Let me tell you guys my wonderful experience and how I haven’t driven my car since Thursday.
Friday- took wheel off and took caliper off no problem, then the rotor was stuck even after hammering with a sledgehammer, mallet while using a combination of PB blaster, nothing worked. I was ready to give up. I couldn’t! I ordered a 5 ton puller and luckily it arrived the next day.
Sunday (today) - I took off caliper no problem, puller was able to get the rotor off no problem, everything was going great!!
I go to finish the front and again no problem removing rotor with puller and everything was great. Took about an hour and a half to do the front.
I put the wheels back on, tighten them and go to break in the new pads and rotors.
As I’m pulling out of the garage I feel something pulsating, scrape..scrape..scrape..scrape, so I look it up and it says that when you replace the brakes and rotors there may be some pulsating and that’s just the pads getting familiar with the rotors, but it was slowing the car when I didn’t have my foot on the brake so I got worried and texted some friends, no one could figure it out but one of my friends said it should definitely NOT be pulsating. Well, I’ll finish the story here.
I have aftermarket wheels which were measured when my brake pads were worn down significantly. They didn’t clear the caliper with the new pads since the caliper gets pushed out more. Luckily my calipers are fine and it only hit the screw for the cover. But the wheels have a nice groove on the inside and now I have to run spacers on custom measured wheels
Luckily a shop about 30 minutes away had some 3mm spacers and it fixed all. So I took the car on a little drive for the first time in a while and so far I say these brakes are terrible compared to oem. They aren’t fully broken in but I’ll give an update tomorrow
2016 Audi A6 prestige black optic. No mods yet
