really notice these problems before, knowing that the timing chain tensioner is a part that is a problem area on the 3.0 TDIs, would you be comfortable changing out all these parts? My car is at 52k miles and drives smoothly... Though the shop is a local euro shop that is very reputable and works on exotics, Porsches, tons of Audis (and TDI engines too), I am still slightly worried I'm performing an "open heart surgery" on my car with things that I didn't notice were problems before...
